Question about Craftsman Garden
I have a Craftsman 17 Bushwacker gasoline hedge trimmer. I want to see a diagram showing the gas lines coming from and going back to the tank.
3 Suggested Answers
  • 398 Answers
SOURCE: Craftsman gas hedge trimmer
yes the throttle isnt giving enough gas. there should be two screws side by side somewere near the trigger next to the cable that moves when you pull the trigger. play around withthose screw a few hours youll get it.
Posted on Feb 26, 2009
SOURCE: sharpen hedge trimmer blade??
My trick is to make sure that I always lube the blades after each session with a 3/4 engine oil + 1/4 kerosene mix - making sure that every tooth gets a drops or 2, then run it for a seconds to spread the oil & leave the blades overlapping. Doing this allows the blades to self sharpen I've found. 2 stroke oil , unmixed is about the perfect viscosity aswell.
Posted on Feb 18, 2010
How do I change the fuel line on a craftsman bushwacker
Videos are so easy to learn from.
Fuel line and fuel filter are located IN the gas tank.
Take a look here...
May 17, 2015 | Craftsman Garden
How do the fuel lines in a weedeater trimmer pe550 hook up inside the gas tank
I have an older model that has a weighted filter in the tank. The filter flops around and can 'fall' into the fuel no matter which way you tilt the trimmer/tank. You should have one in your tank. Feed in the new line and make the end come out the gas cap. Push the filter/weight into the end of the fuel line. Pull the extra fuel line out of the tank to match the original position. You should have cut the new line to approximately the proper or same length as the old fuel line with an angle cut so you could push it into the tank.
Jul 23, 2014 | Poulan Craftsman/poulan/weedeater Fuel...
HOW DO YOU SHARPPEN BLADES ON ELECTRIC HEDGE TRIMMER BUSHWACKER?
proper method is to use what is referred to as a "lapping table" professional sharpening shops have these , look in your yellow pages for scissor sharpening , but if your a skilled hand and have some time then a simple fine file will work as well , keep same angles on cutting edges ,approx. 30 degree angle
Jun 17, 2014 | Craftsman Bushwacker Bush/hedge Trimmer...
Why does my craftsman bushwacker hedge trimmers not go fast when I have it full throttle?
if engines stumbling when at full throttle , ck to see that your getting full fuel flow ( lots of bubbles in primer bulb are a sure sign of not a good flow) , locate the fuel filter inside fuel tank , ck it for a dark color ? if so replace it , also try adding some normal car fuel system cleaner to your fuel next time u run it for a few minutes , this helps to loosen stuck deposits inside the carb
May 27, 2014 | Craftsman 22" Gas Hedge Trimmer
Blade on a Craftsman 20 in bushwacker electric hedge trimmer stuck on a vine and will not engage
with engine off ! use a pocket knife to whittle wood branch out of bar , do not yank it off the bush the blade will bend then will become stuck
Mar 10, 2013 | Craftsman 20 in. Hedge Trimmer
I have a Craftsman's Gasoline Weedwacker model 358.791580. The weedwacker wouldn't start after priming and choking. I observed the fuel filter inside the gas tank unattached because the fuel l
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, oo
Jan 18, 2012 | Garden
I have an 18" Craftsman Bushwacker hedge trimmer
The wire into the handle may have been pulled and come loose. You will have to take the handle apart to check. They are simple.
Sep 28, 2017 | Craftsman Garden
Repairing fuel line on craftsman 32cc weed trimmer.
Cut the end of the line at a sharp angle. Spray WD-40 on the line and fuel tank hole. Slowly screw the line in the tank far enough so you can connect the fuel filter if you are replacing that line. If not just push the line into the tank if you have a two line system. Remember on the fuel primer, the long tip has the line going to the tank, and the short tip has the fuel line going to the carb.
Aug 24, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
464 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
