Question about Dishwashers
My kenmore ultra wash dishwasher is starting to forget to clean!!
Hi there, I have an older model (model # 110764592) kenmore ultra wash dishwasher and as of late more and more plates and glasses have come out dirty. It's been getting progressively worse. Being that I bought my house 2 years ago and it was part of the house package, I do not have the manual. I can only imagine that there are a few maintenance things I could check on or a few different parts that could be checked foe efficiency.
I have taken the arms apart to see if there was plugging or food blockage in them but found nothing. I've also taken the whole lower half apart to see if there is drain blockage and found again nothing.
What could I check next? Any help would be much appreciated!!!
My kenmore ultra Model 110764592 portable dishwasher does not remove the water from the bottom of the unit at the end of its cycle
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Apr 21, 2011 | Dishwashers
We have a Kenmore Ultra Wash Dishwasher Model 15955781. We are now getting a white film on glasses and dishes are not cleaning. What is the problem?
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Dec 27, 2010 | Kenmore 24 in. 16352 / 16354 / 16359...
Normal wash light blinking, d/w wont start
Wish I could solve this, as I'm having the same problem too. Normal light blinks not matter which wash button is pressed. Cancel light will light, but still NOTHING happens. Same model as yours.
Jul 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Decible level for a Kenmore model 16625691 ultra dishwasher
HI,
ACCORDING TO SEARS TECH SERVICE THE AVERAGE DECIBLE READING IS 53.5 DECIBELS
HOPE THIS HELPS. THIS IS ONE OF THE QUIETEST MODELS IN THE CLASS OFFERED BY SEARS.
Nov 12, 2008 | Hobart AM14-253 Free-standing Dishwasher
Kenmore ultra wash dishwasher control lock light flashing
Just press the 'Air Dry' button for 5-6 seconds....I have an ancient Kenmore Dishwasher (ULTRA)
Oct 02, 2008 | Kenmore 15899 Built-in Dishwasher
Dishwasher won't start
Drhook65,
Welcome,
I'm Huuum
How old is this dishwasher and the complete model number is?
You said, you have a Kenmore Ultra Wash dishwasher, and you have power running to it, but when you shut the door on it...it still won't start a cycle. Does it have a reset button on it? Any ideas on a solution?
Yes, you may try this to reset the system.
Go to the breaker and switch it off for 5 minutes and the on and try it. It usually resets the systems.
Let me know ho it goes. Huuum
Do not forget to leave a rating.
Sep 24, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Older dishwasher-kenmore ultra wash. Serial no ff3902085, model no :110764511. I have no info on how to run it. Does it take rinse agent? D. Wickes
Hi landwix,
I'm Harvey the Master Plumber.
Your problem is: older dishwasher-kenmore ultra wash. Serial no ff3902085, model no :110764511. You have no info on how to run it. Does it take rinse agent?
Operation is simple and yes it will take rinse agent if you so desire. Rinse agent can be purchased either liquid, dry or combined with the soap in a tablet (I don't recomend). The dry comes in a tiny basket you hang from the upper rack. The liquid goes in the dispencer next to the soap dispencer. Just twist the plug counter clockwize about 1/4 turn and lift out, pour in no more than 4 oz. slowly and replace plug. Forget about it for a month. It will use a few drops with each use. Fill soap dispencer about half full and close. Choose wash cycle (normal, etc.) then press start. Thats it.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Sep 21, 2008 | Dishwashers
Clean light keeps blinking and I can't start a new cycle
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. Catriver...post back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
129 people viewed this question
Top Dishwashers Experts
Owen Barnes
