Question about Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive
WD 500gb external hard drive 'elements' not recognised by laptop
I have a WD 500gb external hard drive 'elements' and it's not being recognised by mine or my dad's laptops. Power supply is normal. Have tried updating drivers, as well as going into Computer Management Snapin (i have vista, dad has windows 98) and no joy.
  • 4 Answers
Windows 98 does not properly work with drives > approx. 130 GB. This has something to do with the FAT* being not large enough for more cluster entries.
*(FAT = File Allocation Table; this tells the computer in which clusters on the HD a file is stored. What is the FAT good for? A computer stores files on HD like a very messy person: The first next free space is used; if it is not sufficient, the second next free space and so on. This leads to fragmentation, i.e. one file may be stored on many different sections of the HD. But unlike a messy person the computer keeps good track of where he puts all the pieces; this list is the FAT.
Here's how I worked around that problem: Partitioned them so that each partition was about 125 GB. Also: Cluster size must be 32 kB; if it is smaller you get more clusters and the FAT can't handle so many.
For example I have a 500 GB hard disk that is partitioned into four 122 GB partitions (just to be on the safe side; a couple of GBs not allocated). This works trouble-free.
You might do the partitioning with Windows's FDISK, though it gives you wrong indications about partition sizes. Use percent values (e.g. ''24%'' when specifying the required partition size in FDISK.
A partitioning utility I can recommend for ease and reliability is Acronis Disk Director Suite.
Posted on Sep 24, 2009
I had the same problem with WD Elements 500 GB. I have Windows 2000. replaced the cable, ans the problem was solved.
Posted on Mar 12, 2010
    Sergeant:
  • 338 Answers
Hi i_mock_thee,
nice to have you here,
concerning this harddrive issue, try using another usb cable(from a thumb drive) with it to make sure the other is not broken.
if this external harddrive is only powered by the laptop's usb port it might simply not work because the laptops power supply cannot
provide sufficient power for it.
It may work with any other Desktop PC though.
Or if it has by chance a power adaptor inlet, purchase the fitting one and it might work then.
good luck
Posted on Sep 07, 2009
My WD external hard drive has suddenly stopped being recognised by my computer
Unplug the power supply from the hard drive, leave for 15 seconds.
Plug power supply back in.
Try another USB cable if that does not work.
Aug 08, 2011 | Western Digital Elements powered by WD 320...
My PS3 wont recognise my WD Elements 500GB hard drive
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Jun 27, 2011 | Western Digital WD Elements Portable...
My drive is not recognised on my windows laptop
Connect it to a different computer. If it still is not detected, then there is a hardware problem. Exercise the warranty to get it repaired/replaced.
Note that W.D. has a "Customer Loyalty" program; buy a new W.D. drive from the W.D. web-site, at a good discount.
Nov 01, 2010 | Western Digital Elements powered by WD 320...
Whats the input and output for a a power adapter needed to work a wd elements 500gb external hard drive?
Check the label affixed on the unit. It should indicate the power requirements. If not, go to the Western Digital website and locate the specifications for this particular model.
Oct 28, 2010 | Western Digital 500GB ELEMENTS 500 GB USB...
My wd elements external hd is not recognized under windows 7. The pc diagnostics say that the device is working properly and the correct drivers are installed?
Go to Administrative Tools in Control Panel. Computer Management then Storage, Disk Management. You'll probably have to recognise it and assign a drive number.
Jun 18, 2010 | Western Digital Elements powered by WD 320...
Where can I get a replacement USB cable for a Western Elements 500GB external hard drive?
you should be able to get one from any reputable computer store,where ever you brought the drive from may be able to order you another usb lead,
May 15, 2010 | Western Digital Elements powered by WD 320...
External Disk WD Elements problem
did u format the wd 320 gb already
you have to format it first to work from it
Apr 06, 2010 | Western Digital Elements powered by WD 320...
WD Elements USB drive not recognized
Try going to Disk Management and see if they show up there.
  1. Click Start
  2. Right Click My Computer
  3. Click Manage
  4. Click Disk Management
If your computer is recognizing a mass storage device they should show up in disk management and you can just assign them a drive letter.
Sep 15, 2009 | Western Digital Elements powered by WD 320...
Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive Logo
1,041 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
