Question about Lanzar (Pair) MAXP104D Max Pro Series 1200W 10" Subwoofers Car Speaker
Want to find out the best type of enclosure for 2 lanzar max pro 124d subwoofers
  • 37 Answers
You best type of enclosure will be a sealed enclosure or you can build it with a partition in the middle seperating the 2 subs and port each side.
heres a link that will give you the specs for your sub
http://www.lanzar.com/manuals/MAXP104D-124D-154D.pdf
Posted on Sep 21, 2009
On a lanzar 535n 5 channel 3200 watt amp what is the best way to hook up 2 lanzar max 12 inch duel voice coil subwoofers
If your amp allows it hook the the sub's to the first two channels but bridge it and only run it on 2ohms so you don't blow your sub's
May 29, 2015 | Lanzar Car Audio & Video
Recommended enclosure for maxp154d
Send me the type and model of vehicle it is going into. From there we can determine what type of sub box to build.
Jan 31, 2012 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
I have a lanzar max pro 15'' subwoofer and i need to know how to wire it. It has four wire inputs on each side teo positive and two negative, is this just to change it from 4 to 8 ohm or something?
In part yes it is a flexibility for wiring your speakers to match the impedance of your amp. For example if your subs are 2 ohm dvc by wiring them in parallel you can drop the impedance down to 1 ohm per speaker and if you connect two 1 ohm then you get 1/2 an ohm load. Or you can put them in series and increase the impedance to 8 ohms which I wouldn't suggest you do. Here is a link to wiring speakers:
http://www.crutchfield.com/S-cgSECUmngLm/learn/learningcenter/car/subwoofers_wiring.html
Sep 19, 2010 | Lanzar (Pair) MAXP104D Max Pro Series...
In the Lanzar HRB212 bandpass enclosure.. are the 2 subwoofers wired/connected in parallel or two independent connections? What is the individual rating/specs of each subwoofers?
I looked at a couple of sites and one site said two 4 ohm subwoofers.That means they have to be parallel.It didn't say about the connections.Here is a link that better describes them.They are loud.I SAID HERE IS A LINK THAT BETTER DESCRIBES THEM.LOL Good luck and rock on! Greg
http://www.onlinecarstereo.com/CarAudio/p_16424_Lanzar_HRB212.aspx
Aug 19, 2010 | Lanzar HRB212 Car Subwoofer
How do wire my 15'' to 1ohm
If each voice coil is rated at 2-ohm, then wire it in "parallel". This will make a 1-ohm total load.
amp pos. out to coil 1 pos. to coil 2 pos.
amp neg. out to coil 1 neg. to coil 2 neg.
If the they are dual 4-ohm, the rating would be 2-ohm in parallel.
Mar 16, 2010 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
Could me and friend install a lanzar max 15" sub into a 2004 honda accord??
Technically speaking, you can install whatever you want into anything you want to install it into. I recommed you doing your research first, because a good amp and sub install job is more than just plugging stuff up. And if your not upgrading to an aftermarker HU, fuggedaboutit!
Feb 22, 2010 | Lanzar (Pair) MAXP104D Max Pro Series...
Why lanzar subwoffer keeps flaping when volume is raised
It could be the magnet slowley falling off or most commonly the tinsel leads hitting the spyder.
Dec 22, 2009 | Lanzar (Pair) MAXP104D Max Pro Series...
Knocking noise with my kicker compvr 15"
comp VR 15s are rated @ 500W RMS 1000Peak.
The lanzar vibe amplifier is 2 x 600W RMS at 4 OHMS 2 x 1200W MAX at 4 OHMS 1 x 2400W MAX at 4 OHMS Bridged 2 x 1000W at 2 OHMS RMS.
Your subs are single 4 ohm subs.
If your subs are wired stereo, they both are seeing 600W. (more than the rated RMS)
Chances are, you have them wired parallel to a 2 ohm mono load - of which that amplifier is not rated. In theory, it will produce about 2000W @ 2 ohm mono for a short period of time.
Your amplifier is too powerful for your subs. Turn down the gain setting to 3/4 or purchase better subs. Also be sur the subs are inthe proper enclosure. It sounds as if they are excurting past their linear x-max and colliding with the rear bump plate. This will cause damage down the road if left as is.
Nov 26, 2008 | Kicker CompVR 05CVR84 Car Subwoofer
Subwoofer Box for four lanzar 15"
what r u trying to do ?shake the car apart?Only kidding that a good questin 4 15: woofers in 1 enclosure>?what kind of enclosure ?how much space r we working with ? i use to be a installer , i also built costume boxes.I need to knoew how much space u have is it a car van,pick-up?I think an iso baric enclosure woukld be your best bet, it would take up the laest space. What frequency are you going to be runnig to your subs? what do you want? punchy bass,over the big tom drops?
what amp r you running or should i say amps?
you'll get the highest spl in a sealed enclosure,but i dont think thats what your looking for.you want heavy vibrating soud,am i correct? a band pass box will give that to you in a close space.bass sounds better and louder the further away you get../.give me more info then ill give you a layout.but 4 now this might help or solve your problem
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
they have all the wiring and p[hyschics and designs of boxes. rating please.
Jan 25, 2008 | Lanzar OPTI1222D Car Subwoofer
Lanzar (Pair) MAXP104D Max Pro Series 1200W 10" Subwoofers Car Speaker Logo
341 people viewed this question
Top Lanzar Car Audio & Video Experts
Radames Pagan
Radames Pagan
Joe Alexander
Joe Alexander
Jose Velazquez
Jose Velazquez
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
