Question about Fisher Paykel EcoSmart GWL15
Blowing 6.3 amp fuse on mother board on fisher pakel washer model GWL 15
aborcass
  • 2651 Answers
SOURCE: fisher & paykel washing machine fault codes
try removing hte screws from the rear of console and within the console usually is a techsheet with an explanation of hall hte major faults
Posted on Mar 12, 2008
SOURCE: Fisher pakel washer taking too long to wash clothes
How long does it take to fill the tub? if the water, on warm stteting, isn't blasting out fast or if, when set to cold, it's trickling out, your cold water valve is shot. I can help with this problem 'cause I had the same experiences you listed.
Posted on Oct 20, 2008
stephanos18
  • 144 Answers
SOURCE: fisher and paykel washer gwl 11 us
ok You have a blown Motor controller module. There could also be another fault that caused this to blow up. eg a faulty drain pump, lid lock or Diverter valve, inlet valve. you'd need to use a ohm meter to test all these. cheers
Posted on Mar 24, 2009
SOURCE: fisher paykel codes
There is a code book inside the top of the washer where the electronics are.
Posted on Apr 06, 2009
  • 15 Answers
SOURCE: We have a Fisher & Paykel Model GWL 15 washer. In
NEED TO KNOW WHERE YOU ARE LOCATED. WE ARE AN AUTHORIZED SERVICER AND CAN OBTAIN PARTS FOR YOU.
Posted on Apr 07, 2009
Fisher & paykel washer no power going to it
No reset button. There is a fuse it is soldered on & part of the main control board. They don't blow the fuse for no reason, so you need to be able to test & check everything to find out why the fuse blew (if it has) If you just replace the control board without checking then there is a good chance it may blow the new board as well. There will be no warranty on the board in that case. You really need to call a repair company who will test everything first.
Dec 27, 2015 | Fisher and Paykel Washing Machines
Where is the pump on my Fisher&Pakel GWL 11 AND HOW CAN I GET IT OFF TO CLEAN IT
Tilt your machine back on a 45deg, look up under machine to find pump
pull back on the white lever & turn anti clockwise to remove.
Jan 28, 2013 | Fisher and Paykel GWL11 Top Load Washer
My fisher&pakel gwl 11 wont drain/spin
Your motor controller board needs three 332k resistors replaced to make it spin again,Only on Series 11 Models
Jan 28, 2013 | Fisher and Paykel Washing Machines
Replace fisher paykel iwl 16 mother board with gwl 11 motherboard
I cannot find your mothers IWL16 model, but I have found various similar machines that are the same phase as your GWL11 machine, the electronics in there although different are compatible, you can swap the drain pumps, there almost universal, avoid the drive shaft machine, fix the other one If you want further help, post a photo of both pcb's (the electronics) After swapping your machine will stil require programming which is simple enough
Sep 14, 2012 | Fisher and Paykel GWL11 Top Load Washer
Model gwl 15 us not draining
find black rubber drain hose under machine and squeeze several times to loosen soap and hair gunk.
start the mahine on the rinse cycle. This should start the draining process.
Dec 08, 2010 | Fisher and Paykel Fisher & Paykel Washer
POWER UNIT IS NOT WORKING
sounds like the motor controller is faulty.if u have power to unit and the lights aren't on then it is either faulty controller, or faulty pump or best case broken power wire.please turn power off b4 u work on it. dont want any accidents. please reply 4 more help.
Apr 09, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykal GWL-11 won't advance through cycles. Could this be
maybe blocked drain pump can u hear a buzzing when it tries to drain water
Oct 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
Oct 13, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel EcoSmart GWL15 Logo
127 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
