Question about LG Dishwashers
What is the difference between the 5835ED2002A blower assembly and the 5835ED2002D. The repair replaced the ''A'' with a ''D''. The ''D'' has a drain hose and ''A'' does not. Can this part still be used? Model # LDF6810BB. Thanks.
4 Suggested Answers
  • 127 Answers
SOURCE: Info on replacing drain hose on dometic model 2652
You will need to remove the fridge and set it on the floor or at least pull it forward enough to reach the top of the drain hose. There is clip that holds the drain tube to a nipple that sticks out of the back of the fridge that will need to be removed. Remove this clip and the drain hose should pull right off. Route the new drain hose down through the cooling unit coils to the door panel. Attach it back to the nipple with the clip and you should be good to go. The part number for the new drain hose is 2932749019.
Hope this helps,
Jeff
Rate me please!!
Posted on Jul 03, 2009
  • 1915 Answers
SOURCE: Ford dealer said the blower motor in my 2008 Ford
If it were me, I'd make a lot of noise-that car is not that old to have a blocked drain-sounds like they are trying to get out of what they should cover, and they chose to treat the cause and not the problem (blower motor failure)-you might only have a bad relay or blown fuse, but I would think they should have checked that out-ask them if they did. Tell them that a plugged drain hose in a 3 year old car is the manufactures fault, and it caused the blower motor to short out-therefore, it should be covered, and call Ford directly if you get no satisfaction-there is no reason that should have happened.
Posted on Jun 23, 2011
brimax7576
  • 344 Answers
SOURCE: Will a throttle assembly from one leaf blower work on another leaf blower of a different model?
9 outta 10 times no. Unless it's the same company or brand... for example, if you have a poulan and wanna put it on another Poulan, u may get lucky.. but if you are interchanging makes and brands...no go
Posted on Oct 14, 2015
HEATER NOT WORKING ON 03 YUKON
Heater not working ???? Blower motor not working , no air blowing out of the vent's. defrost , floor ? I'm assuming you have the manual HVAC - climate control system , by the fact that you replaced the resistor assembly . Was there a relay included on the resistor assembly ? What fuse's did you replace ? HTR/AC - 30 amp. left I/P fuse box , BLOWER fuse -40 amp - under hood fuse box ? Did you use a DMM - digital multi-meter an test for B+ voltage at the purple wire at the blower motor ? The fuse's you replaced ,check for B+ voltage with meter .
Your vehicle could have two different HVAC systems , manual & automatic. The automatic system doesn't have a resistor assembly , has a blower motor control processor. Do you know how to test automotive electrical circuit's ?
Jan 05, 2018 | Cars & Trucks
Whirlpool duet 8E error code, what is the cause?
F8E0Steam valve failureCheck the water supply hoses for kinks. Check for a restricted screen in the water valves. Replace the steam valve if defective.
Steam valve
F8E1No water detectedMake sure that both water supply valves behind the washer are fully open. In winter, check the fill lines for freezing. Check the drain system for a siphon problem. If the water valve assembly is defective, replace it.
See the repair guide to fix it yourselfWater valve assembly
F8E2Dispenser failureThe dispenser can't move into position. Unplug the washer and check the mechanical linkage on the dispenser housing. Repair or replace any damaged dispenser parts.
Dispenser assembly parts
F8E3Overflow conditionUnplug the washer and, if the washer is overfilled, check the water valve assembly for proper shut-off of water flow. If the water valve assembly is defective, replace it. If the washer is empty when this error code appears, replace the water level pressure switch.
See the repair guide to fix it yourselfWater valve assembly, water level pressure switch
F8E4Low water flowThe flow meter detects a long fill time. Make sure that both water supply valves behind the washer are fully open. In winter, check the fill lines for freezing. Check the drain system for a siphon problem. If the water valve assembly is defective, replace it. If water flows normally, replace the flow meter.
See the repair guide to fix it yourselfWater valve assembly, flow meter
F9E1Long drainRemove excess suds; the washer can't drain excessively sudsy water. Check your house drain system for a clog. Check the drain hose for kinks or clogs. Replace the drain pump if defective. If the washer drains properly, replace the water level pressure switch because it isn't accurately detecting the water level.
See the repair guide to fix it yourselfDrain pump, water level pressure switch
Oct 16, 2016 | Whirlpool Washing Machines
2008 dts caddy blower motor resister location
Your not going to like to hear this , but you'll need to take the dash apart !
Blower Motor Resistor Replacement
Preliminary Procedure
  1. Remove the HVAC module. Refer to HVAC Module Assembly Replacement .
  1. Drain the cooling system. Refer to Cooling System Draining and Filling .
  2. Recover the refrigerant. Refer to Refrigerant Recovery and Recharging .
  3. Remove the evaporator tube from the thermal expansion valve. Refer to Air Conditioning Evaporator Hose Assembly Replacement .
