Question about Garden
I got a scotts 35-3 spreader at a thrift store, need details
What settings should I use?
    Problem Solver:
  • 13 Answers
Use the "Broadcast Spreader" settings on the product package, not the "Drop Spreader" setting. I find that "3" works for me with the stuff I put down: namely, lawn fertilizer and weed killer.
I haven't used it with ice-melt, so I can't advise you there except to say that if what you run through it spreads too thick, reduce the opening size; if not enough comes out, increase it.
Posted on Mar 28, 2010
What setting do I set my Scotts speddy green 2000 broadcast spredder to spread colonial bentgrass at 2 lbs per 1000 sq ft?
Scotts Spreaders
Robert, Normally the bag tells you the setting to use, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Scotts Spreader Settings Helper Tools Scotts
How to Calibrate Scotts Speedygreen 2000 Lawn Spreader eHow
Lawn Care Basics How To Use Lawn Spreader by Scotts
Mar 23, 2016 | Scotts Garden
I need a new spring is it replaceable
Yes, you will need to remove spring and take to hardware store or automotive parts store to match it up. Or you can look online at the parts list for your spreader and order it from Scotts directly.
Mar 28, 2015 | Scotts EvenGreen Drop Spreader
Need a setting for Scott's Speedy Green EdgeGuard mini
First, I went to the products website, in this case Lesco and looked up the spreader settings:
https://www.johndeerelandscapes.com/home/spreader-settings.aspx
Then, I went to Scotts website and looked up spreader settings:
http://www.scotts.com/smg/node2/SCOTTSCOM/lawn-care/lookup-spreader-settings/7800015-24900013-s
I cross referenced a product on the Scotts website that uses the same settings as one of those listed on the Lesco website and I found my settings that way.
In my case I was using Lesco Pre-M 0.86% 0-0-7 and wanted to apply 5.3 lbs/1000ft. My spreader was a Scotts Turf Builder EdgeGuard Mini with settings from 0-15. I found out by cross referencing that the Scotts Speedy Green 1000 and my spreader used the same settings. So I ended up using the recommended setting of 5.5, as listed on the Lesco website for the Scotts Speedy Green 1000, to apply 5.3 lbs/1000ft of pre emergent using my Scotts EdgeGuard Mini.
Hope this helps!
Mar 30, 2013 | Scotts Company Garden
What settings to use for grass seed
If you are planning to overseed or reseed your yard, it would be best to use a rotary spreader instead of a drop spreader. When spreading seed set the spreader on 2 or 3, It really depends on the square footage of your yard. If you purchased seed from a local nursery or hardware store, read the bag and it will have the correct spreader setting on the bag. If you just bought a few pounds and the clerk weighted it up for you, you probably can call and ask the clerk for the spreader setting. But I'm pretty sure setting 3 will work just fine.
Sep 14, 2011 | Scotts Company Scotts Turf Builder Classic...
I have a new Scotts Classic Drop spreader and an old bag of 16-4-8 fertilizer. 2,130 SF of Zoysia Zeon lawn. According to my guidance I need to spread 6.5 # of the 16-4-8 fertilizer over the entire area....
Does the product you are using list any Scotts AccuGreen spreader settings? If so, you can safely use the spreader settings listed for the Scotts AccuGreen. If your product does not list any spreader settings, please give Scotts a call at 866-465-5160.
Hilary @Scotts
Aug 27, 2011 | Scotts Company Scotts Turf Builder Classic...
I purchased my "Pro" edgeguard
The Scotts Pro Edgeguard Spreader is calibrated at the factory. This spreader cannot be calibrated, and shouldn't need to be. For further assistance, call Scotts at 877-465-5160
Hilary @ Scotts
Aug 16, 2011 | Scotts Company Scotts Pro Edgeguard...
I have an antique scotts metal drop speader # 35-3. Probably at least 30+ years old. The setting bar goes from 2 to 18. Scotts fertilizer products use different setting numbers that correspond to newer...
That model is a little over 45 years old, gotta love those metal spreaders! Many times the new Drop spreader settings will work for the older models as well, you just have to make sure it looks like its dropping at the right rate. That can be a little troublesome, but if you can estimate about 1/4 of the bag and cover the proper area for that amount you should be good to go. You can always give us a call and confirm settings with us first at 1-800-543-8873. Stacey at Scotts
May 29, 2011 | Garden
I have a 35-3 spreader and cannot find the setting rate to apply 3.5# of product to 1000 sq ft
I have a Scotts calibration bar which I used according to their instructions and the unit (a 35-3) still does not perform correctly. Therefor I used a tried-and-true method to make my own calibration.
1) get a large tarpaulin, the bigger the better. Lay it on a flat surface, as level as possible. Measure the tarp to determine the area.
2) Pick a setting. I would suggest starting with "5". Load up your spreader and go back and forth over the tarp as though it were your grass.
3) Dump what you have collected on the tarp into a container and weigh it.
4) Perform high school arithmetic operations to determine the pounds per square foot delivered and adjust accordingly. Obviously, different products will perform differently and this will have to be done for each different product.
5) Down at these low numbers it doesn't take much change in setting to make a big change in the delivery rate. The Scotts representative also noted that the speed at which you walk can affect the rate. As you walk more slowly the spreader will deliver more product.
Mar 01, 2011 | Scotts Company Scotts& Accugreeen 3000...
Need the setting for a Scotts Pro edgeguard broadcast spreader for pre-emergent
Hi, W/D here.
The spreader setting instructions will be found on the back of the bag, and you will set your spreader gate opening accordingly.
Best regards, --W/D--
Feb 18, 2011 | Scotts Company Scotts Pro Edgeguard...
Garden Logo
541 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
