Question about Samsung SGH-D900 Cellular Phone
Samsung tv shuts off randomly somettimes as many as 3 or 4 times with in 5 to 10 minutes. tv is about 4 year old
My Samsung 46 inch LN550j1fxza LCD TV turns on and plays sometime but then shuts back off with no sound, black screen and won't come back on until it's off for a while. thank you
Samsung 46" LCD TV (LNT4665F) turns off and on over again - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About 3-4 months ago, my TV would start turning off and on a few times at startup ... Samsung 46" LCD TV (LNT4665F) turns off and on over again ...chirp would sound and then it would power off and the cycle would continue. ... After 5-10 minutes of this without being able to shut it off completely, I pulled out the power cord. Samsung UN55B8500 - turns off by itself! - Forums - CNET
Nov 16, 2011
Samsung LN46A650 green/pink static picture and power resets ...
Jul 27, 2010
More results from www.cnet.com
How to fix clicking samsung tv (wont turn on) - Instructables
www.instructables.com/.../How-to-fix-clicking-samsung-tv-...
Instructablesif your looking at this then you probably have a samsung tv thats broken. This instructable is for how to fix one of the most common faults in samsung LCD tvs. .....its fine and never goes off until it is shut off but will not turn on immediately . ... The issue with my LN46A650A1F just started happening last weekend (12/7/2014).
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ON AND OFF Repairing Samsung LCD No power problem LN ... LCD No power problem LN MODEL LN46B500 - buy the cap kit for your tv model ...
Jan 05, 2016 | Samsung Televison & Video
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
At just over 1 year old and out of warranty, my Samsung 52'' LCD will not turn on. You can hear the relay click on/off/on/off, getting slower, until it will turn on after about 8 minutes. The firmware has...
Same problem on my friends Samsung LN52A650A. Never did the firmware update cause that refers to a random shut-off problem. I replaced (2) 1000 10 volt caps next to a heat sink with 1000s rated at 35 volts @105 degrees C. The tops on his were a little swollen and you had to really look close. The caps were 2 0f 4 inline caps. They were the smaller 2. TV works.
Jan 02, 2010 | Samsung LN52A650A LCD TV
Shut off tv on its own
Look into getting a new Power Supply Board. There is a good chance that you have 1 or more faulty capacitors on the PSB.
Apr 03, 2009 | Samsung HLN5065W 50" Rear Projection...
TV Shuts Off randomly
Our flat panel TV would shut off for 5 to 10 seconds and then come back on. We found out that our Comcast HD box was bad. After a tech replaced the bad box with a good box the problem went away.
Jan 20, 2009 | Televison & Video
Intermittent shut off
20 years is too long and the components ternmial might be loose or crack at this time, I'll susgest you look for any dry cold solder on the main board and do resoldering to the components terminal.
Nov 30, 2008 | Fisher PC-25R20 25" TV
Low output
The grill is not staying lite and not heating up like it should.
Jul 03, 2008 | Kenmore 774 sq. in. Cooking Area Gas Grill...
Samsung DLP HL-P4663W
could be the lamp, and is about time for a new one
http://fixyourdlp.com/blog/?cat=4
Jan 15, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung SGH-D900 Cellular Phone Logo
122 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