  4. Remove the heater hoses from the heater core. Refer to Heater Hoses Replacement .
  5. Remove the brake pedal bracket assembly. Refer to Brake Pedal Assembly Replacement .
  6. Pull back and reposition the carpet.
  7. Remove the lower instrument panel (I/P) support brace. Refer to Instrument Panel Center Support Bracket Replacement .
  8. Reposition the auxiliary air distribution duct. Refer to Auxiliary Air Distributor Duct Replacement .
  9. Remove the instrument panel carrier. Refer to Instrument Panel Carrier Replacement .
  10. Disconnect the HVAC module assembly electrical connectors.
HVAC Module Assembly Nut (Qty: 5)
Tip
Tighten the nuts in sequence.
Tighten
9 N?·m (80 lb in)
HVAC Assembly Module
Disconnect the blower motor resistor electrical connector.
Jul 28, 2016 | 2008 Cadillac Dts
How do i replace the heater core 1997 isuzu hombre
See me at website for images can only send one through this channel. www.autorepairhelp.us
Best Regards,
Master Tech Lee
HEATER BOX SHIELD
Heater Box Heat Shield
Remove or Disconnect
1. Fasteners that retain heat shield to heater box assembly.
Image [ Heater Box Heat Shield
Install or Connect
1.Fasteners that retain heat shield to heater box assembly.
Tighten
-Bolts Screws to 2.2 N.m (25 lb in).
HEATER ASSEMBLY
Image ' Heater Hoses
Image ' A/C Evaporator Tube Assembly
Image ' Evaporator Core
Image ' Evaporator Core Assembly
Image ' Heater Assembly
1.Engine coolant. Refer to Draining and Filling Cooling System in Engine Cooling.
2.Heater hoses. Refer to Heater Hoses.
3.Instrument panel. Refer to Instrument Panel Replacement in Interior Trim.
4.Air inlet assembly. Refer to Air Inlet Assembly Replacement.
5.Vacuum lines.
Important
-Clearly label vacuum line connections.
6.Heater assembly studs inside engine bay.
7.Blower motor resistor. Refer to Blower Motor Resistor.
8.Stud inside heater core housing.
-Stud is revealed by removing the blower motor resistor.
9.Rear case screws.
10.Heater assembly.
11.Seals.
Imagt
Imagt
Imagt
Imagt
Imagt
Heater Hoses
Evaporator Core
Heater Assembly
Install or Connect
1.Seals.
2.Heater assembly.
3.Rear case screws.
4.Stud inside heater core housing.
Tighten
-Stud to 1.9 N.m (17 lb in).
5.Blower motor resistor. Refer to Blower Motor Resistor.
Tighten
-Studs to 1.9 N.m (17 lb in).
7.Vacuum lines.
8.Air inlet assembly. Refer to Air Inlet Assembly Replacement.
9.Instrument panel. Refer to Instrument Panel Replacement in Interior Trim.
10.Heater hoses. Refer to Heater Hoses.
11.Engine coolant. Refer to Draining and Filling Cooling System in Engine Cooling.
-Check the system for leaks.
Sep 06, 2014 | 1997 Isuzu Hombre
Blower motor will not shut off
I can't speak to the cost, a local dealer can do that. As for the reason the fan runs on, it sounds like either a stuck power relay (location should be in the owners manual) or a bad fan speed regulator. Since the fan is stuck on high, I suspect the fan speed regulator is bad. On some cars the regulator is part of the fan assembly, and on some it's separate. Also, there is a possibility you can repair the circuit board, assuming it's something as simple as a burnt out diode. Best of luck!
Jan 19, 2012 | 2005 Chevrolet Impala
How do I replace the heating fan on my 2000 Kia sportage
Blower Motor
Removal & Installation
To Remove:
  1. Evacuate and recover air conditioning refrigerant.
  2. Remove battery.
  3. Disconnect and cap A/C lines at evaporator tubes.
  4. Remove blower motor assembly drain.
  5. Remove glove box.
  6. Remove 5 screws and right hand instrument panel lower trim panel.
  7. Remove screw that attaches upper center console to gain access to left
    instrument panel lower support.
  8. Remove left and right bolt and remove instrument panel lower support.
  9. Detach control cable from inlet duct.
  10. Disconnect blower motor electrical connector.
  11. Pull carpet back and remove hole cover plate.
  12. Remove 2 bolts at top of blower motor assembly.
  13. Remove 2 nuts that attach bottom of blower motor assembly to mounting studs
    on bulkhead.
  14. Remove blower motor assembly.
To Install:
  1. Install blower motor assembly.
  2. Install 2 bolts at top of blower motor assembly.
  3. Install 2 nuts that attach bottom of blower motor assembly to mounting studs
    on bulkhead.
