Question about RCA D44LPW134 44" HDTV
RCA PROJECTION TV MODEL #D44LPW134 NO SCREEN OR SOUND
I HAVE AN RCA 44 IN.PROJECTION HDTV MODEL #D44LPW134, (NO SCREEN, NO AUDIO) WHEN I PUSH THE POWER BUTTON IT MAKES A CLICKING SOUND A FEW TIMES THEN THE POWER LED LIGHT FLASHES 10 TIMES, PAUSES, FLASHES ONCE, PAUSES AND REPEATES THIS CYCLE A COUPLE TIMES THEN POWERS OFF. ANY INFO ON THIS? THANKS
  • jess_trujill Sep 07, 2009
    THANKS, BEFORE I GET STARTED I WANT TO CLARIFY THE NUMBER OF FLASHES THE POWER BUTTON MAKES. IT FLASHES 1 INTERMITTENT THEN 10 RAPID FLASHES. WOULD THIS MAKE ANY DIFFERENCE FROM 9 RAPID FLASHES AND 1 INTERMITTENT FLASH? JUST WANT TO MAKE SURE. THANKS AGAIN
How do i reset the power supply?
Posted on Jun 12, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa.. 10 flashes or 'single flash with 9 flashes' on the power button means a 'Power Circuitry' problem within the unit (either a loose wire or loose connection on a circuit board).
Your TV has ITC222 chassis, the first thing to do is reseat the 2 ribbon cables between the Power supply/deflection and SSB boards. Those things are notorious for weird intermittent problems. Also check for any coolant leakage on the board.
And, if fiddling with the cables doesn’t help then probably you might need to replace the power supply board.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 07, 2009
  • Rylee Smith
    Rylee Smith Sep 07, 2009
    Nope that will not make any difference as its the same thing.
    Thanks
    Rylee
  • Scott Henderson
    Scott Henderson Oct 19, 2010
    This is actually a ITC250 and doesnt even have a deflection circuit. nothing that has been said is correct. but I would start with checking the LAMP.
Plug on tv model# d44lpw134 was not all the way in and cable wire fell on plug and caused a spark and now tv will not turn on
You can test a fuse if it is open with an ohm meter or you can look, inside the glass to see if the wire is broken.
Jan 03, 2012 | RCA D44LPW134 44" HDTV
I have a rca hd tv 42 inch model #40LA45RQ stays on for about 15min to half hour goes off please help
hi,
Check the lamp cooling fan. If the fan is faulty then the lamp will become overheated and the protection circuit will turn it off . you can see the fan near the lamp housing.
ok
Jun 12, 2011 | RCA D44LPW134 44" HDTV
Made high pitched sound, then no picture
Hello Sir fi you have sound but no picture in your tv this could be lamp issue is very easy to change it
regards
Ness
Jan 18, 2010 | RCA D44LPW134 44" HDTV
Preparing for transport
STOP! DON'T BUY IT! These RCA (and all) DLP's are JUNK! You will, at the least, end up paying 100's of dollars in new bulbs, which you have to replace after they burn out and at the most up to $1000 or more to fix the ballast, the light engine, the board, the power supply...DON'T DO IT! Do a google search for RCA products and DLP in general and read the horror stories! Mine is one of them... You have been warned!
Mar 19, 2008 | RCA D44LPW134 44" HDTV
Picture format changing
i think that that tv is equipped with an "autotformat" feature there should a setting in the menu to change that option. check owners manual.
Jan 28, 2008 | RCA D44LPW134 44" HDTV
Loud noise from tv
if this is a very annoying screeching or sqeualing type sound, it is, in my experience, the "color wheel" which is located inside the lite engine. this is a replaceable component whick costs about $110....i've done this repair many times with no problem....
Oct 30, 2007 | RCA D44LPW134 44" HDTV
Buzzing sound by bulb
be quite sure that it is not the fan physically touching the case; other than that, scope your B+ voltage to the ballast and be certain it is clean;  while it could be that or the lamp itself, it is most probably loose or misaligned case assembley
Oct 09, 2007 | RCA D44LPW134 44" HDTV
Possible heat related problem to television.
If you had the back off ,while in there jump any switchs that are related to cover being off,turn on set kisten for fan bearings .check air path ,especially in light unit.wayne
Oct 19, 2006 | RCA D44LPW134 44" HDTV
RCA D44LPW134 44" HDTV Logo
133 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
