Question about QSC MX1500A 2-Channel Amplifier
Peavey cs800x a channel drive board what goes bad?
I have a peavey cs800x A channel didn't work, relay didn't click.no power light .I swapped the drive boards,and now A channel works,but B relay doesn't click.So it definatly is in A channel Drive board.
    Champion:
  • 211 Answers
A bit late, but I'll give it a try.
You can measure the outputsignal before the relay.
Often there's a coil, measure if you've got a DC level at that point.
If so, you're power amp is down.
Normally when the relay doesn't switch there's a DC level in your amp.
Cheers, Gerard
Posted on Nov 06, 2009
I have a Peavey amp but no sound is coming out?
Bad output transistors or bad Soldier joint in output section
Nov 26, 2013 | Peavey Xr 8600 8 Channel Powered Mixer
No Power to A channel
check output transistors also the driver transistors.
Jul 28, 2013 | Peavey CS® 2000 Amplifier
How do you test the three relays to the radiator fan on a 1995 Mercury Villager?
When you apply power and relay clicks,that means its good.Best way to test relay issue is swap the relay with another working relay of same type and see if problem goes.This relay issues are very frustrating,while testing it shows good but still it will not work sometimes and after replacing relay all gets good.Also relays are not costly to replace.You can try swapping the relays and see if it helps.
Mar 05, 2013 | 1995 Mercury Villager
I have 2 Peavey Impact 1015s and 2 PV 118 Subs. I have a Peavey Kosmos PRO that runs from my Numark CDMix3 to my amps. My two amps that I have are a Peavey CS800x and a Crest Audio CD3000. Could you tell...
Just a note regarding connecting: USE BALANCED lines everywhere you can. Use either XLR if available or TRS type cables. This will reduce noise pickup.
Another hint: For SAFETY of your equipment run ANY interconnected devices from the SAME power source. DO NOT say power the amps from one place and your other equipment from a different outlet. Afford a power distribution system that feeds from a single receptacle or nearby receptacles near a common electrical panel. This will ALSO help avoid noise as well as the hazards to your equipment from ground loops.
Apr 01, 2010 | Peavey Music
The DDT light on one channel stays on,but I can't find a reason why? What can I do?
Disconnect the speaker wiring and speaker on the bad channel. Turn the level control(s) all the way counterclockwise and turn the amp on. If your DDT (limiting) light remains lit, it's time for a visit to your nearest certified Peavey service center....G.
Feb 05, 2010 | Peavey Pv 2600 Power Amplifier
Peavey 5150 II guitar amp! Power Tubes don't light up and only
peavey 5150 II has low humming sound but still plays and sounds pretty good...should i re-tube it?
Jul 18, 2009 | Peavey PV-3800 2-Channel Amplifier
Peavey sound board 2 channels not working
check for cold solder joints from the input jacks and the fader. If any look suspicious (dull or grainy) re-solder.
Apr 29, 2009 | Peavey Pv 2600 Power Amplifier
Peavey CS-800 PA power amp 1 channel is out
Hi Bill,
It's a log time ago that I repaired those amps., but I give it a shot.
There's a speakerprotection after the finals, what I remember it's a triac (SAC187, or something like that).
You will find it at a small pcb at the back of the amp. Normally it has three legs but the centre is cut away. If it's down you will measure 0 Ohm at the output, also with a switched off amp.
Thats all I can remember, it was about 25 years ago.
Maybe it helps,
Gerard
Jan 25, 2009 | QSC MX1500A 2-Channel Amplifier
Open Questions:
See all QSC MX1500A 2-Channel Amplifier Questions
QSC MX1500A 2-Channel Amplifier Logo
527 people viewed this question
Top QSC Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Are you a QSC Audio Player and Recorder Expert? Answer questions, earn points and help others
