Question about Dometic RM2652 Refrigerator
Will not cool on gas or electricity - Dometic RM2652 Refrigerator
  • 508 Answers
May haft to pull unit and tip sideways to reactivate chemicals then try!!!!
Posted on Sep 07, 2009
It was working fine it was unplugged to be moved now it wont work on electric or gas its a rm 760 gas or electric domestic
When operating on Electric, if the rear of the cooling coils get warm and the fridge is level, but the refrigerator does not get cold then it is more then likely your cooling unit that has failed. Visit ArctiCold Refrigeration We keep it cold for info on replacement cooling units.... I have also attached a video with tips on diagnosing the RV fridge,
Arcticold New replacement cooling units can be purchased from Ebay Dometic RM760 Brand New Manufactured Cooling Units LIFETIME WARRANTY
Sep 16, 2013 | Dometic Refrigerators
I have a Maytag Ensignia Electric Dryer Mod. # MDG7758AWW. It starts up but runs cool air only and intermittenly will give off some heat but can run for a hour with cool air only. The vents and lint...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 15, 2011 | Maytag MDG7758AW Gas Dryer
My dometic refrigerator unit is not cooling properly on gas or electric. The freezer gets cool but the fridge stays warm. What could cause this?
my domestic refrg will not work on electric but will lite on gas. freezer will get cold on gas but bottom will not cool.you can plug refrg in and it will kick the gas off. you unplug refrg on gas will lite.that part of the power board seems to be working.
Apr 17, 2011 | Dometic RM2652 Refrigerator
Dryer is always "Cooling", doesn't heat. Why? How ...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 20, 2010 | LG DLE2514 Electric Dryer
Works good on electric. The freezer freezes on
make sure your gas level is right. low gas levels can cause your problem
Aug 07, 2009 | Dometic RM2652 Refrigerator
Our Dometic RM2193 cools on gas but does not work on electric
It could be as simple as a blown fuse at the fridge. Also check to make sure you have turned on the electric switch that allows the fridge to run on AC. Note, you can only operate the fridge on EITHER gas OR electric, but not both sources at the same time, thus, you have to turn off the gas switch before you can run on electric.
When this unit is running on electricity, it has to have the thermostat set for it to run.
Here's a link to the Dometic manual for your model.
http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
Just follow the steps for running on electric and you should be OK.
Hope this helps.
Jul 30, 2009 | Dometic RM2193 Compact Refrigerator With...
DOES NOT COOL AT ALL ON GAS OR ELECTRIC
This sounds like you have a block inthe cooling unit. The only way to repair this is to replace the cooling unit or replace the refer. Sorry this is not good news but this happens
Nov 24, 2008 | Dometic NDR 1292 Refrigerator
Dometic rv fridge
Your possibly getting a DC voltage interuption Your convertor can be over heating causing a temporary drop. You can chech this by turning everthing dc supplied on and watch to see if the check light comes on then. Primary is electric and if no electric then it is suppose to look for gas.
May 29, 2008 | Dometic RGE400 Top Freezer Refrigerator
Hi i have a 3 way electrolux fridge. it cools perfectly well on the electric mains, I've not tried the 12v, but it fails to cool on the gas. The gas ignites but fails to cool the system.
A simple remedy to the fridge working correctly.
I wasnt aware that the mains dial turned fully to an 'OFF' position. Once I had turned the dial until it 'clicked' off, I tried the gas and it lit and cooled perfectly.
May 28, 2008 | Electrolux Refrigerators
Electrolux RM212,F, wont cool on gas but appears to be ok on electric. The flame lights but can only feel a slight chill in the freezer box, and the flame does not seem to adjust with the control.
May 13, 2008 | Electrolux Refrigerators
Dometic RM2652 Refrigerator Logo
291 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
