Remove the cover after pulling the power plug. Check the transformer and large capacitor for signs of overheating. If they look ok, then remove the sheet metal wave-guide from the area where the energy enters the cooking cavity. Under the wave guide is a fan-like device called a stirrer that has a plastic bearing. This stirrer bearing is commonly arced over (when the oven is operated with nothing to heat in it). Usually the bearing looks good, but has arced internally. Replace the stirrer as a unit. The machine can be operated with the case off and a cup of water for a load, but keep you hands clear. Look for smoke.
Was this helpful?
Yes
No
Popular Solutions for Panasonic NN-H504WF 1200 Watts
the microwave turn on ok fan works but not heating food all buttons work but there's a heat blinking...
(More)
the microwave turn on ok fan works but not heating food all buttons work but there's a heat blinking indicator not lit up on display
I have a Panasonic Genius 1200W which still has power to the front panel, but when you try to cook...
(More)
I have a Panasonic Genius 1200W which still has power to the front panel, but when you try to cook something, it appears to operate but cuts out after three seconds and does not heat anything during that time. Thnaks
the microwave continues with light on and turntable turning despite the time running out and...
(More)
the microwave continues with light on and turntable turning despite the time running out and pressing reset etc.
