Question about Acer TravelMate 290 Notebook
The CPU Fan stop after the pc boots - Acer TravelMate 290 Notebook
  • 241 Answers
The fan will only run when needed to cool the computer. Fans normally run at full speed during bootup, but turn to low speed or off after bootup if not needed. Is your computer running hot enough that the fan SHOULD be running?
Posted on Sep 07, 2009
Trys to start but doesnt
The bios keeps track of all mechanical s pre-boot and post-boot. Beeps most generally mean a bad stick of ram or the ram is not seated firmly in the slot. The other issues are bad CPU or the CPU fan has stopped and the bios shuts the pc down in either case.
Apr 21, 2014 | Acer Computers & Internet
HP Compaq 6200 Pro Microtower XL504AV - doesn't boot
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Mar 26, 2013 | Computers & Internet
Error on normal boot up, System Fan has stopped, system will shut down in 5 seconds. Boot to BIOS: CPU Fan Speed 1700+rpm System Fan Speed 0RPM (in red) of course CPU Temp 45c/113f I opened the case,...
HI ker7758 ,
You may need to apply "Thermal paste/grease " to the CPU.
You can watch this video tutorial from Youtube:
http://www.youtube.com/watch?v=o7rPqCvCt0g
There are different types of thermal grease. You don't have to buy the expensive ones. The cheapest on the market should be able to do the job.
Apr 09, 2011 | HP Compaq Presario S5200NX (DM173A#ABA) PC...
It was just this morning when I tried to turn my pc on.. unfortunately it did not. ! when i press the power button on cpu it turns on for a few second like one or two but immediately after it drops the...
Try replacing the power supply - I had a similar problem that was fixed that way. If that doesn't work, it's probably the motherboard itself. The CPU is also possible - have you overclocked it or otherwise cooked it? Is the CPU cooler/fan blocked with fluff, or has the fan been slow (or stopped) - noisy fan is a sign of bearing stiffness/partial seizure which slows the fan and lets the CPU get too hot. If the CPU is fried, you get the symptoms you describe (MB won't start the PS)
Dec 23, 2010 | ASUS M2N-MX Motherboard
Cpu fan > just stops working
Most likely there is some kind of software management of the fan.
Boot to the BIOS CMOS settings, and see whether there is a "Quiet Fan" or "Q-Fan" setting (or the like) enabled.
Disable this by selecting "Fan runs always".
If you could provide the model number of the desktop, I may be able to give you more specifics.
Dec 20, 2010 | Computers & Internet
When pluged into outlet fans spins and doesnt stop, wont boot
Fan spinning hard is usually a CPU issue.
If you've made any hardware changes to your computer, undo them. This happened to me when I was trying to upgrade my Processor (CPU) and I had the wrong kind.
Mar 09, 2010 | HP Pavilion m7560n PC Desktop
Amd phenom faulty
Replace cpu fan , failed cpu fan might have caused CPU stoped working. If you are sure about the CPU fails then replace the CPU. If the problem seems continues after that too, then PC might have failed to boot due to other reasons. What shows on the screen once you power on the computer? There could be , motherboard , or harddisk faults too. Try unplugging other parts and see if the computer boots from CD or USD flash or floppy drive!! Once you know that motherboard works then replace the CPU. There could be BIOS setup problem. Did you check the BIOS for harddisk is set properly.
Sep 17, 2009 | AMD 2.1GHz Phenom X3 Tri-Core 8450 AM2+...
My sony vgc-rb40 will not boot bios with cpu fan connected
mostly all fans are 12V DC try connecting all the fans directly to SMPS of the system i.e the red and the black wire
Sep 16, 2009 | Sony VAIO VGC-RB40 PC Desktop
Acer TravelMate 290 Notebook Logo
500 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
