Question about HP Office Equipment & Supplies
My printer Offfice Jet L7480 Needs Help....My indicator was telling me tnat I soon needed to chage a couple of my ink cartridges fo I went to Staples and purchased a Full set of ink replaced they all and and found I could not print anything. the nanual to to is very incomplete and thud I now have a printere that will not print, I Need a printer so I need help. I had a similar HP printer that failed about a year ago and edded up having th purchase the L7480 now I have the problem again. I NEED Help as I need at leaset a black and white printer daily. Donald C Gage dongage@q.con (435)623-0298
  • HP Master
  • 6,487 Answers
Try first to remove all the cartridges and then put them back in and make sure you put them one by one correctly and then after that align the print head and try to print....
Posted on Sep 07, 2009
Ink light is on. which cartridge needs to be replaced
The printer's indicator lights tell you when to obtain a replacement ink cartridge by flashing when ink is low, and when to replace an empty ink cartridge by remaining on when ink is depleted. The LCD panel also displays INK LOW or INK OUT.
Even if only one ink cartridge is empty, the printer cannot continue to print.
Nov 24, 2014 | HP DeskJet 960c InkJet Printer
Bypass expired message cartridge. Cartridge is less than six months old & nearly full.
Every cartridge will have its own ID and Expiry date, please check the Cartridge expiry date, if its really expired then printer will reject it even-though the cartridge is full.
We cannot bypass cartridge errors for single cartridge in INK-JET printer, because they work in TIJ technology (Thermal Ink Jet) which needs all cartridges to be functional unlike Laser-jet printers.
Regards
Riztech
Jan 13, 2011 | HP Officejet Pro L7590 All-in-One InkJet...
How to replace the ink cartridge
1. Look at the indicator light on your Lexmark printer. You'll need to replace ink cartridges when the light flashes or turns red instead of the standard green.
2. Purchase Lexmark ink cartridges. You can buy the brand name or purchase a generic version that is compatible with your printer. You can shop for low cost ink cartridges from ABC Ink.
3. Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
4. Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
5. Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
do rate the solution if it helps
Nov 26, 2010 | Lexmark X1240 All-In-One InkJet Printer
Lost my manual, need to change the ink cartridge, help
  3. Step 3 Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
  4. Step 4 Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
  5. Step 5 Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
Apr 24, 2010 | Lexmark C533DN InkJet Printer
I'm trying to find replacement ink cartridges for my Lexmark X2690, per the service center and it tells me I need (for the Black) #4, or #4A, and (for the Color) #5, or #5A and also #31 for photo color. My...
Sorry...No other numbers. Have you tried Staples? They have free shipping over $50. I have had pretty good service through them.
See:
Staples Ink
If that link is not good, I will post another.
Thanks for using Fixya.
Oct 08, 2009 | Lexmark X2690 All-In-One InkJet Printer
Printer won't recognise new colour cartridge
I got a new print head @ "staples" office supplies. It didnt cost me anything!!! Kodak had probs with the head, & gave a bunch to staples.....i changed the head, put in new inks, again...got a calibration to run...& things printed np!!!
Apr 14, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Black ink only?
No, the answer is not.
printer need all fo the ink cartridges in order to print.
Feb 09, 2009 | HP Color LaserJet 2600n Printer
Will not print at all
are you using generic toner or brother toner?????
Jan 05, 2009 | Brother HL-2040 Laser Printer
HP OFFICE JET PRO L7500/L7600/L7700
my hp office jet pro l7500 indicates the ink has expired in all cartages but the cartgages are new because they were just put in . Before the same error code came up and so bought new cartages. Also the door to the cartages will not stay closed without tape.
Nov 29, 2008 | HP Officejet Pro L7480 All-in-One...
Ink replaced, but sows nothing
A yellow exclamation mark in any application means the attatched item to it is usually in error state, but you say the printer works fine. Most people would tell you to not touch what is working!!! But leaving anything showing error risks further confusion and problems. I think that you problem is probably very simple. Do you know hao to reset your ink levels. Read your manual that came with disk or go to the onscreen help. You may find this will remove the issue. If it does not, then you may have a corrupted driver etc, and may need to uninstall the printer, and reinstall it again. Good luck.
Aug 30, 2007 | HP Photosmart C3180 All-In-One InkJet...
19 people viewed this question
Seeker5211
Seeker5211