  4. Install hole cover plate and replace carpet.
  5. Connect blower motor electrical connector.
  6. Install instrument panel lower support and install left and right bolts.
  7. Install right hand instrument panel lower trim panel and 5 screws.
  8. Install glove box.
  9. Install blower motor assembly drain hose.
  10. Connect evaporator lines at bulkhead.
  11. Evacuate and charge air conditioning refrigerant.
  12. Install battery.
Oct 29, 2010 | 2000 Kia Sportage
1999 Chev Venture Heater core do I need to remove Dash to replace?
The blower motor location can change from year-to-year. It can also change with the trim level of the vehicle. A vehicle that has front and rear climate controls may be configured differently than a vehicle that has front controls only. The following are two different repair procedures. One is for blower motors located and accessed in the engine compartment, the other is for blower motors mounted inside the vehicle.
REMOVAL AND INSTALLATION
Engine Compartment Mounted
  1. Disconnect the negative battery cable.
  2. Remove the engine air cleaner assembly.
  3. If necessary for clearance, remove the left hand wiper arm linkage.
  4. Detach the wire harness connector from the blower motor.
  5. Disconnect the motor cooling hose.
  6. Remove the blower motor assembly retaining screws
  7. Carefully pull the blower motor assembly out from the firewall.
Oct 08, 2009 | 1999 Chevrolet Venture
1 yr old lg dishwasher model# ldf6810st LEAK/CONDENSATION
I have the same problem in my machine, and it seems to be a design problem from LG. They changed the blower and ducts in Dec/2007 for "improved drying performance". I found it in their most recent Service Manual. It seems there is a repair kit that can be installed on models older than Dec/2007, but I am not sure under what circumstances (warranty claims maybe). As I live overseas (there is no LG warranty for dishwashers in my country), I just keep a piece of cloth there to absorb the moist. Sorry.
Feb 05, 2009 | LG LDF6810ST Stainless Steel Built-in...
TOO ALL SAMSUNG LDF AND POSSIBLE OTHER LG DISWASHER USERS:
LG NEGLECTED MY CALLS TO SOLVE THIS PROBLEM. THE DRIPPING PROBLEM FROM THE CORNERS OCCURS:
1- VENT ASSEMBLY FOR HOT AIR BLOWER SEAL LEAKS: EASY TO FIX JUST USE A GOOD QUALITY CAULK AROUND THE SEAM. YOU WILL HAVE TO DISMANTLE THE BLOWER ASSEMBLY WHIXH IS FAIRLY EASY.
2- THIS IS VERY IMPORTANT: LG HAS A DESIGN FAULT. WHEN THE DISHWASHER FILLS WATER AND STARTS PUMPING TO SPRAYS THE AIR INSIDE THE DW HAS NO WHERE TO GO THEREFORE THE WATER WAS PUSHED UNDER THE BOTTOM OF THE DOOR GASKETS (THE ONE ATTACHED TO THE DOOR BOTTOM, NOT THE ONE AROUND THE MAIN CABIN). SO AIR WITH WATER PUFFS OUT OF THE PAN HITS THE DOOR AND LEAKS DOWN. THE SOLUTION IS TO LET THE AIR OUT SOMEHOW. YOU MUST TRY TO PUSH-IN THE DOOR GASKET WHICH IS SEALING LEFT/RIGHT/TOP PART OF THE CABIN AND THE DOOR. IF YOU PUSH TOO MUCH THE WATER MAY LEAK FROM THE SEALS SO BE CAREFUL NOT TOO PUSH TOO MUCH. BASICALLY TRIAL AND ERROR. YOU CAN DO THAT AFTER YOU REMOVE THE DOOR COVER. THE LEAKAGE OCCURS IN THE BEGINNING OF THE CYE SO IT IS FAIRLY EASY TO TRY. IF THAT IS NOT A SUCCESS THEY DROP OF CAULK ON THE ONE OF THE DOOR EDGE TO PUSH THE GASKET SO THAT THE DOOR PUSHES IN THE GASKET TO ALLOW AIR OUT RIGHT AROUND THE CAULK. NORMALLY DISHWASHERS HAVE AN ELECTRICALLY ACTUATED OUTLET TO LET THE AIR OUT. THEY JUST WANTED TO SAVE COST AND HAVE US DEAL WITH THIS RIDICULOUS PROBLEM.
Feb 05, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Heater/blower fan not working at all after intermittently working
Heater motor is prone to water damage when the small drain scuttle drain gets blocked (usually by leaves).
If the passenger footwell carpet is damp, that's probably the problem.
Worth checking regularly anyway, and/or remove the small cover over the drain which is part of the problem.
Remove the heater assembly (located over passenger footwell) and replace is the easy answer.
It is possible, depending on ability, to strip and repair.
New from Europarts around £130, used around £60.
Have fun!
Oct 19, 2008 | 2000 Mercedes-Benz CLK
Dishwashers Logo
90 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
