Question about Maytag Atlantis MDE7400AY Electric Dryer
Dryer fins coming loose
I have the exact same problem. On eof my fins has come completely off. The fins are attached with two screws but I can't for the life of me figure out how you screw them back on to the drum of the dryer.
  • 304 Answers
Unplug Unit.
Refer to pages 5-2 and 5-3 of the manual below to see how to expose the drum by lifting the top of the machine. Then turn drum very slowly and only until the screw holes for the missing fins are within your reach. Most of these dryers have two sizes of fins make sure you order the right one if you need to replace them.
Good Luck
Download this file : Maytag Dryer
Posted on Sep 07, 2009
Fin that tumbles clothing inside dryer coming loose, how can I tighten it?
These fins are usually screwed on from the outside of the drum. If you're up to it this is a simple but time consuming fix. Take the cabinet off the front of the dryer, the top will come off as well. be careful of the wires from the control console, they will stay attached to the dryer. Tighten the tumbler fins on the drum and then re-assemble the cabinet. Typically the screws you need to access are the same used for the door latch and hinges. They go back together easy ........
Feb 14, 2011 | Maytag Neptune MDE7500AY Electric Dryer
Inside the dryer there are 3 bars that stick out to help tumble the clothes. One of them has come loose and I'm not sure how to tighten it. It appears to be attached with screws that come thru the drum...
With the front off look up in the top left and right corners for some screws that hold the top of the dryer to the side panels. Depending on your model, there can be different styles. The old maytags used 3/8 in screws up inside the corners and the newer models had 5/16 screws right up front.
Once you get the front of the top loose you will be able to lift it like the hood on a car to gain access to the drum.
Rotate the drum by hand to put your loose fin at the top and tighten up your screws. Sometimes the screws will round out the holes on the drum too much and you may want to put a washer on the screw to secure it better.
Oct 07, 2010 | Maytag Dryers
Fin on gas dryer loose.
The model number is generally inside the door or door jamb area. The top must be removed to access the drum to tighten the screws to the fin
Apr 15, 2010 | Maytag SDG4606A Gas Dryer
Two of the three internal fins in the dryer came loose and detached from the inside of the dryer. Now the dryer is losing heat where the installation holes are located. Can I purchase new fins and install...
if you open the dryer by removing the top and front panel/door assy you can look at the bottom of the unit and find the old screws, buy the new fins, and re attach them if the holes in the dryer where the screws attach to the fins are too large for the screws use some washers
Jan 06, 2010 | Maytag Dryers
Loose fin
there are two clips located between the front part in the frontpush those clips in and lift it up rest it back out of the way some of the dryers have small bolts holdind the fins on if so tighten them up and some dryers have only push in plasic clips these fins have to be replaced i certainly hope that i was able to help you and by the way close the lid, thank you.
Dec 23, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
The fin on the Neptune Dryer has come loose and I need to remove the side panel on the dryer to replace the two screws that hold one of the three fins in place. It would be simple if I knew exactly how to...
Remove the 2 screws holding the door and the 2 screws on the other side of the door opening . Pull the front panel foreward and lift off . If still not enough room to reach under to tighten , remove the 2 screws (1 on each side , holding the top down , then lift top . DISCONNECT POWER BEFORE DOING ANY WORK .
Aug 18, 2009 | Maytag Neptune MDE5500AY Electric Dryer
MDE7600AYW Atlantis Dryer -paddle inside dryer is coming loose
You will need to take the back panel off use a 1/4 in socket driver.Then you should see the drum.
Len
Feb 21, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
FIn inside neptune md55 dryer came loose need to remove side pane
I had the same problem but it's the FRONT Panel you need to remove. Before you start, unplug the thing first. BTW I did the whole proceedure in 10 minutes using an electric screwdiver / philips bit and a socket set with an 8mm socket with my leg in a cast. You can do better, I'm confident!
Two 8mm hex head bolts hold each fin on the drum. They can be tightened. You need to open the dryer front since they bolt from the outside of the drum. To open the dryer front you first take the door off by removing the two philips head screws, then slightly lift the door and pull toward you (the door hinges have little hooks on the end that inserts into the slots (this little design keeps the door from falling off during removal and install-nice). Then remove the two philips screws on the other side of the door opening (opposite the door hinges). These screws hold two plastic brackets (be sure to see how they are aligned before you remove them so you know how they go back on.
Now the front frame panel looks like an "H" . Grab the top two arms of the 'H" and give a quick ****. The top arms of the 'H" will come loose. The bottom part is held by a couple of clips, just pull up and the front panel comes off.
You will be able to spin the drum until the hex bolts for the fin(s) in question are visable / reachable from the right side (just above the heater unit-hope you unplugged the dryer earlier). I tightened it using an 8 mm socket.
Now reverse your steps: put the front panel back on the bottom clips and snap the top "H" arms back in place. Reinstall the plastic clips / screws and then put the door back on.
Feb 15, 2009 | Maytag Neptune MDE5500AY Electric Dryer
DRYER FIN IN DRUM IS COMING LOOSE
Unplug the dryer, remove the door hinge screws that go into the cabinet and the two screws on the opposite side of the door opening, then the front panel can be removedby starting at the top. Once the front is off, there are two screws, one to each side that hold the top on, remove these and raise the top. You can rotate the drum by hand and the baffles are held on by the screws on the outside of the drum. Reassemble in reverse order.
Jan 06, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Loose Tumbler Fin In dryer
most maytag dryers have push type clips that hold the top to the front. look between the top and front with a light and find them about 3-4 inches from the outer edges. once you get the top up then there will be screws that hold the drum baffles to the drum. just put a new screw in them and all will be ok. no need to replace them, just use new screws.
Dec 31, 2008 | Maytag HYE3658AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
302 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
