Hello i have a zanussi fl-1850,it has stopped spinning all of a sudden.i have looked and the belt is still attached and dont know what else.....HELP!
  • 15,935 Answers
It appears your motor/motor controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
Left screws in the back of new Zanussi washing now it wont spin
It must have broken some plastic off inside or may have jammed the belt mechanism. Check the belt and suspension/mounting.
Jan 16, 2014 | Zanussi Washing Machines
I transported my newly given to me by my dad tristar from Fl to LA and I can't get the reset button to start the power. The vacuum comes on, but the rug attachment is not spinning I can't get
If the rug attachment is not spinning, it is likely the drive belt has come off. Also, the entire intake area probably needs to be cleaned.
If the vacuum cleaner starts, the reset button has nothing to do with why the attachment doesn't spin.
Sep 12, 2012 | Tristar Vacuums
How do you change the belt on a zanussi nexus fl 1082.iv got the top off and tryed to slip my hands down the back of machine to attach the belt to the motor and wheel,but just cant get the last bit on,and...
With the help of someone, tilt the washer forwards towards you, this will give you more room to get your hands inside to fit the belt, it is awkard, but can be done, I have done it this thay on many occasions, otherwise, it entails removing the rear half of the cabinet, not an easy job!!!!!¬.
Good luck.
Oct 12, 2010 | Zanussi FLA1101W Front Load Washer
The drum for our Zanussi TC7103 has stopped spinning
sounds like a new drive belt is required. pull the machine out remove the mains supply!!!!
remove the top and look into the back of the machineif you cant see the belt them remove the back of the machine, it's like a small fan felt from a car it's either come off or disintegrated in which case you'll need a new one.
Nov 09, 2009 | Dryers
DRUM NOT SPINNPNG CAN HEAR MOTOR RUNNING
Hi
You need to pull the machine out from the wall and remove the back panel. This will give you access to the belt drives. It sounds as if the belt has either snapped or slipped off the pulleys. Be aware you may also have a bearing problem on the motor which has caused the belt to come off in the first place.
Hope this helps.
Jul 12, 2009 | Washing Machines
WONT SPIN
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
May 10, 2008 | Zanussi FLE1416W Front Load Washer
No spin
Your problem is that the carbon brushes on the motor have worn out and need replacing.. eaisly done
Dec 10, 2007 | Zanussi FJS1225W Front Load Washer
My washer wont spin
on the motor there are what you call carbon brushes.. these wear out over time, this then the motor stop spining check and get back to me . cheers doc
Nov 20, 2007 | Zanussi FS1455W Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
