Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Dishwasher fills with water but won't start washing
Rotu
  • 175 Answers
SOURCE: washer
If I'm not mistaken, these dishwashers are built by Asko for Viking. If thats the case then you probably have a bad circulation pump. Under Asko's warranty (not sure if Viking is the same) these pumps are covered parts and labor for 3 years from installation date, and 5 years for the part only. The pump is accesed from the back of the machine,so you have to pull out the dishwasher. Then you remove the lower plate in the rear and the motor at the very back center is the pump. You remove it by turning it about a 1/4 turn either clockwise or counter clockwise, depending on the style, then place the new one in and turn it to lock it in place, being careful that the sealing oring stays in place or youll get a leak. The part will probably cost you around $150 unless viking marks theirs up more than Asko. Good Luck!
Posted on Nov 23, 2006
  • 9 Answers
SOURCE: Kenmore dishwasher 58715142400 fills but doesn't wash
All kinds of qwerks with newer Kenmore units. When did u buy it?
Posted on Jan 26, 2008
SOURCE: beko dishwasher fills with water, does not wash but will drain the water away
impellor buggered. Needs replacing
Posted on Apr 12, 2008
reg501
  • 413 Answers
SOURCE: Kitchenaide KUDM24SE1 dishwasher will not fill with water
It may be the water inlet valve or the electronic control board. To check, remove the bottom toe panel. The valve will be on the left side. There will be live power, so use extreme CAUTION. Start the DW, 1. if you can hear the valve humming or the valve coil is getting warm, replace the valve. 2. Using a device with wires to check the power at plugs, connect to valve power connection, if power is present, replace valve else replace electronic control board.
Posted on Jun 07, 2008
  • 236 Answers
SOURCE: my carlton dishwasher fill and drains but does not wash
sounds as though the wash motor/pump is jammed or has seized therefore no wash.
Posted on Mar 16, 2009
New dishwasher won't wash
What noise does it make?
Jun 09, 2013 | Dishwashers
Shx33a05uc won't start washing
bosch smu -4052 will not fill with water
Aug 08, 2012 | Bosch 24 in. SHU43 Built-in Dishwasher
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 | Dishwashers
Boscsh shu3322uc dishwasher won't fill. If I put
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Sep 09, 2011 | Bosch SHU3306UC Built-in Dishwasher
Water won't drain
Do the diagnostic test:
SHU 53 MODELS
To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show “88′ when REGULAR WASH button is pressed and “8h” when Delay Start button is pressed.
To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4).
0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault
1 = Aqua Sensor (“Sensotronic”) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
If water level switch (f1) has failed (opened), display will show fault code “4′ and unit will continually fill and drain where testing won’t be completed. If flow switch (e5) has failed (opened), display will show “0′, water won’t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code “8′ immediately and testing will end shortly after water has started circulating.
The dishwasher not draining is most probably faulty drain pump or drain hose is got bit loose.It has to be checked and confirmed
.You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 27, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to...
SHU 53 MODELS To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button. To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show ?88″ when REGULAR WASH button is pressed and ?8h? when Delay Start button is pressed. To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor (?Sensotronic?) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test) To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code ?4″ and unit will continually fill and drain where testing won?t be completed. If flow switch (e5) has failed (opened), display will show ?0″, water won?t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code ?8″ immediately and testing will end shortly after water has started circulating.
Aug 01, 2009 | Bosch SHU5315UC Dishwasher
Dishwasher will not run after filled with water
The float switch in the tank is bad,also if water only trickles in your fill valve is going bad which will not let it fill all the way to start wash cycle. Fill tub with pot of water to raise float, if wash cycle starts,replace fill valve,if not,replace float switch.
Jan 21, 2009 | Dishwashers
Machine won`t fill
the water-inlet solenoid valve is inoperative-replace it
May 30, 2007 | Zanussi 24 in. DE6544 Built-in Dishwasher
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
110 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
