Question about Motorola Mobility SLVR L7 Cellular Phone
Slideshow How do i make the slideshow work as my wallpaper?
  • 790 Answers
No u don have that option in ur cellphone ...
Posted on Dec 09, 2007
Is it possible to put a slideshow wallpaper on my home screen?
I doubt that you can do a slideshow continuously. It would take up way too much battery. I do know that you can do a slideshow in your gallery though.
Feb 14, 2015 | Cell Phones
Tip
How to change wallpaper in Windows 7 The Windows 7 Starter edition does not...
The Windows 7 Starter edition does not include the Personalization features such as the change desktop background option.
1. Download the Oceanis Change Background Windows 7 ZIP
link:
http://www.sevenforums.com/tutorials/47294-desktop-background-change-windows-7-starter.html
Open the ZIP file and extract the Oceanis_Change_Background_W7.exe file, then run it to install it.
NOTE: Restarting the computer will be required to finish installing this program.
2.When your computer restarts, you will see this as your desktop background. Click on the Oceanis Change Background Windows 7 shortcut to change your desktop background. (see screenshot below)
3. Browse to the images that you want to use and select one, or more to have a desktop slideshow. Select the Picture position for how you want the images displayed, and any desktop slideshow settings if you selected more than one image. (see screenshots below)
NOTE: These options are just like the default ones in the other editions of Windows 7 here that are now being allowed by this program by Oceanis for the Windows 7 Starter edition.
42270d1260987873t-desktop-background-change-windows-7-starter-program.jpg42271d1260987873t-desktop-background-change-windows-7-starter-program3.jpg
4. When done, click on Save changes. (see screenshots above)
Default Windows 7 Desktop Background
1. Right click on a empty space on the desktop and click on Personalize. (See screenshot below)
2. Click on the Desktop Background link at the bottom of the window. (See screenshot below)
NOTE: The name in gray under Desktop Background is the current desktop background file name.
3. Select a Picture Location -
A) Click on the drop down arrow menu to select from the list of available picture folder locations, or click on the Browse button to navigate to the picture folder location. (See screenshot below step 7)
NOTE: To use another regional wallpaper, see the yellow TIP box at the top of the tutorial.
B) Select the picture folder and click on Select Folder.
4. Select a Desktop Background -
A) Right click on an available picture, or click (check) on the box in the upper left corner of the picture, to select it. (See screenshot below step 7)
NOTE: You can continue to right click on the images to see it previewed on your desktop until you decide which one you like best.
5. Select the Picture Position -
A) Click on the drop down arrow menu, and click on the picture position you want for the desktop background. (See bottom of screenshot below step 7)
6. For a Desktop SlideShow -
A) For how, see: How to Create a Desktop Slideshow in Windows 7
link: http://tinyurl.com/yaqll2x
7. Click on OK to apply the changes. (See screenshot below)
8. Close the Personalize window when done. (See screenshot below step 2)
on Feb 02, 2010 | Computers & Internet
Tip
Applying the settings to the logon desktop
Next, you need to apply the Screensaver settings to the Logon Desktop / Welcome Screen (Technically, HKEY_USERS\.Default registry key), so that the Screensaver is invoked when no user is logged on. Copying all the Screensaver settings to the Logon Desktop (or Welcome Screen) manually is a tough task. Use Tweak UI instead.
Download and install TweakUI.
Launch TweakUI and click Logon, click Settings.
Select Screensaver from the list box and choose Copy Now
The Screensaver settings are applied to the Logon Desktop
Restart Windows for the changes to take effect
Allow few minutes at the Logon screen, to test if the Screensaver is working properly. The Screensaver should launch after the timeout. It will look as if the Company Logo moves around.
Additional Tip
The User interface / slider allows the minimum value for picture change interval to 6 seconds only. To reduce the change interval to less than 6 seconds, alter the registry value named ChangeInterval (Set decimal value 1000 for 1 Second, and so forth) in this key:
HKEY_USERS \ .DEFAULT \ Control Panel \ Screen Saver.Slideshow
For Current user profile, make the change here:
HKEY_CURRENT_USER \ Control Panel \ Screen Saver.Slideshow
With no logon wallpaper set, Windows displays a pre-defined color for the logon desktop. ( If you have enabled Welcome Screen, press CTRL+ALT+DEL twice to see the logon screen background color. ) To change the logon background color to that of your choice, you need to alter the registry:
Click Start, Run and type REGEDIT and press Enter
Navigate to the following key:
HKEY_USERS\.DEFAULT\Control Panel\Colors
Backup the registry key by exporting to a REG file
In the right pane, double-click Background
In the Edit String dialog box, type the Color code in R G B format and then click OK.
