Question about Kenmore Elite 45986 Front Load Washer
How to replace door lock on my kenmore elite washer he3
  • 5,911 Answers
The following link explains step-by-step how to replace the door latch on a Kenmore Elite HE3:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
This is a very simple repair. If you have questions, or require additional assistance, please let me know. I hope this helps you.
Posted on Sep 09, 2009
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
Kenmore elite he3
most front load washers and dryers have locks on the doors some have a bottom panel that u can remove to manually unlock door using the release before opening any machine please unplug machine from wall sometimes even unplugging it and waiting a few seconds will release door lock from itself
Feb 09, 2014 | Dryers
Kenmore he3 washer. power will come on but start button will not lock door and start.
The door lock must be faulty ..This is an very common problem ..Do you get any error code ? If so kindly let me the code...
Sep 20, 2010 | Kenmore Elite 45986 Front Load Washer
I cant get my kenmore elite he3 washer to start keep getting dl F error
Possible causes: (power off the mains first before checking)
Door lock mechanism is broken or removed from door.
Door switch/lock unit failure.
1. Check door switch/lock unit.
2. Check the wire harness connections of the door switch/lock unit to the Central Control Unit (CCU). The wires shd be secured well.
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
May 04, 2010 | Kenmore Elite 45986 Front Load Washer
He3 washer will not start. The lights on the
you probably broke the door switch and the machine thinks the door is open. little piece on top of the lock catch. need to change the door switch
Feb 05, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 front load washer door locking mechanism issue
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Aug 01, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My Kenmore Elite front loader HE3 washer will not start.
The door lock is not telling the control the door is locked. Faulty door switch or failed control or loose wire.Try pushing in on the door while it tries to start. Advanced trouble shooting may be required.
Eric
Jun 20, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore front load He3 washer: door wont unlock
happened to me once - I just unplugged the machine - waited a minute and plugged it back - it - then used cancel button
Feb 27, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he3 - door lock
If sound like a lid switch issue. Open the top of the washer to get an access to the lid switch(located near the doorframe). Look for a loose wire or a broken switch. In case there is no loose wire or broken switch, you should replace the switch. Good luck!
Sep 05, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
642 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
