Question about RCA Televison & Video
Don't know what channel the dvd is suppose to be on. TV is set on 4 and I can't get dvd to change to four.
    Problem Solver:
  • 8 Answers
DVD players don't carry signals to channels. They carry signals to inputs. Check the back of your TV. If your cable coming from the DVD player goes into "video 1" set the tv to video 1, etc.
Posted on Sep 07, 2009
Why does the channel up or down sometimes not work?
It sounds to me like you have a fault in the tuner circuit. I suggest you take it on for service.
Oct 23, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
How can I set the channel BACK to CH 3 from CH 4
1) Set your TV to channel 3.
2) Insert a pre-recorded tape into this unit.
3) Press the OUTPUT button on the DVD/VCR so that the VCR OUTPUT light is lit.
• If noise appears on the TV screen, press the VCR/TV button on the remote control.
4) Press the PLAY button once.
5) After a few seconds, press the PLAY button on the DVD/VCR for 3 seconds.
• The RF output channel will change to channel 3 from channel 4 and you will see a playback picture.
• When a picture does not appear on the TV screen, repeat step [4].
6) Press the STOP button to stop playback.
Nov 17, 2007 | Emerson EWD2004
New sony tv doesn't recognize cable channels
Normally the TV has to be connected to a set top box supplied by the cable company. The TV set usually needs to be tuned to channel three (or four) and kept at this setting. If an HTMI connection cable is used look for a button labled "input" on the TV remote and using the remote change the input selection to tch the HTMI input station you plugged it into .
Oct 06, 2014 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
Hitachi DV-PF 2U dvd player works fine when hooked directy to TV (channel 3) but won't work when connected through the new COX digital cable box. TV is set to channel 4, dvd player turned on, disc...
If the cable box needs to be set to 4, the TV will need to be set to 4 as well as the dvd player. The hookup should be cable box to dvd player to the TV for your system to work. Let me know if you have any other questions. Thanks.
Dec 30, 2010 | Hitachi DVD / VCR Combo
I don't know what channel the tv is supposed to be on
Hello, you set your TV for channel 3 or 4, if your combo has an out to TV RF connector(threaded connector) or you set the TV for video 1or video 2 if it has the RCA video/audio outs in the rear. If the TV has no auxiliary jacks you will need an RF converter, usually common in any electronics store(radio shack or similar).
Jul 22, 2010 | Durabrand DWT2704 TV
Phillips dvdplayervideorecorder connect w/zinwell converter box
First off get the TV on the right channel. It will either be ch3 or ch4. If you are using a cable box the dvd/vcr combo will have to be on ch3 or ch4 as well. OK, Make sure the input connector on the combo is hooked to the output connector of the cable box and the output connector of the combo is hooked to the input connector of the tv. Deal with one part at a time. First hook the combo to the tv and get the tv on the right channel (ch3 or ch4) so that you can see a pre-recorded dvd or video play. Then you will know what channel the tv is supposed to be on. When you find it don't bother the tv channel any more. Stop the dvd or video and hook up the cable box and turn on the cable box and set the box to a known good channel. Now put the combo on ch3 or ch4 with the combo's channel selector buttons until you see the cable box playing on the tv (remember you already set up the tv channel). Change channels on the box but don't bother the channels on the tv or combo anymore. You can put the box on whatever channel you want. The box will be your channel selector. I certainly hope that this helps. I know it can be confusing but don't give up. Just remember that the tv and combo have to always be on ch3 or ch4 (which ever one you found before). Good luck and thanks.
Nov 01, 2009 | Televison & Video
Sony RDR-VX535 I tried hooking it up to just a TV, no cable box or anything else. I put the 3-pin cable from the Sony's Output to my TV input (only has yellow and white on TV, no red). However, when I...
Red is Audio Right
White is Audio Left
Yellow is Video
You don't say what TV you have so it's impossible for me to guess what the connection it is that you are using. You will not see a signal on any of the channels you will need to select AV or Mode or Input or something similar on the TV
Jul 26, 2009 | Sony RDR-VX535 Player
Trying to watch vcr on channel 4, but the vcr is set to channel 3
You can watch the TV programs
with the tuner of the unit. (Usually
channel 3 or 4 of the TV is
available for the RF converter
setting.) Be sure to connect the
unit to a TV using the RF cable.
Select channel 3 on your TV.
Press [VIDEO/TV] on the remote
control.
• If noise appears, change the
RF output channel of the unit to
CH 4 by pressing [VIDEO/TV]
for 3 seconds. The RF output
channel will alternate between
CH3 and CH4
Nov 20, 2007 | Philips MWD2205 DVD Player/VCR
Setting up the chanel on the VCR
(FROM MANUAL)
RF Output Channel
1-Set TV to Channel 4
2-Insert a prerecoeded tape into the unit
3-Press Source until VCR light is lit
~ if noise is seen on TV screen, press (VCR/TV) on remote
4-Press play> once
5- After a few seconds, press and hold {Play>} on the unit for 3 seconds
~ The RF output channel will change to channel 4 from 3 and you will see a playback picture
~ When a picture does not appear on the TV screen, repeat step 4
6- Press (STOP) to stop plasyback
Sep 02, 2007 | Philips MWD2206 DVD Player/VCR
Televison & Video Logo
29 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
