Question about GE JVM1440 Microwave Oven
I have the same symptom on my JVM1350AW
When it starts it sounds normal but makes a louder hum after about 1 second. It does not heat.
  • ray1762 Sep 15, 2009
    Your diagnosis was right-on. I ordered and installed a new magnetron and all is back to normal. I suspected that the problem was the magnetron but your response gave me the confidence to go ahead and spend the money to order the part. Thanks for your help. Well worth the $13!
  • 612 Answers
Your mag tube (Magnatron) is bad. This is what creates the heat in a micro wave. If you have it fixed, it would cost you in my area (Not sure about your area) around $170.00 plus 1 1/2 hour labor @ $69.95 per hr. Some companies go by National flat rate, it calls for $180.00 labor. If you can replace it yourself, you are looking at $157.29 plus freight for the mag tube from www.partselect.com ..
To repair. Remove unit from over stove, remove case. (Be sure to bleed capacitor off to ground before working on the insides of this micro wave. This type stores HIGH Voltage) Locate the mag tube, unplug and remove. Replace with new part. Reassemble unit and re-install. This will fix the problem.
Please rate solution
Posted on Sep 07, 2009
  • James Hilton
    James Hilton Sep 15, 2009
    Just checking. Have you repaired your unit? If so, was it what I diagnosed?
My Neff microwave H5470NOG/03 has stopped heating food, any ideas?
It has a internal Dio fuse..You have to take cover off to see it.. Warning...High Voltage...There pretty cheap...
Oct 04, 2017 | Neff Microwave Ovens
When you start the microwave it starts normally with a low hum, then a couple of seconds into it the hum gets louder. After the cook time has expired the food is still frozen. Is there something I can do...
Replace the magnetron by the sounds of it. The hum gets louder a second or so into "Cooking", that would comply with the magnetron heaters coming on and working into a dead magnetron. It could be capacitor or diode of course.
Dec 27, 2010 | GE JVM1540SMSS Microwave Oven
The microwave oven turns on but does not heat
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms, as well as the answers to this question:
- Is there any unusual noise or is it louder or quieter than normal?
We have a sound clip here of what a microwave should sound like when the cooling fan and high voltage section are working.
(A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.)
Nov 28, 2009 | GE JVM1440 Microwave Oven
Power on Turn,Turn Table Moves,but don't heat
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms ("no heat"), as well as the answers to these questions:
- When you try to microwave are the inside light, internal cooling fan and turntable all working?
Nov 27, 2009 | Maytag Microwave Ovens
NO HEAT IN "OTC" GE MICROWAVE
Nov 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave comes on but does not heat. What's wrong with it?
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms ("runs but no heat"), as well as the answers to these questions:
Nov 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave stopped heating anyting. All else appears normal.Manufactured Jan '05. Model JVM1870BF02
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit (JVM1870BF02), your symptoms (no heat), as well as the answers to these questions:
Whirlpool Model #MH1170XSS-0 will not heat
Since FixYa is not currently notifying us Experts when Clarification Requests are answered, you will need to post a NEW help request.
I
n your new post, please include your brand name and the full model number from the tag in or on the unit and your symptoms, as well as the answer to the following questions:
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Oct 07, 2009 | Whirlpool Microwave Ovens
My goldstar mv1501B won't heat anything. What' wrong?
everything works except the heating system what shell i do?
Mar 25, 2009 | Goldstar MV-1501 Microwave Oven
Microwave makes deep humming sound and doesn't heat
Your magnetron that actually does the cooking is making that humming sound. That part needs to be replaced before it starts blowing your fuse inside the microwave. That part is the one located on top behind the control panel of your microwave and is about the size of a persons hand (sometimes smaller sometimes bigger). With everthing unplugged you can take the cover off and see it. It has some cooling fins on it and is held in place with only three to four screws. There are three to four wires that come out of it and go to only a couple of places one of them being a large capacitor that is about three to four inches long with terminals at its top. Find a magnetron at a local tv repair shop (reputable), a local electronic supply house (they can order you one) or on the internet. They cost from $25 to $60 depending on size of microwave. If you can do it yourself you can save about $40 to $50. Let me know how it goes. Good luck.
Jan 22, 2009 | GE JVM1631 Microwave Oven
GE JVM1440 Microwave Oven Logo
85 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
