Question about Frigidaire Affinity ATF7000E Front Load Washer
Cant find access to the drain pump? My front load affinity will not pump, so I thought I could check the drain pump, where do I get access to punp?
  • champ3 Sep 07, 2009
    acess in front door/ remove rubber boot.
    Problem Solver:
  • 14 Answers
If it does not have an access panel on the lower front, you have to take the entire front and top off. it is under the drum on the right side. A lot of times it is the strainer clogged at the pump. Hope that helps.
Posted on Sep 11, 2009
My Frigidaire Affinity front loading washing machine model #ATF6000FS1 won't spin when loaded.What's the problem?
sounds like you have something in your pump stopping the water draining it will not spin with water try unblocking the punp
Sep 27, 2012 | Frigidaire Affinity Washing Machines
Fridgidaire Affinity front load washer not draining
It is your pump it is probably clogged not the hose the actual pump mine was full of hair and a quarter. so it would not drain.
Aug 27, 2012 | Frigidaire Affinity ATF7000E Front Load...
Fridgidaire affinity not pumping out water
Possible the drain pump is defective , check voltage to the pump during the drain cycle to confirm that the program controller is outputting voltage to the pump.
Check this link: drain pump replacement
Jul 04, 2012 | Frigidaire Affinity ATF7000E Front Load...
At first I thought it would rinse or spin. I went out to get towels & they were soaked. I removed some towels/blankets because I thought it may be too heavy...after several attempts I removed...
Hi tinawagner,
Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 11, 2011 | Frigidaire Affinity ATF7000ES Front Load...
My frigidaire affinity washer doesnt spin during the rinse cycle.
Hi javierc569,
Before the Spin Cycle should start, all water must be drained out of the machine. If it does not start, it could likely mean the Drain pump may be clogged. Please follow my below tip on the fix:
Kind Regards
JEDEMEYER1
Jul 26, 2011 | Frigidaire Affinity ATF7000E Front Load...
How do I access the drain pump on a Frigidaire Affinity front loading washer?
If you cant access it from the front You will have to tilt the machine back as far as safely possible to access the bottom of the machine. Locate the drain pump which will be at the bottom font or back corner and remove the hose that connects the pump to the tub, you will need to have a basin ready to catch any water. You most likely have a sock or something stuck. Hope this helps
Mar 01, 2011 | Frigidaire Affinity ATF7000E Front Load...
I have a Frigidaire Affinity LTF 8000 washer that will not complete the spin cycle. Items are still completely wet when wash is "finished". Even in "spin only" mode, I can hear the...
If you cant access the drain pump from the front then you will need to pull the machine out and tilt it back as far as possible safely, this will allow you access to the bottom of the machine and the drain pump. You will need a basin to catch any water that will come out when you remove the drain pump. The pump should only be held in by 1 or 2 screws and pulls or twists off. If the pump is clear then you will need to remove the pipe that goes from the pump to the drum to check for blocks, commonly a sock is blocking it. hope this helps
Feb 23, 2011 | Frigidaire Affinity ATF8000FE
WHAT DOES E20 MEANS ON A FRONT LOAD
Hi
Error code e20 means a clogged drain pump. This might have happenned due to small clips, pins, coins, etc being stuck in the pump. Please note that error e20 can also occur when the drain pump is not pumping fast enough or when the pump fails. To fix the issue you'll need to check the drain pump.
Remove the 2 screws from the bottom of the front access panel, it will come off. Now check for the pump on the right side and remove hoses from it. Remove pump from machine then clean the debris from the pump. Make sure that you have a container to collect water nearby when you are removing hoses from the pump, as ther would be a lot of water. Please post back for any further assistance.
Daniel
Aug 02, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Affinity ATF7000E Front Load Washer: where do i find what efo means on my affinity wash...
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
May 16, 2010 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF7000E Front Load Washer Logo
598 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
