Question about Lands Phones
My onetel OT250 tam twin will not ring on phone or base but phones out fine? please help
How to extend ring
To extend the number of rings before your phone goes into the answer message option, change the settings for Answer delay option as described below.
You can set number of rings before your phone answer message kicks in. You can set answer message to begin after 2, 4, 6 or 8 rings.
1. Press <Menu> and up down to select ANS Machine
2. Press <OK> and <up/down> to select TAM Settings
3. Press <OK> and <up/down> to select ANSWER DELAY (OPTIONS: 2, 4, 6 OR 8 RINGS)
4. Press <OK> and <up/down> to select to select desired delay.
5. Press <OK> to confirm.
Aug 18, 2014 | Binatone Lifestyle 1910 Twin Cordless...
Onetel OT2500 - anyone know how to turn answer-phone on?
Press the c/Mute button (Has a tape logo on it) It should say either TAD ON or TAD OFF - presumably yours says TAD OFF!! Press number 8 to switch between TAD ON & TAD OFF.... If Answer is on, you'll hear a double beep and the orange message light will come on.
Regards.. Ray
Feb 05, 2009 | Philips 2252 Twin Cordless Phone
Lost instructions
Try the manufacturers website.
Dec 03, 2008 | Lands Phones
Onetel cordless phone OT350 does not ring
Hi I had a similar problem with my 350, I phoned their support line who said it was not repairable so if you found a solution please let me know?
Aug 29, 2008 | Lands Phones
FAX JX500
Mary:
Given that the last question I responded to for you related to a Fax JX200 - and this to a JX500 - I am not certain which model you are actually asking about. The information that follows relates to the JX500. Further, if you need information in this regard on the prior post in order to feel that the previous response was a FixYa level response, please let me know. I responded based on the information you provided...
Based on the fact that you are getting a constant 5-ring situation, it appears that the machine is in TAM (tel-ans mach) mode. The purpose of 5 falls into remote recovery of messages - toll saver results in the phone answering after 2 rings if there are messages to retrieve, and 5 if there are not. This is done to prevent long-distance charges if there are no messages.
Two ways to accomplish an 8-9 ring objective. (1) Place the machine in manual mode, which means answering every call and sending faxes to the machine. Additionally, a "fail-safe" on this mode is that it will switch to TAM/automatically answer (if there is a recorded greeting message) after 15 rings - below. (2) The incoming ring - ring count - can be set (under Fax/Tel Auto) to ring 10 to 60 seconds before the fax picks up. (3) Alternatively, the Incoming Ring ring count can be set to have the fax ring 2 to 30 times, depending on the country specific parameters.
Re TAM: When the fax is set to <MANUAL MODE> and <MAN/AUTO SWITCH> has been set to <OFF>, TAM MODE will be activated if the fax rings 15 times and the call is not answered (only when an outgoing message has been recorded). When the call is disconnected, the fax returns to <MANUAL MODE>.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding your specific needs, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Aug 04, 2008 | Canon FAX-JX200
Onetel ot150 plus add handset
I don't have a second handset, but I'll quote from the instruction manual - Try this,
Regsiter up to 5 GAP cpmatible handsets to your OT150 base. New handsets must be fully charged.
You can use the same handset at home as well as the office by registering it to 2 bases.
1. At the base: press and hold "FIND HANDSET". You hear 2 beeps and the in use light flashes. Youa re now in registration mode.
2. At the handset: Press "OK". scroll down (with down arrow) to "REGISTRATION" and press "OK".
3. "REGISTER" is diplayed. Press "OK". Any free base numbers will flash. Enter the number of the base you want using the keypad.
4. Enter the PIN Number (default = 0000) and press "OK"
5. The handset searches for the base and when registration is complete goes into standby mode.
To test the handset is registered. Press "FIND HANDSET" on the base and the handset should begin to ring. Press "FIND HANDSET" again to stop the ringing.
As I say this is taken word for word (with a few spelling mistakes no doubt) from the instructions. I Hope that it solves your problem.
If you still have problems or you don't have the PIN number, the helpline number is 0845 226 7794, or e-mail help@telephoneproducts.co.uk
Mar 09, 2008 | Cable_and_wireless CWD4901 Cordless...
ONETEL PHONE
When your handset is in standby, press and hold the left pointing arrow until TONE is displayed.
Feb 07, 2008 | Lands Phones
Lands Phones Logo
141 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
