Question about Dacor ECS230 Epicure Electric Double Oven
Daco oven - U60 cooling fan error
I would NEVER NEVER NEVER buy any Daco product again. I just purchased a Daco oven about a year ago. I used it only 5 or 6 times. Recently I got the message “U60 Cooling Fan” error. I searched the Internet and noticed that a lot of people have the same problem as mine. My oven should not break down just only a couple uses. It was not cheap, but its quality is really bad. I rather buy other products that are a lot cheaper, but more reliable than Daco. You live and you learn. Goodbye Daco forever.
At the mean time, Ali Bani, can you please give us the key pad sequence that you have so that we can fix our over problem. Thanks.
    Top Expert:
  • Dacor Master
  • 79,847 Answers
Still active problem?
Posted on Jul 26, 2017
4 Suggested Answers
Rotu
  • 175 Answers
SOURCE: Display reads U60 Cooling Fan - oven won't heat
The code is telling you that the oven has sensed a fault in the coling fan circuit of the upper oven. Dacor has had a few problems with the cooling fans in these new ovens since theyve been out, so most likely you will have a bad fan motor. If that is the case, be prepared to have the repair person have to pull the oven out of the wall to get to it and change it. If its a realy board problem (less likely) than that can be changed from the front. Call up Dacor and find an authorized servicer in your area since it will still be under warranty. Good Luck!
Posted on Feb 06, 2007
woodchuck789
  • 4070 Answers
SOURCE: im getting this message u60 cooling fan can
There is a small fan you should be able to hear blowing when the oven has been hot for a while. The fan keep the electronic controls cooler so they won't be damaged by the heat.
Posted on Aug 22, 2009
I got Dacor to give me the number sequence -- - push "cancel" and "#" at same time - when screen asks for "service ID" enter "S1234" (get "S" by pushing "7" 5 times) - screen will list "U60 Cooling Fan" as number 1, so select "1" - select "clear all", this should clear the error - hit "cancel" to get out of that screen
Hope this works for you! Best suggestion I have is DON'T BUY DACOR!! We also own their 30" dishwasher, which has been a nightmare experience as well.
Posted on Jan 13, 2010
My kitchen aid kebc208kss0 is getting the PF error in cool down mode.
\I am not sure y it is giving the PF code because that code is saying there has been a power failure. U could be right in the direction you are thinking.
Apr 26, 2014 | KitchenAid Ovens
Omega oven
The cutout stat for the cooling fan needs replacing
Oct 06, 2017 | Ovens
Im getting this message u60 cooling fan can some one tell me the meaning? Thanks
Aug 21, 2009 | Dacor MCS130 Millennia Electric Single...
Jenn-Air coolimg fan problem
Good Morning!
What youre experiencing could be a result of a faulty oven temperature sensor, a faulty oven control board or relay board. Youre more than welcome to send both the main control board and relay board for evaluation. Fixyourboard will test and repair both as needed for less expensive than buying new, and include a two year warranty.
5700M662 60 Jenn Air OVEN CONTROL BOARD
May 15, 2017 | Jenn-Air JJW8230D Electric Double Oven
Apr 09, 2008 | Dacor ECS230 Epicure Electric Double Oven
GE: JTP56 F2 Door Locked displayed
I have the the same problem as discribed above. Does you oven fan go on for a long time after you use your oven during regular baking. Mine seems to stay on for 45 minutes after I bake anything. Can this be all tied together with the f2 problem? I am wondering if it is not just a fan circulation problem?
Dec 15, 2007 | GE Profile JTP56 Electric Double Oven
Feb 05, 2007 | Dacor Millennia MOV130 Electric Single...
Thermador Oven won't heat after running self-cleaning cycle
SOunds like you need to reset the oven high limit switch. It should be located behind the grille obave the oven opening and below the control panel. There should be about 4-6 screws you need to take out to remove the grille to gain access. Turn the power of to the oven at the circuit breaker, then rech in with a screwdriver and push down on the little red button in the center of the hig limit until it clicks. the high limit should be about as big around as a quarter and have a wire going into one side and out the other. If this keeps tripping, you may have a bad cooling fan. When you run a self clean it should also run a fan to cool the components. You should be able to feel a breeze coming out of the bottom of the oven when the cooling fan (not the convection fan ) is running. If this fan doesnt run, it will trip that switch. Hope this helps!
Dec 08, 2006 | Thermador C301U Electric Single Oven
Dacor ECS230 Epicure Electric Double Oven Logo
340 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
ashburton
Are you a Dacor Oven Expert? Answer questions, earn points and help others
