Question about Kenmore Elite HE4 Electric Dryer
He 4 washer
My he 4 washer control board is dead
  • Anonymous Dec 13, 2007
    My Kenmore HE4 dryer doesn't go on. The timer shows but when I press the start button nothing happens. The "clean lint screen" showed up. The lint screen was cleaned realy good but it still won't start up. What is the problem?
    An expert who has written 2 tips or uploaded 1 video tip.
  • 62 Answers
Have you checked the vent and venting??? This is the most common. Past that it may have a problem with one of the sensors
Posted on Jan 02, 2008
Ge front load washer power button not working so I want to know how to check control board after it has been removed
You can;t check the board out of the machine. Inside the control panel area should be what GE calls a mini manual and wiring diagram. Should be test procedures in that paper work. It should tell you where to test for voltage if the board is completely dead. If you had power, the board can be put into a test mode to check all the different parts and cycles. Hopefully that sheet of paper is still inside the control panel.
Apr 11, 2015 | GE Energy Star WCVH6260F Front Load Washer
Both washer and dryer (MDG5500A) dead except for drum lights.
I am afraid there is no breaker or fuse inside the machines that will cause the control panels to go dead. You can check your power to the boards at L1 and neutral. If you have the proper voltage here but controls are dead, you will have to replace the control boards.
I notice in your problem heading it stops at the word except. Except what?
Nov 18, 2007 | Maytag Neptune MAH5500B Front Load Washer
No lights on control board, door locked, MAH9700
Unfortunately the control board is dead and will need to be replaced. Here is the board to order if you decide to order it.
The E2 error code was for a stuck button and it would require the control board to be replaced also.
Dec 08, 2012 | Maytag MAH9700AWM Neptune Front Load...
I have a 609 Intuitive washer that was dead. Controller fuse was blown, pump control FETs shorted out. Another smaller chip in pump control circuitry obviously dead (small crater in the top). Corrosion...
i just love these machines they are not the best but there great when they work correctly. ok yes the most common problem with the f/p washers is they blow there power control boards the reason why is this there is no power short protection in the pcb have you ever unplugged the washer lifted the lid and turned by hand the barrel and seen that the lights on the control light up it allows the capstan drive motor to reverse its poer back to the board when the washer spins too fast it imt/s too much power back to the pcb. your completly ok to fit the control board it wont burn out 32 ohms on the pump is great give it a little spray of wd-40 anti corosive oil spray now the impulse reader on the side of the barrel small circuit board that must be clean and free of water marks and dust rust e.t.c then the drive break will respond faster stopping pcb burn out do this every 6 months
merry christmas
sonic boom electronics australia
please take the time to rank this advice
Dec 24, 2010 | Fisher and Paykel GWL11 Top Load Washer
Power button beeps three times. Lock button works. Nothing else works.Technician diagnosed microcomputer control board. Replaced board control 8183258. Still dead!- he never called
Try to unplug power cord for 10 minutes and plug in. If you have manual on hand, follow instruction to find error code on your machine. Please tell problems before it went dead. Thanks.
Aug 10, 2010 | Whirlpool GHW9200L Front Load Washer
Washer fuse problem
There is a dead short on the control board. Cease using the washer and get it serviced.Constant blowing of fuses can damage other items connected to the same circuit.
Thanks for using FIXYA
Oct 12, 2009 | Washing Machines
NO power or dead control board with maytag washer mah9700aww
Are you getting power at the wall plug? Test it with a lamp or nitelite. GFI are made to protect people and need to be tested annualy by the button on the plug. You also have to reset it by the plug or circuit breaker. If the washer is on the same circuit as something else that uses high current it may too much current for the circuit. It use to be that we could not wash clothes and use the microwave so I moved the microwave.
Aug 12, 2009 | Maytag Washing Machines
Control board problem
please provide the brand and model number so I can help you..
Sep 22, 2008 | Washing Machines
Control board
have you the touch onsole first to se if it was ok there have been more problems with tha then the cpu board? do you get any beeps while touching it??
Aug 23, 2008 | Maytag Neptune MAH7500WH Front Load Washer
Kenmore Elite HE4 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
