Question about Car Audio & Video
I installed a scosche 500k micro farad capacitor in my truck. i have a 800w sony explode running a volvonhag 12" sub, the doors are run by a rockford 40i amp. sounds great till capacitor hook up. amp cuts out after a few seconds. i have it hooked up in line w/ my 12+ but there is a power distrubution block splitting the 12v power between the amps.it is grounded back to another block grounding both amps which is grounded to body of truck.so problem:turn on stereo it plays real low, speakers cut in and out then amps fail???
You need to put the capacitor after the in line fuse/ distributor block. Because you are putting it on only your subs you are running it into fail because of a negatuve ground loop which is why they play low then cut out. Also check your grounds for both amps after rewiring and make sure they are tight.
Posted on Jan 25, 2010
How to wire a 12inch 4ohm dvc sub to 2ohm
Take two wires, equal length. Reach from positive of 1 coil and hook too positive of 2nd coil, now do the same with negative, neg to neg.. Then pos of sub to amp. And neg of sub too amp.
Jan 03, 2013 | Rockford Fosgate T1d212 12" Power T1 2-ohm...
How do you hook up scosche 500k micro farad digital stiffening capacitor? Read more: http://wiki.answers.com/Q/How_do_you_hook_up_scosche_500k_micro_farad_digital_stiffening_capacitor
you hook it up like a battery. positive to positive supply, and negative to negative supply, or ground. it may require a remote turn-on from a head unit, if there is a digital display on it. usually, it is the tiny screw, that looks like it holds the plastic cover on.
Aug 31, 2012 | Car Audio & Video
I have two 12 inch rockford p1 punches powered by an 800 watt sony explode amp (2 Channel) and i want to install another 15 inch kicker with a 1200 watt amp not sure the model, i got it from a friend and...
I have a similar setup & I just run the second amp straight off the other amp by running positive & remote wires directly from 1 amps positive & remote inputs to the others amps inputs. But my head unit has RCA inputs, (sub in & front & rear inputs) so from my 4 channel amp I run 2 6 inch alpine S's to the front to the front RCA inputs of the head unit, & 2 Pioneer 440w 6x9 inch speakers to the rear inputs. & my 800w 12 inch sub from my 2 channel amp to the sub woofer inputs on the head unit. Has blown my eardrums for nearly 12 months now great stuff! Hope this has helped
Mar 12, 2010 | Sony Car Audio & Video
Describe how to connect a scosche 500k micro farad
Put the capactior in parallel with your battery right before the amplifier. So Postive lead of cap to your 12 Volt line and negative lead goes to ground. It is also suggested that you charge the cap before placing it directly in parallel with the 12 volt rail. yo ucan do this by using a 1000 ohm resistor with a power rating of 1 watt. Disconnect your amplifiers so it is just your cap and battery. Replace the fuse with the 1000 ohm resistor. Once the resistor is in place hook up your cap. It will take a little bit for it to charge. RC time constant is T = Reistance X Capacitance. So 1000 ohms X .5 Farads = is about 8 minutes, or you can just measure the voltage with an volt meter and when the cap reads 12VDC you can then hook it up. BE CAREFUL NOT TO SHORT TERMINALS. THIS CAPACITOR I STORING A LOT OF CHARGE.
Jan 26, 2010 | Car Audio & Video
Looking for a diagram so i can see how to install the installing scosche 500k micro farad and do i have to sauder it.
ok this is an easy one first make sure u have all your wires ran through the car connect a ground to the negative side of the cap then run 12 v power wire and use another piece of power to connect to your amp
Sep 29, 2009 | Rockford Fosgate Car Audio & Video
I trickle charged a new scosche 500k micro farad capacitor and when i hooked it to my trucks system it threw my amps into protection. so i replced both subs and got rid of cap.now the cd reciever plays but...
do the rca's work and does the speakers work on the radio. if the rca's don't work the rca's do have a fuse inside right next to the rca's on the circuit board. it is a small black rectangle soldered on both sides and has the letter f on it. if no sound comes from the speakers on the doors the output on the radio is probably damaged. the item number of the part is tda 7856
Sep 08, 2009 | Sony Car Audio & Video
Rockford fosgate amp keeps shutting down when volume is cranked
your cd player cant handle all the power, time to upgrade to a cd player with at least 80w10
Jun 12, 2009 | Rockford Fosgate Punch P5002 Car Audio...
Reconnecting two amplifiers adn farad capacitor
run a fused + wire from your battery to the + of the cap ground the - of the cap to a good grounding place on your car run a wire from the + of the cap into a one in two out disburtion block make sre it is a fesud one.then run one wire from each or the two out side of the dis block to each amp then ground both amps to a good ground.what type of amps do you have
Mar 19, 2009 | Kenwood Car Audio & Video
Amp stoped working
You need to run a larger power/ground cable. If you are reading low, you are not getting the kind of voltage that the amplifier requires to run, you may have been fine before adding the other products but if you wired them all to the same power wire (say an 8 gauge) you'd encounter problems. You should probably use a 2 gauge or at least a 4 gauge power kit.
Jul 09, 2008 | Pioneer 250WX1 360X1 800W MAX CAR AMP Car...
Head unit
If the display goes out then it is possible the flex cable is broken. Return it to Rockford for repairs.
Jun 19, 2007 | Rockford Fosgate RAV DVD1 Car DVD Player
Car Audio & Video Logo
863 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
