Question about Star Logic 17" LCD Monitor
StarLogic- Out of range
I just switched my starLogic monitor to another computer in the house and it is hooked up properly but the message keeps blinking "out of Range"what can I do ?
  • 79 Answers
The computer needs its screen resolution reducing or changing in aspect ratio to suit the StarLogic monitor. Use a previously-working monitor and reduce the resolution on the computer to 1024 x 768 pixels or less (right-click an unused part of the desktop, click Properties and select Settings; slide the resolution slider to the left to adjust). The StarLogic monitor will now work; plug it in - do the resolution adjustment again as above, but increasing the resolution until you are happy. Going this way around, your computer will failsafe back to the previous (lower) resolution if the monitor says Out Of Range again, so you cannot lose the display along the way..
Posted on Sep 07, 2009
My Starlogic monitor fails to power up. We had a recent power outage. Everything else on the computer seems to work properly however when I power up the pc the monitor will not turn on. Have manually...
Not sure if you have done this so give this a try.
* If possible, plug your Starlogic monitor into another working computer. If the Starlogic monitor works then it is the port on the original computer that has gone bad. The solution would be purchasing a new video card such as PCI or AGP video card. (Assuming all other aspects of your PC are working fine)
*However, if the monitor does not work then you know your monitor is dead. You will need to buy a new or used monitor. **You may want to barrow someone's monitor and test your original computer just to make sure the port on that original computer is fine.
Jun 16, 2010 | Star Logic 17" LCD Monitor
Intstalled starlogic moniter to PC and got error message
the "Out of Range" message usually appears when the video card is putting out a video resolution or frequency that the monitor isn't able to handle. You should reboot your computer and BEFORE the Windows screen shows up, press the F8 button once every half-second. THis will bring up the boot menu for Windows. Select "Enable VGA Mode" and press enter. THis will load Windows in VGA mode where the screen resolution will be 800x600 @ 60Hz. Any modern monitor is able to use this. Once you log into Windows with the basic video settings, you can go into the Display properties within Windows and bump up your resolution and frequency as needed.
May 11, 2009 | Computers & Internet
How to covert Starlogic M17ANA into tv screen.
yes a dvi to VGA converter is available they are available online and over the counter at an electronics or computer store
Feb 05, 2009 | Star Logic 17" LCD Monitor
17'' monitor whte screen power light on
have a 17'' starlogic flatscreen monitor and i opened a game and it went to white screen and stayed there.
Jun 19, 2008 | Star Logic 17" LCD Monitor
Starlogic LCD Computer Monitor
I can't find a website for StarLogic anywhere, so either they have gone out of business (not likely as there should be some reference to them somewhere) or they are imported from a foreign manufacturer and rebranded with the StarLogic name.
May 13, 2008 | Star Logic 17" LCD Monitor
StarLogic monitor needs to be switched off digital signal.
Dear Carol,
You can check at rear of the the monitor.
Sometime they assmbled the switch at the back of the Monitor.
May be that the switch is located there.
Apr 11, 2008 | Computers & Internet
Problems with monitor
Are sure you plug into the right socket jack.
Try plugging different socket and listen.
Jan 19, 2008 | Star Logic 17" LCD Monitor
19" starlogic monitor
If you are getting a "No Signal" message, someone may have inadvertantly pressed the wrong button on the monitor. Use up arrow of button #5 below to cycle through RGB (normal VGA connection) and DVI sources. Down arrow will result in "No Signal" message.
There are five buttons at the bottom of the screen on this monitor. From the left:
1 - sound volume
2 - degausser
3 - power on/off
4 - monitor set-up
5 - RGB/DVI source
Nov 20, 2007 | Star Logic 17" LCD Monitor
Star Logic 17" LCD Monitor Logo
336 people viewed this question
Top Star Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
ray gallant
jd83854
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
