Question about Video Cameras
JVC GR-D770U-Camera is in safe mode, error code 03. Tried a cleaning tape says eject tape & reinsert. Insert regular tape & it will not record at all. Any solution to this problem? Thank You....Sandra
  • Video Cameras Master
  • 2,200 Answers
Hi
The 03 Error on this JVC Camcorder is what is known as a "No supply reel rotation" error
This problem is caused by either
1) Defective reel tables, or
2) A defective rotary encoder inside the camera itself.
Unfortunately it is not a user serviceable issue and the camera will require service attention.
You can expect to pay $150 - $200 this type of repair so sorry to be the bearer of bad news.
You can try removing the battery for 10 minutes or so to see if there is any resolution although this is unlikely to happen with this type or error.
Hope this helps. Please do rate my answer. Many Thanks.
Posted on Sep 07, 2009
MY CAMERA SHOW E03 ;unit in safeguard mode ;EJECT AND REINSERT TAPE WHT SHOULD I DO............
JVCGR-D270.Digital Camcorder. When we put the tape in the cam it chews the tape whiles loading and says that it's in 03 safe guard mode. Please help.
Jan 24, 2011 | JVC GR-D73AG Mini DV Digital Camcorder
I have a JVC GR-D30U I get error E)$ eject and reinsert tape unit in safe mode. I can not eject the tape to reinsert it.
HI,
Please reset it.By removing the battery for 10min and then insert it back.Let me know the result.
Sep 01, 2008 | JVC Cameras
I'm getting an E04 ( error) when I try to record or play
Here is some information regarding the E04 error message from http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/:
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
This doesn't seem uncommon, and indicates a bad tape is loaded, or unfortunately, that the camcorder requires servicing.
May 22, 2009 | JVC GR-DVM50 Camcorder
Gr-dvl-520u trying to record or playback tape it goes into safeguard mode within 5 seconds. alternatly pressing play and still every 3 seconds advanced the playback without it going into safeguard mod
According to http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/,
If you are getting E03 or E04 errors on every tape you try, it sounds like a servicing is required.
Apr 17, 2009 | JVC Cybercam GR-DV500US Mini DV Digital...
JVC GR-D30U Digital Video Camera error E04
there was a hole under the tape deck.. u can try to force;y open it right there
Sep 01, 2008 | Cameras
Camera is a JVC GR-DF470 Video Camera. Problem is UNIT IN SAFEGUARD MODE EJECT AND REINSERT TAPE ERROR 03. I have done this and problem still remains.
I have the same model of camera and the same problem has occurred after two years of use. I am not sure why it happens but checking on other web sites, it may have to do with tape tension and the brand of tape. Up to now, I was using Sony and JVC tapes which worked fine but a recent purchase of TDK tapes seems to have caused this problem.
My fix was to take the tape out and then manually wind the tape a couple of turns by inserting one flat blade screwdriver in the tape lock tab (bottom middle of tape case) and using another to wind the tape. This appeared to fix the tape tension and after loading it back in, the tape and the camera worked fine.
Hope this helps.
May 05, 2008 | Cameras
Jvc gr-dv500u
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Sep 27, 2007 | JVC GR-D290 Mini DV Digital Camcorder
JVC-GR-D371U
Sep 25, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Unit in safeguard mode
You mix te info with Write protected tapes.
Safe guard mode is caused by the motor that takes the tape out of it's case, through the mechanics and past the video head.
If for some reason the electronics detect that it's been done by too much force, the safe guard issue promts.
Mar 29, 2007 | JVC GR-D290 Mini DV Digital Camcorder
Video Cameras Logo
102 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
