Question about Kenmore Refrigerators
Where is the timer fridge keeps working nonestop
  • Kenmore Master
  • 4,654 Answers
Most defrost timers are located inside the fresh food compartment and behind the control panel. Not knowing your Kenmore's model number really does not tell me if you have a timer or an Adaptive Defrost system or if the defrost is completely controlled by a mother control board. Sears uses a different model number system than everyone else so I would need the model number to tell you exactly what you do have.Older models do have the timers and I think they are easier to work with than the newer brands, But the newer brands save energy because of the electronics.
So explain why you think it's the timer. Are temperatures increasing inside the fresh food compartment and the freezer? Is a layer of frost building up on the rear wall or on the floor of there freezer compartment? I am going to send some photos in a few minutes and try to help you find out what's going on with your refrigerator, Sea Breeze
Posted on Sep 07, 2009
  • John Tripp
    John Tripp Sep 07, 2009
    OK, Here are some sample locations and number that Sears would use.
    Sample model number for a Kenmore would be KENMORE, Model No. 253.64802400
    E. Cold Control & Defrost Timer/Automatic Defrost
    Control
    These parts can produce a snapping or clicking sound
    When turning the refrigerator on and off. The timer also
    Produces sounds similar to an electric clock. Location E is insid the control panel and shows two choices. A defrost timer or an Adaptive Defrost Control. Please don't forget to rate my solution. I will be here or at the locations below if you need more answers. In the photo below you can find the locations for the model number. If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
    appliancepartsse@yahoo.com
    http://servicepartstec.blogspot.com/
    http://appliancepartsse.blogspot.com
  • John Tripp
    Wow that was fast I just finished downloading the photos and information. Thank You very Much For The Rate!!
    Sea Breeze
    SEA BREEZE TIP's
Ticking sound is this the defrost timer on magic chef fridge
Sound like the defrost timer. Just get unit info and grab a new one and replaced. They are very simple to do
Jun 01, 2017 | Magic Chef Refrigerators
Fridge keeps freezing
Top of Form
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Sep 26, 2011 | Candy CPCA240FFK Bottom Freezer...
Kenmore refrigerator Model 253-68232800 will not keep food cold in fridge and frost build up in freezer.
Top of Form
Sep 14, 2011 | Kenmore 64722 Top Freezer Refrigerator
Freezer is cold, but cold air is not circulating in refrigerator
Check freezer fan is working.If ice formed over freezer fan by working. It's a common problem due to irregular defrosting. Keep freezer setting temp at 5 degree. And check defrost timer, thermostat,heater are working properly.
Turn timer with small tip screw driver to shut off fridge. If not shut off, replace timer. Turn counter clockwise defrost thermostat. If fridge not shuts off replace defrost thermostat.Check heater by join the 2 wires in the defrost thermostat. And after 1 minute, unplug power and keep your arm on heater. If it's warm heater is o.k. Otherwise, replace heater.
Once heater starts work at regular interval controlled by thermostat and timer, defrost will be good and effective cooling will also be in fridge compartment.
Jan 24, 2011 | Amana ABB2524DE Bottom Freezer...
The freezer is icing up again on my MSD2758GE fridge. How can I test to see if it the adaptive defrost assembly or something else?
Top of Form
Suspect the fault can be the defrost timer to confirm shut off the fridge, after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
So try this test from the outside and make your observations so that we come to the solution.
Oct 09, 2010 | Maytag MSD2758GEB Side by Side...
The fridge is not cooling!! The motor and fan are both making noises as though they are working and the freezer is working perfectly. I have turned the thermostat up to the maximum but still no cool air.
If there is no cooling on the fridge but the freezer is cooling then the compressor and gas pressure seems good. So to check the set for blocks in the ducts we must shut off the fridge.Keep it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
The fan making noise can be due to frost build up .If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
Do not set thermostat up to max but keep it to normal .So try this test from the outside and make your observations so that we come to the solution.
Oct 09, 2010 | Refrigerators
I have to keep the temperature turned up to 9 in order to keep the food at 45 degrees. The fridge is only 3 years old.
If it's the freezer control you keep at 9, it's probably a defrost problem. If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If it's the fridge temp control you're talking about The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 15, 2009 | Refrigerators
Freezer and fridge are not cooling but we hear the sound of the refrigerator
your defrost heater or timer is not working . rotate you defrost timer until it clicks and check if its is defrosting if it is let it defrost for about 10 mins and turn the timer some more to take it out of defrost. replace timer
Jun 02, 2009 | Hotpoint HSS25GFP Side by Side...
We have a Maytag Fridge model: MTB1956GE and the top freezer is not keeping food frozen, however the bottom fridge is working fine. In addition small pools of water have been cleaned up from under the...
Your defrost system consists of the timer, heater and thermostat. Your problem could be any of these. But because your fan doesn't turn off it is more than likely the timer. https://www.searspartsdirect.com/model-number/MTB1956GEW/3048/0166000.html
Oct 31, 2017 | Maytag Refrigerators
Refrigerators Logo
197 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
