Question about Dacor DMT2420 1200 Watts Microwave Oven
The touch pad fades out and now won't work.
The touch pad has been fading and going out for some time.  Sometimes a breaker re-set woud bring it back, but only temporarily.  I was futzing with the inside electronics and a ribbon connector pulled out easily and now nothing works.  Good job, huh?  Who do I call?
I'm in Portland, Oregon and my wife is about to kill me.
  • Sandra Williams Feb 18, 2008
    We do and have had the same problem for some time, our model type is
    PMOR30S . It has done this for quite a while and occasionaly comes to a clear screen.. Our model is an over the stove type, around 7 years old.
  • Dacor Master
  • 9,098 Answers
We regularly repair these for customers nationwide with our guaranteed $39.95 service.
Full details of our service are at but if you still have questions, please reply back.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 09, 2007
  • William Miller
    William Miller Mar 20, 2008
    To sandrajoy (and all)
    We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service with a full one year warranty.
    We have full details, plus *critical* safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa:
Electronic control no working today, managed to get oven on can't turn off.
It may be on auto cook? Try unplugging the unit for 10 or 15 minutes then plug back in and see if it resets itself. Set the clock to correct time and start again. If it is still playing up, the touch pad membrane may be faulty. Don't use spray cleaners on these touch pads, it ruins them.
Sep 06, 2017 | Microwave Ovens
Buttons not working on 900 watt microwave, it's only a month old. How do I fix or must I return to store?
May i ask , is this a GE?
Have you un-plugged it and plugged it back in? You can try this to see if it needs re-setting.
I don't know how mechanically inclined you are but if you comfortable with this idea you can take the touch-pad off yourself and inspect the ribbon cables that supply power to the touch-pad. These ribbon cables work slightly loose sometimes and all they need is to be re-seated back into their connector which is pretty simple to accomplish.
There should be 2 screws or maybe 3 on the top (front) panel of the microwave. Remove these then once the panel is removed you can access the 1 or 2 screws (1 Usually) that holds the touch-pad in place. Remove this screw and lift the touch-pad up and out. Remove all wires from their connectors and don't worry about , if you can replace them to their correct connectors , many times the connectors are all different and can only accept 1 wire when re-installing.
Inspect your ribbon cables and their connection. I would even disconnect them and re-connect just in case there is a faulty connection.
Sometimes the ribbon cables need to be removed and clean the connections with alcohol but in your case you have a new microwave so i don't see dirt or debris being an issue.
Of course , unplug the unit from the wall if you decide to take on this task.
If this doesn't work i would return the microwave. If your like me i like to inspect things and take on new tasks sometimes just to try and fix things to have something new under my belt. Anyways i hope this is helpful and good luck.
Oct 15, 2016 | Microwave Ovens
H7871SOGB/03 combi. Why isn't it working?
The fact the breaker in the fusebox tripped indicates a fault in the appliance that is probably safety related. If it was the mcb (micro circuit breaker) it indicates a sudden overload. If it was the rcd (residual current device) it indicates there might have been a live circuit shorted to earth.
The fault is likely to be internal and it is potentially dangerous for unqualified people to fiddle about inside microwave ovens. Many brands are cheap throw-away items these days because a visit to the repair shop tends to cost more than a replacement.
The Neff brand is a premium brand and although repair costs are expensive it is likely to be (marginally) cheaper than a replacement.
Sep 04, 2015 | Neff Microwave Ovens
My stove is a frigidaire gallery series and my oven won't at all. Error F7 pelase give me a solution
f7 normally is a control issue either the touch pad or the control board inside the unit... turn the breaker off to unit and try to run your hand over the keypad pressing firmly on all the button ..reset the breaker afterwards usually a 50 amp ciruit and see if it still does it.. the ribbon cable on the touch pad has either failed or the control board itself... common problem with these units.
you may luck out as sometimes the keypad will get stuck and by resetting will correct problem...
Jan 13, 2011 | Microwave Ovens
Won't start sometimes, can't set time clock, starts when i touch stop/clear pad, won;t stop unless I open up the door. denmore model 72180413
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
Sep 18, 2010 | Microwave Ovens
Touch screen fading in & out, unit works fine
You can get that repaired for $39.95 in most cases (details here) or order a control / display unit here.
Jul 27, 2010 | Dacor DMT2420SS Microwave Oven
The clock works & counts down but the microwave won't heat
  • Disconnect the power for 30 seconds. After restoring power, do not set the clock.
  • If your model has an ON/OFF clock display, you can choose not to have the time displayed. To choose this option, press the 0 pad for about three seconds. To Turn the display back on, press the 0 again.
Touch the clock pad. Enter in the correct time of day by touching the numbers in sequence. Touch the clock pad again.
Aug 03, 2009 | Sharp R-1460 Microwave Oven
Dacor DMT2420 1200 Watts Microwave Oven Logo
98 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steven Clarke
Steven Clarke
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