Example: Type 0 0 0 if you want to see a Black background. You can choose any combination from 0-255
Points to ponder
If the logon Wallpaper is set, the background Color may not be visible. So, you must reset the Wallpaper value to a blank string in this key: HKEY_USERS\.DEFAULT\Control Panel\Desktop
If the Background value is set under the following Winlogon registry key, the above setting is ignored. In other words, the Winlogon\Background value takes precedence over the .DEFAULT..\Background value.
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
Cannot set as desktop
If you are unable to change or display the wallpaper of your Windows 7 or Vista desktop, try this :
(1) Open Control Panel > Ease of Access Center > Make the computer easier to see.
viswalp.jpgEnsure that Remove background images (where available) is unchecked.
Save, Apply, Exit.
This should help !
(2) If it doesnt, try this:
Run regedit and navigate to the following key:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies
Then right click on Policies > New > KEY > name it as "ActiveDesktop".
Next in RHS, rt click > New > DWORD > name it as "NoChangingWallPaper" .
The DWORD value 1 will restrict change in desktop wallpaper. To allow change give it value as 0.
Reboot.
(3) If it still doesnt work, maybe your TranscodedWallpaper.jpg file has become corrupted.
Open explorer and type the following in the adress bar and hit Enter:
%USERPROFILE%\AppData\Roaming\Microsoft\Windows\Themes\
Here, rename TranscodedWallpaper.jpg to TranscodedWallpaper.old.
Next, double-click slideshow.ini file to open it with Notepad. Empty its contents. That is, select all the text and delete it. Save the changes. Close explorer windows.
Hope something helps!
Dec 03, 2012 | Acer Computers & Internet
The colors keep changing on the laptop
may be ur wallpaper settings had been changed to slideshow mode.. chesck the settings once..
Nov 05, 2010 | HP 6735B Notebook
How to change the wallpaper in dell mini 10' inspiron
1. Download the Oceanis Change Background (http://www.sevenforums.com/attachments/tutorials/42272d1272912523-desktop-background-change-windows-7-starter-oceanis_change_background_w7.zip)
2. Open the downloaded ZIP file and extract the Oceanis_Change_Background_W7.exe file to your desktop, then run it to install it. NOTE: You will be prompted to restart the computer to finish installing this program.
3. When your computer restarts, you will see this as your desktop background. Click on the Oceanis Change Background Windows 7 shortcut to change your desktop background. (see screenshot below) 4. Browse to the images that you want to use and check (select) a image, or more than one image to have a desktop slideshow. Select the Picture position for how you want the images displayed, and any desktop slideshow settings if you selected more than one image. (see screenshots below) NOTE: These options are just like the default ones in the other editions of Windows 7 here that are now being allowed by this program by Oceanis for the Windows 7 Starter edition.
5. When done, click on Save changes.
Oct 22, 2010 | Dell Inspiron Mini 10 Notebook
Cant take off slideshow
there is an arrow on the bottom left corner of your wallpaper. press it and the drag you slideshow onto the toolbar that pops out. press the arrow again to close the toolbar.
Oct 09, 2009 | LG Xenon GR500 Cell Phone
I somehow managed to start a slideshow and cant remove it from covering my wallpaper. I dont want this slideshow. How can I remove it to where it originally looked with a simple wallpaper?
Sep 26, 2009 | LG Xenon GR500 Cell Phone
Screen saver
A single image cannot be set as a screensaver unless you are running some kind of slideshow screensaver software. Single images can only be set as background or wallpaper.
Sep 07, 2008 | Acer Aspire 5100 Notebook
Copying slideshow from hard drive to DVD
use nero 7 program u have just aint great used it dont ever do what u wann does it so use nero 7 8 ok so easy slide shows perfect quilty on dvd music dvd menu fr videos and slide shows cool icons back ground wallpapers best
Jan 21, 2008 | Roxio Easy CD & DVD Creator 6...
Motorola Mobility SLVR L7 Cellular Phone Logo
32 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
