We have a kenmore washing machine top load model 110. The machine stops on the spin cycle but will advance if you push in the button on the machine top with a pencil and hold the pencil in place. The little pin on the lid doesn't seem to push it in far enough. Also if you push down on the lid in the corner where the pin and button is it will advance but it doesn't stay on. Is it the timer or the button in the machine top that is the problem/
  • 5,911 Answers
You just solved the problem yourself. Replace you lid switch or replace the actuator on the lid.
If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
A new lid switch (if needed) can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. All these sites offer competitive pricing, so shop all them for the best price.
If you have questions, or need additional assistance, please let me know. Please post back with a complete model number (located on a nameplate around the wash tub opening) with your questions, so that I may be able to provide you with better assistance. I hope this is helpful.
NOTE: You do not need to bail or empty the wash tub to complete this repair.
Posted on Sep 07, 2009
  • 574 Answers
Yes if the lid switch dont stay in and make contact the washer thinks the lid is open and shuts down.
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Washer stops in rinse cycle
    your contacts swithces for rinse cycle inside timer could be burned or bad..very model I will locate part number
    Dec 15, 2007 | Washing Machines
    Kenmore 110 Spin Cycle
    Assuming that this is a basic top load, direct drive, neutral drain washer it seems as if the problem is likely in the timer.
    The transmission and draining are controlled by the motor which gets it's power through the timer. If the timer isn't advancing once it gets to the spin cycle area, the motor keeps getting power, the machine keeps spinning and only by pushing in the control knob will the motor stop.
    Here are a couple of places to look at how the machine works and parts for a basic Kenmore washer.
    Sears parts site:
    http://www.searspartsdirect.com/partsdirect/index.action
    Enter your model number and you'll see a number of sub catagories for the washer components.
    Whirlpool Installation and maintenance PDF.
    This is a public domain Whirlpool manual describing how the washer works and a good troubleshooting section.
    https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
    Sep 21, 2009 | Kenmore 22642 Top Load Washer
    Kenmore washer 110 24642300 will not go past spin cycle. it will just get towards the end of the spin cycle and will keep on spining. unless i lift the lid and push in the start button. thanks
    if your machine is getting stuck in aspin cycle and no longer advancing out on its own, sounds as if you have a dead spot on the timer, reccomend replacing timer
    Jun 09, 2009 | Kenmore Washing Machines
    Machine doesnot agitate or drain once filled with water
    it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
    Apr 24, 2009 | Washing Machines
    GOES TO SPIN CYCLE THEN STOPS SUDDENLY AND REFILLS WATER IN TUB
    Are you sure you don't have a second rinse button that is selected.
    Jan 11, 2009 | Kenmore 24032\24036 Top Load Washer
    Kenmore portable compact topload washer model 110 49722992--won't spin!!
    sounds like a broken motor coupling( this machines equivelent to a belt. part number 285753a . mounts directly to the motor shaft and connects to the transmission, order a new one it installs between the motor and transmission,assy
    Apr 03, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
    Kenmore Waher spin cycle out of balance
    Sounds like your front to back spring is pulling to tight, sometimes you need to replace it and sometimes you can take it off and stretch it. hope this helps
    May 19, 2007 | Kenmore 24872 Top Load Washer
    Washing Machines Logo
    60 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
