Question about Gateway 310 XL (310XLSP) PC Desktop
I want to install 1GB of memory. I need step by step directions
    President:
  • 1,996 Answers
If you go to the Gateway support site and enter your serial number, found on the case by the optical drive, you can get instructions specific to your model. See here for example.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Sep 07, 2009
  • 241 Answers
0. Buy the proper RAM card for your PC. If you don't know how to do this, you probably shouldn't be digging into your PC. Get someone knowledgeable to help you.
1. Turn off the PC.
2. Open the case and find the existing memory card slots.
3. Install your new RAM card into an unused slot, noting any notches in the edge of the card which must align with bumps in the slot. The RAM cards simply press into the slots and there are white clips at the edges of the slots that snap into the RAM card to hold them in the slots. You might need to move the clips away from the slots to allow insertion of the RAM cards. Then press firmly (remembering to check for alignment notches and bumps as noted above) until the card pushes into the slot and the clips pop into locking position.
4. The computer will probably automatically configure the new RAM or it may ask you to go into "Setup" to configure it. If so, just press the key suggested, look at the settings, and then "save and exit". All done.
    President:
  • 2,666 Answers
Remove side of PC (left hand as you look from front) locate memory slots, make sure retaining clips are open, insert memory (correct way up) with firm pressure but do not force. Retaining clips will automatically click home. Replace side of PC.
Sony 1GB Memory Stick PRO Duo Memory Card "full"
You can try recovery tool to see whether your memory card corrupted or not. For example, 4Card Recovery, which is able to recover various files in a few minutes.
Step one, download 4Card Recovery online and install it on your computer.
Step two, run it and choose the files that you want to recover, of course, you can choose recover all files in case of the omission of anything.
Step three, scan it by clicking the 'next' button and wait for about ten minutes.
Step four, save the recovered files on other part to avoid losing it again.
Hope you can solve the problem with this. Have a try.
How to Recover Photos Videos off SD Card after Formatting Unformat SD...
Dec 22, 2012 | Sony 1GB Memory Stick PRO Duo Memory Card
EMachines T3304 won't work with 2GB memory
might not be a working pair
are the memory modules of the same brand and type
IE: hynex ddr3 low density
if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
hope it helps
Jun 21, 2012 | eMachines Emachine T3304 Amd Sempron 3300...
I recently purchased Two PNY 1Gb ram to upgrade from original 512mb. When I put both 1Gb ram in the slots, the computer will not boot up. When I take one out and put the original 512 back in with the other...
I don't know your specific model, but some of the Emachines had some memory directly on the motherboard. With the 1Gb and 512Mb sticks installed, boot the machine and report how much memory the system sees. Perhaps the onboard memory is causing you to exceed the 2Gb limit.
Please post the memory size you get here with the above sticks.
Thanks,
Dan
May 12, 2011 | E-Machines W6409 (7234) PC Desktop
How do I install a Dell 1GB Memory chip?
***NOTE**
If this PC is still under warranty opening the case will void it
For an illustrated guide look here
http://www.ehow.com/how_895_install-ram.html
Jul 04, 2009 | Chips Computers & Internet
Gigabyte GA-8VM800PMD-775 @ 1.5gb memory
This is the website link for your board on gigabyte website. http://www.gigabyte.com.tw/Products/Motherboard/Products_Spec.aspx?ClassValue=Motherboard&ProductID=2159&ProductName=GA-8VM800PMD-775 Suggest you have a faulty piece of ram or a clock speed miss-match. your board supports up to 2gb of memory.Try also reseating the memory. Let me know how you get on? chris http://www.motherboardsrus.net
Jun 06, 2009 | Gigabyte GA-8VM800PMD-775 Motherboard
How do you remove and replace dell laptop memory? (d600)
I dont know this particular model, but usually it's underneath the computer, there is one screw to remove and you can take out a door which gives you acess to the memory slots. If it's not there, you will need to remove the top cover to get there. But it's most likely a small door underneath the laptop.
Jun 03, 2009 | Dell Latitude D600 Notebook
Not totally hung-up but lag during gamming
you have far too low system memory..... modern games use huge amounts of system mem as for your system, widows itself is taking up most of your 1Gb memory let alone any Anti Virus / firewall software installed
a quick mem upgrade should help as a first step.
Apr 23, 2009 | ASUS P5PE-VM Motherboard
Upgrade Sony VGN-S580 to 2GB memory
flip the notebook upside down and disconnect the power adoptor and remove the battery from the notebook and you will have a flap showing a rectangle shape open that flap and hold the memory in45deg in the slot and press the memory in and it will get lock in the slot
Mar 12, 2009 | Sony VAIO VGN-S580P Notebook
Installation of 1gb on my laptop
hi, installing memory is so easy. you can do it in a breeze.
here is a link hope this helps:
http://www.computerlaptopmemory.com/installing_laptop_memory.html
Sep 25, 2008 | Compaq Computers & Internet
RAM problem
Hello, if you have an intel m processor for your sony then u are somewaht out of luck. the base memory is 256 megs and it is not in the motherboard but rather integrated in one of the slots itself, that means if u put a 512 mb chip into that certain slot it will only read 256. a lot of people are mislead into thinking they can put two 512s and get a gig of memory, but not true, at least not with most of the sony intel processors. find the base slot by switching chips around, then leave the 256mb chip there. then u can add a 512mb to the expandable slot and get over 700bytes. if u can find a 1gb compatible stick,then try that the same way, leave the original hynix base slot chip in and add the 1gb, if u can find one, then u will have a little over 1280 of which u can up the video graphic usage up to 128 in the bios, and have your 1gb in memory. if u find a 1gb memory chip that work,drop a line as to what brand and size u used
Jun 22, 2008 | Sony VAIO K45 Notebook
Gateway 310 XL (310XLSP) PC Desktop Logo
65 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
