Question about Epson Stylus C46 InkJet Printer
When I switch my C46 on the red and green buttons are flashing
The button flash alternatively
The ink pads are at the end if their service life.
Depending on what type of printer you have:
Procedure 1 We found this procedure to work for the Stylus Photo 1270 type printer, and understand that it also works for the 870 range and even earlier models like the Stylus Color 740. The error is indicated on these printers by all four lights on the printer flashing. Even if you press the power switch on the printer, the lights continue to flash, and the printer does not turn off!
  1. Turn off your printer, ensuring that the print head is at it's home location and locked in place as normal;
  2. Power off the printer at the wall or by removing the power cable, for at least 20 seconds;
  3. When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer's power switch was 'on' - switch it off and return to step 1;
  4. Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down;
  5. When the paper-out LED flashes, release the buttons;
  6. Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button);
  7. The printer will now attempt to reset, including resetting the EEPROM memory and running a short (about 10 seconds) cleaning cycle.
Procedure 2
  2. Hold down the paper feed button only;
  3. Turn on the printer;
  4. As the paper feed light starts flashing, release the button;
  5. Immediately hold down the ink-drops button for some 10-20 seconds or until the printer springs into life;
  6. Allow printer to complete it's processing, then turn off for a few seconds, and back on again for a newly working printer!
Procedure 3 - for 1290 and possibly 890 printers 1290 printer with green (power / data) and red (ink / paper feed) lights flashing alternately:
  1. Switch off printer with panel switch;
  2. Switch off printer at mains switch - leave off for 20+ seconds;
  3. Hold down roll feed and sheet feed buttons;
  4. Switch on at mains;
  5. Switch on at printer panel;
  6. Continue to hold down roll and sheet feed buttons until both green and red lights flash together in synchronisation, not alternately;
  7. Switch printer off and then, after a few seconds, on again at mains switch;
  8. When red and green lights are both flashing in synchronisation, release the roll and sheet feed buttons;
  9. Press and hold down the ROLL FEED button (the one at the extreme left) and keep it down until the machine finishes whirring, cleaning etc and the green light comes on steady;
  10. Release the roll feed button and all should be well.
Mar 13, 2011 | Epson Office Equipment & Supplies
Have flashing lights from Green to Red with no
Sounds like a maintenace pad problem (every Epson printer has a different set of flashing lights to indicate this "Maintenacne request"- read this link: http://www.epson.com/cgi bin/Store/support/InkPadsForm.jsp
Jun 01, 2010 | Epson Stylus C46 InkJet Printer
Red and green lights are flashing alternatively and colour ink cartridge has run out. How do i change the cartridge?
Flashing alternately mean waste pad full. Reset using SSC utility or Adjusment program/resetter. But, you must replace cartridge before. Turn off printer, unlock carriage lock (left side of carriage at parking position). Move carriage by hand to replacement position. Replace ink tank. Reset using the resetter.
May 21, 2010 | Epson Stylus C46 InkJet Printer
The red and green light are flashing alternately and it won't print. What can I do?
Buried inside the Epson C46 is a usage counter. Mine was preset to 8300... when this was exceeded, I got the dreaded flashing lights. Go to http://www.fixyourownprinter.com/forums/printer/39038
for a full explanation (by Leonardo A. Palacios) of how to down load and use the printer reset program.
Good Luck
Paul A. Boothby
Dec 18, 2009 | Epson Stylus C46 InkJet Printer
Red and green lights flashing alternatively
Down load a program from Intenet. "SSCSERVICE"
Install to your computer.
Open the program
Select printer driver and install driver.
close the program. found a icon right-bottom corner.
click right button.
clear Protection counter.
Now enjoy ready to print your printer.
Thanks
Nov 29, 2009 | Epson Stylus C46 InkJet Printer
Epson C46 colour printer green and red lights are flashing....but
Basically your printer says that you need to replace the waste ink pads. If this happens for the first time to this printer you can just reset the counter using SSC Service Utility (http://www.ssclg.com/epson.shtml) or if it happened more than once you shoul first replace the ink pads and then reset the counter or the printer may overflow. That's it.
Jun 15, 2009 | Epson Stylus C46 InkJet Printer
My C46 suddendly stopped working.
It is error of waste ink tank.
You can find a lot of utilities in internet to reset this situation
Mar 07, 2009 | Epson Stylus C46 InkJet Printer
Flashing lights
Dear , friend
Please replace cartridge
Jul 08, 2008 | Epson Stylus C46 InkJet Printer
Problem with my printer
well first here http://emeasupport.epson-europe.com/downloads.aspx?LNG=EN-EU&Search=1&data=1bANIZf8BRVoS83cS1PVis/kIVxbLcWZ9JD5vhjblgJTVeIjQGvfyu2+tOhzwN03 for more info & your drivers but what you need is new ink cartages
May 25, 2006 | Epson Stylus C46 InkJet Printer
Epson Stylus C46 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
