Hi most masterful gurus, I see you've offered masterclasses in Beko washing machine repair before...I've followed all the steps you suggest (http://www.fixya.com/support/t583571-beko_wma_510_washing_machien_leaving) but my machine still refuses to spin up, leaving washing soaking. The pump's definitely working, I figure the load balance sensor may be faulty - any suggestions for where this is, whether it's possible to fix and how to go about doing it? Kind regards, Will
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
Please check the belt, if it is worn out then replace it. Also check for any losse wires inside the washer.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 07, 2009
What is needing done to stop oily smears on clothing after being washed in beko washing machine
beko front loaders use sealed bearings ..
would suggest try doing several empty hot washes with a strong liquid detergent
and as a tester ..put in a white piece of material
check for oil sludge in the lint filter
if oil persists
have it looked at by a professional
May 27, 2016 | Beko Washing Machines
REPLACE PUMP
easy
  • How to Replace a Washing Machine Water Pump: 12 Steps www.wikihow.com/Replace-a-Washing-Machine-Water-Pump
    • 4 MIN
    • 76K VIEWS
    2016-01-08 · Video embedded · How to Replace a Washing Machine Water Pump. Washing machines are durable and expensive appliances. Repairing them is often less expensive than replacing ...
  • Washer Not Draining? Washer Drain Pump Replacement (Part ... www.youtube.com/watch?v=DwV71h86Gxw
    • BY REPAIRCLINIC.COM
    • 3 MIN
    • 381K VIEWS
    2010-05-14 · This video provides step-by-step instructions for replacing the drain pump on top loading direct drive Whirlpool washing machines. The most ...
  • Geeks On Home: How to Replace a Washing Machine Drain Pump www.geeksonhome.com/how_6509829_replace-washing-machine-drain-pump... How to Replace a Washing Machine Drain Pump. Washing machines take the drudgery out of laundry day, and they're a lot easier than using a washbasin or beating ...
  • Related searches for Washing Machines replace pump
  • How To Replace The Pump in a Washing Machine - YouTube www.youtube.com/watch?v=cvyCSQMPkCc
    • BY BUYSPARES
    • 5 MIN
    • 74K VIEWS
    2011-07-13 · For all your washing machine spare parts and accessories, visit: http://bit.ly/1VKQiNZ If the pump in your washing machine is faulty or broken, ...
  • How to Replace the Pump on a Washing Machine - Bosch ' ... www.espares.co.uk/.../how-to-replace-the-pump-on-a-washing-machine- View All Washing Machine Pumps Now » How to Replace the Pump on a Washing Machine - Bosch. Is your washing machine failing to drain following a wash cycle?
  • How to Replace the Pump on a Whirlpool Washing Machine www.geeksonhome.com/...replace-pump-whirlpool-washing-machine.html How to Replace the Pump on a Whirlpool Washing Machine. The pump in a washing machine helps remove the water from the washer's tub. Water comes in through the ...
  • How to replace a washing machine pump on Aeg, Electrolux ... www.youtube.com/watch?v=yrY9R_T8qrY
    • BY HOW-2-REPAIR.COM
    • 10 MIN
    • 17K VIEWS
    2014-03-26 · How to replace a washing machine pump on Aeg, Electrolux, John Lewis, Zanussi washer dryers Please remember to mark us to your ...
  • How to change and replace a washing machine pump on ... www.how-to-repair.com > Home > Washing machines > Pumps After checking that the pump is faulty in our previous tutorials you will need to replace the old washing machine pump with a new one. Disconnect the appliance from ...
  • Whirlpool Washing Machine Pump Parts from RepairClinic.com www.repairclinic.com/.../a11b5c36/Whirlpool-Washing-Machine-Pump-Parts Shop for your Whirlpool Washing Machine Pump from our huge inventory. Return any part for any reason.
  • How to Replace Beko Washing Machine Pump www.how-to-repair.com > Home > Washing machines > Pumps This video will show you how to replace Beko washing machine pump, If your Beko washing machine is not emptying or draining the water then it is a good chance
  • Mar 10, 2016 | Washing Machines
    Wme8227s. What does code E18 indicate?
    Beko Washing Machine ' WMA Series ' Error Codes
    www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3623-beko-wma-...
    Feb 6, 2013 - ... Fault Codes. Beko WMA Washing Machines With Display ... BekoWMA Series Washing Machine Fault Codes. These fault codes are ... E18 ...
    UK Whitegoods • View topic - Beko WME7247W showing error code e18 ...
    www.ukwhitegoods.co.uk/.../washing-machine.../beko-wme7247w-show...
    Jun 19, 2011 - Hi, does anyone know what error code e18 is on a beko wme7247wwashing machine? thanks. User avatar louisebaxter: Whitegoods Newbie Beko wme7247w dc module burnt out
    Apr 27, 2014
    Bosch WAS24460GB showing error F:57
    Sep 28, 2013
    beko washer error code
    Aug 18, 2012
    Samsung B1415J showing error code EA ...
    Jan 9, 2012
    More results from www.ukwhitegoods.co.uk
    Oct 30, 2015 | Beko Washing Machines
    Washing machine wont begin a programme
    Hi sam this might help if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
    Also check all waste pipes are clear and inspect the pump I have included this video below.
    At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
    How to replace Beko Washing Machine Motor Carbon Brushes
    you might find this test video helpful but only do it if you have checked the motor
    May 17, 2012 | Beko Washing Machines
    Beko washing machine main wash led flashing
    It appears your timer/main controller/CCU has failed in this instance.
    For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
    I recommend both sites because ...
    FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
    PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
    RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
    If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
    In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
    Anything too complicated or beyond your scope should be handled by a professional.
    If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Mar 23, 2009 | Washing Machines
    Beko wma 665 w washing machine error code -c.l-
    hi
    my problem is when I try to use the machine I found the thatit didn't produce water to wash the colse ,just the washing machine start to work wiout water even I 've checked all the valve leeding te water to it.
    Aug 04, 2008 | Vacuums
    Washing Machines Logo
    91 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
