Question about Lincoln Welding Tools
Welder is geting power. But wont turn on.Could primary be bad? and if so what would it cost to fix.
  • 1 more comment
  • slims_300zx Sep 08, 2009
    power is gowing through switch.and i have power to primery wires. but nothing out of primery.
  • slims_300zx Sep 10, 2009
    Yes im im geting power to the transformer. soo can i check continuity on transformer.
  • slims_300zx Sep 11, 2009
    ok thanks
  • 395 Answers
This basically depends on your location, it would basically cost you below $50 to get it fixed.
Hope this would help. I had a bad one that i fixed and it had similar problems with yours. It cost me about $50 to get it fixed.
Cheers
Posted on Sep 10, 2009
I have a AC 225-s stick welder that has the capacitor removed.Could you tell me what size to replace it with?
Thanks Garry R Perry (dorcabg@aol.com)
Posted on May 08, 2011
    President:
  • 1,723 Answers
Wont' turn on, this is kind of wide open question for me to reply to. Have you checked all the basics? If you opened up the welder, have you checked any fuses and looked all the connections over? Do a good visual inspection first thing and make sure you look for any blown fuse. Try to turn it on with cover off and note any conditions that might occur. Give the control module (electronic board) a good look and see if there are any burned components.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Sep 11, 2009
    President:
  • 497 Answers
You could physically inspect all wiring within the unit to make sure every connection is secured. but sounds like you have a faulty switch. replace it and it should work fine.
Posted on Sep 07, 2009
  • Greg Mills Sep 09, 2009
    Im not sure exactly what you are referring to from "primary" wires. if the leads coming from the power switch are still good, that goes to a transformer. that may be bad, But without some more info i cannot be more help.
Low output on silverline inverter welder 633822
Got anyone around with a multimeter? You need to see where the power drops -- primary or secondary side, control circuit, etc.
Aug 25, 2014 | Welding Tools
I have a miller econo welder,the power switch is bad where to get one??
contacts in switch seem to have gone us local elec store should get
Aug 01, 2012 | Miller Welding Tools
My snap on welder isn't working properly. With the heat dial turned all the way up, I have to turn the wire speed almost all the way down. Even with it in the hottest setting it welds cold. Won't even burn...
I own and love my Snap-On YA-212A and had a similar problem that turned out to be a power issue, not a welder issue. Repair costs and parts availability of these welders can vary wildly, it may be cheaper to replace it with a Lincoln, Miller, or Hobart. Snap-On uses more than one supplier to make their welders, if you tell me the exact model number I can probably tell you who manufactured it,
For now, try the following:
  1. Unplug the welder from the power outlet on the wall
  2. The power cable where it connects to the welder should be a twist lock type, make sure it is not loose. Take it off and look for any signs of arcing that look like it may have been a bad connection
  3. Look at the power connector that plugs into the wall and look for signs of arcing. If possible, take the back off the plug that goes into the wall and ensure that everything looks tight.
  4. Put the power cable back on the welder
  5. If your breaker box has a load controller turn it off and try your welder again
  6. Replace the circuit breaker in the breaker box on your house
Feb 26, 2011 | Snap-On Welding Tools
I have a carke 140 and it start but ado it is at max it will not even burne a 2mm rod (it dos not weld only do little blobs ado is at max power setting )
get a good heavy gage extention cord its about 60 DOLLARS YOUR NOT GETING ENOUGH CURRENT TO YOUR WELDER this goes for any welder stay away from cheap extention cords home depot carrys them dont be cheap
Dec 12, 2010 | Clarke Power Products Welding Tools
Have a hobart 140 mig welder, the wire feed otor does not turn on, gas solenoid does
I have a 120 and when that happened to it the bridge rectifier was bad on it. Not sure if your 140 has that or not but just something to look into. It only cost me about 8 or 10 bucks to fix mine.
Apr 26, 2010 | Hobart Handler 140 Mig Welder
Ave a power mate 225 amp 240 volt welder that wont arc
Sounds to me like the Power Controller has gone bad. These are a real tricky, dangerous, things to fix yourself, I recommend that you call the service rep, for Power Mate,and cut your losses.
Feb 24, 2010 | Welding Tools
I have an old mastercraft 110 volt ac stick welder model 110-104 have not used it for years have lost the instruction manual plate on the machine says primary voltage is 115 and primary amperage is 26.6...
35 amp should do nicely however make sure the mains cable is of the correct size, better still, get a qualified Electricion to install it.
Usualy 30amp could be used but using 35amp gives you some reserve
Oct 03, 2009 | Miller Electric Mfg Co 903505 Invision...
Tv went blank, wont come back on.
If those green lights on the board are going dim, then yes it should be repaired. This is likely a bad main filter capacitor on the primary side of the switch mode transformer. Should not cost over $150 at the most. Easy fix
Aug 02, 2009 | Hitachi 70SBX74B 70" Rear Projection...
Hobart handler 140 will not feed wire
A schematic would certainly help, give Hobart a call and ask for a wiring diagram. or manual. Hobart are very helpful and may even give you guidance, you may have to pay the postage, they usually fax these documents so it will not cost you anything.
Feb 13, 2009 | Hobart Handler 140 Mig Welder
Laptop wont boot
windows cant be bad, seems your laptop is not geting throught POST (power on self test)
I could probably fix or find the reason If I where near you but not much I can say from here.
Id take it to a professional for analysis, simple problem analysis shoudnt cost itself at all. so.
easyer on all of us that way.
Mar 27, 2008 | Dell Inspiron 6000 Notebook
Welding Tools Logo
272 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
