Question about Nokia 5800 XpressMusic Smartphone
Phone turns it's self off then straight back on, then when trying to create a new msg it goes back to the menu, it won't let me send or recive any msgs or data, any ideas??
How do i change my apn settings on my eternity so i can use the straight talk network
From the main screen of your phone open you menu, then messaging, then messaging settings, then multimedia message, then MMS profiles. from there create a new profile and fill in these settings:
Set Name: Straight Talk
Access Name: att.mvno
Auth Type: Normal
User ID: *leave blank*
Password: *leave blank*
Protocol: HTTP
Home URL: http://mmsc.cingular.com
Proxy Address: proxy.mvno.tracfone.com:80
Linger Time: 300
*leave advanced settings alone*
Save your profile and select it using the square on the right of the screen. You should now beable to recive multi-media text messages. Exit out to your phone main screen.
Press menu, then Media Net, then Browser Settings, then Browser Profiles, then select the profile named straight talk by pressing the square on the right side of the screen. You should then be all setup to use all forms of data and messaging on your new Straight Talk plan. I hope this was helpful!
May 02, 2012 | Samsung Eternity Cell Phone
How to activate & send mms in samsung s8000 mobile
you need to configure the mms settings from your internet menu... but you need the right configuration from your network provider to the settings..
to give you an idea, here's how you may do it.. from your phone, press menu select internet select browser profiles to lead you to internet profile settings.. from your settings, press create.  then create the mms profile your network preferred.  once created, press save and exit the settings for internet profiles..
to make the mms profiles be the default settings for your mms, do thes steps... from your phone, press menu select settings select phone applications select messages select multimedia from multimedia menu, select profiles assign the mms profiles you created for your multimedia. press save and exit the setup...
now to check if it's working, try sending a multimedia message to your own number to check if your phone can send and receive mms. once you successfully send it and received it, it means that your phone mms is already set and working...
take care..
Mar 30, 2010 | Samsung Jet S8000 Cell Phone
How do I enable predictive text on my sony
The usual way for most phones is to start to create a new message and hold down the hash key (#-find under number 9), this will usually switch predictive texteing. Or start a new msg, open up menu options and search for T9 or predicitive texting in there.
Jul 15, 2009 | Sony Ericsson T303 Mobile Phone (Shadow...
Cant send or recive mms on my sidekick 3
first before you can send a multi media msg. you must turn on the gprs of your phone and both phone have gprs active to send and recieve multi media msg
Jun 20, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Can't send a Text Msg on my Razor
go to create message then select the format:
New Short Message
New MMS Message
MMS Templates
Send to online album.
Start with the first option,then you do a little more exploring with the different formats.
Mar 03, 2009 | Motorola Mobility RAZR V3
When sending a text msg, it goes to outbox, wont send
I had the same problem and I read on down and saw someone's phone was stuck in flight mode. I remembered that for some reason, my phone was in flight mode the other day, so I went in and took it off. I realized the problem had been since that time. So, I put the phone back in flight mode and was able to delete the message from my outbox. I put it back in normal mode and now I can send texts. Yes!!!!
Nov 29, 2008 | Sony Ericsson w580i Cellular Phone
I can't send any message or recive
How can I use the messaging features on my Motorola phone? space.gif space.gif answer.gif To send a text message:
  • Enter your Message menu
  • Scroll to Create Message and Select
  • In the To: field, either enter a telephone number**, e-mail address**, or Browse your Phonebook, Received or Dialed Calls list.
  • Enter your message in the MSG: field
  • Select done when you have completed the To: and MSG: fields
  • Confirm that you would like to send the message now
Please note that text messaging is a service provided by your cellular service provider and you must subscribe to this service to have the capability to send text messages. Certain carriers may require alternate instructions.
**Please contact your carrier for further information on these services, and to ensure they support sending to both a telephone number and/or e-mail address.
To send a text message - Select Menu, Messages, Create Message, and then New TXT Msg
<a href=""http://motorola.custhelp.com/cgi-bin/motorola.cfg/php/enduser/std_adp.php?p_sid=Id42qGph&p_lva=4061&p_faqid=4064"" target=""_self"">To send a multimedia message -Select M, Messages, Create Message, and then New PIX Msg
To Insert Objects In Text Message while composing a text message - Select Menu, and then Insert
To use MMS Template open an MMS template with preloaded media - Select M, Messages, Create Message, and then PIX Templates
To read a new text or multimedia message that you have received - Press Read (Right Soft Key).
To Store Message Objects - Go to a multimedia message slide, or highlight an object in a letterand select Menu, and then Store
To send or create a quick note message - Select Menu, Messages, and then Quick Notes
To view sent messages - Select Menu, Messages, and then Outbox
To read received messages - Select Menu, Messages, and then Inbox
Tip: Press Menu to perform various operations on the message.
To view messages saved in drafts folder - Select Menu, Messages, and then Drafts
To delete all messages or only messages from the Outbox or drafts folder: Select Menu,; Messages, and then Cleanup Messages
Oct 22, 2008 | Motorola Mobility RAZR V3
Texting a picture
take a picture normally. save it to phone. then go into text msg then hit menu and you should see something to add a file.
May 07, 2008 | Samsung SGH-D600 Cellular Phone
Help!
Your phone ran out of memory and the only way the messages could be sent or received is through mms on the phone. You need to clear out the in and out box often so the phone will not do this. Also you must reboot the phone after you have cleared out the in and out box. Then it should work.
Feb 09, 2008 | Motorola Mobility RAZR V3
Nokia 5800 XpressMusic Smartphone Logo
79 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
