Question about Air Tools & Compressors
Rotary air compressor oil leak all over - Air Tools & Compressors
  • ollie reece-jones
    ollie reece-jones May 11, 2010
    best thing to do is run it up and try and seek where the oil leak is coming from then get back to me
  • 41 Answers
First of all clean the machine inside the casing,the motor, pump I mean every where whth no trace of oil be seen in the machine.check the oil level sight glass,if level is ok. start the machine and if you see oil leaking at a hose ,stop the machine repair the leak and clean again, and restart the amchine and check and repair till all leaks are settled.
Posted on Sep 29, 2009
What is the application or use of z6000 compressor oils?
The MSDS sheet on it may answer your questions.
Mineral Based
Compressor Oils are mineral based air compressor oil designed for use in many rotary screw, reciprocating and rotary vane compressors needing an ISO 100 oil of this type, providing up to 2000 hour oil drain periods.
Synthetic Based
Are a full synthetic, special, ashless, synthetic based oils, designed to provide extended oil drains in both oil injected and oil flooded rotary screw compressors. They contain a special shear stable synthetic base oil to help reduce deposit formation.
http://www.mitsuiseiki.co.jp/Portals/0/images/catalog/pdf/Z6000%E3%83%BBCOMPRESSOR%E3%83%BBOIL-E.pdf
Jan 13, 2016 | Air Tools & Compressors
Why does compressor push oil through air filter when it shuts down ?
Minimum pressure check valve is bad. when unit shuts down air pressure goes back thru compressor and pushes oil out the air filter.
Jun 02, 2015 | Ingersoll Rand UP6-20-125 120 Gallon...
Recomendation rotary compressor
1 check oil level
2 clean dirty oil cooler
3 replace thermostatic valve
May 09, 2013 | Ingersoll Rand Stationary Air Cooled...
My Ingersoll Rand UNI15-5-150-L rotary screw compressor only starts uo after trying to start between 10 and 15 times
image Regulator may difference on all set ups good luck
you may have a Regulator on Air-Compressor Mount on the Gauge or next to it this allow you to set a pressures from 0 - 200 psi this to helps you maintain steady and reliable operation of your air tools.
Apr 18, 2013 | Ingersoll Rand Stationary Air Cooled...
Quincy model model QMB/T is leaking oil out of filter
tighten filter
check that the filter is not too tight and distorting the seal
replace the filter
Oct 24, 2012 | Quincy Compressor Quincy 30 Rotary Screw...
My ingersoll ssr2000 rotary screw compressor trips &restart on it
Check defective HATS or Airend is defective. HATS means High Airend Temperature Switch.
Mar 03, 2010 | Ingersoll Rand Stationary Air Cooled...
I have oil leaking out of the air inlet filter on a qrs5.0 any ideas what the problem would be?
If it is an oil bath air filter, overfilling the filter could do it.
If there is excessive vibration that could cause it.
Possibly during shutdown some backflow of air occurs.
Nov 17, 2009 | Chicago Pneumatic Qrs 5 HP/3 Phase Rotary...
40 hp rotary screw IR compressor
Check if your compressor running in low pressure. If your discharge pressure drop @65psi the result is oil carry over.
Jul 01, 2009 | Ingersoll Rand Stationary Air Cooled...
40 hp ingersoll rand rotary screw air compressor keep shutting
I have a ingersoll compreesor that keeps shuting down on high discharg air temp
Nov 12, 2008 | Ingersoll Rand Stationary Air Cooled...
Air Tools & Compressors Logo
467 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
