Question about Dryers
Our Maytag gas dryer is having heating problems. Our burner is intermittent some times it comes on and goes off in a minute sometimes it doesn't come on at all.
  • Controlfrk
    Controlfrk May 11, 2010
    This problem is usually caused by a bad coil on the gas valve. To get any more help you will need to post your model number.
    President:
  • 1,776 Answers
This type problem is usually caused by faulty gas valve coils. These electrical coils are right above the gas valves and when energized, these solenoids open the gas valves and permit the burner to light. Faulty coils can cause this type "cycling" problem. If any are suspected of being faulty it is recommended that both (all) be replaced at the same time. Sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 07, 2009
I have a Maytag MDG9606AWW gas dryer. The heat is intermittent. What part is most likely to need replacing?
Although it could be several things, the three most likely suspects is the radiant sensor P/N 338906, the thermostat P/N 303395 if there is a temperature fluctuation but the burner is active. The gas valve P/N 306176 if the burner is not active. Intermittent problems are very hard to troubleshoot so you need to write down every indication and when it happens. For example: Works good on permanet press, but not on high.
Hope this helps. Hal aka ImJustAvg
Dec 17, 2011 | Whirlpool Dryers
Igniter comes on will not let the gas in. The gas burner does not come on Maytag model dg882s
Your have one of two problem causing the gas to not come on on your dryer.
1) the flame sensor is bad...if the igniter comes on and stays on and doesn't go off...usually within 1 minute the flame sensor isn't working as its supposed to
2) the coils on the gas valve could be the problem...if the igniter does indeed go off within 1 minutes and as soon as the igniter goes off if their is no flame the coils on the gas valve is what would need to be replaced
here is what each part looks like
FLAME SENSOR
Sep 14, 2011 | Maytag Dryers
My Legacy Series gas dryer only gets hot intermittently - sometimes it works sometimes it doesn't :(
A very typical problem with gas dryers is a weak coild that open the gas valve...this tip i wrote goes into more detail about why your gas dryer works intermintely
http://www.fixya.com/support/r10174506-gas_dryer_starts_off_hot_but_after_while
GENE
Sep 06, 2011 | Maytag Dryers
Maytag mdg6700aww dryer clicks to start the igniter. Sometimes the burner ignites, other it doesn't and I can smell raw natural gas from the vent. Not drying. Help
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 14, 2011 | Maytag Neptune MDG6700A Gas Dryer
Intermittant heating
heatman101./';
Aug 06, 2011 | Maytag Dryers
Fires intermittently
heatman101
Jul 09, 2011 | Maytag MGD9700S Gas Dryer
Gaqs dryer does not dry no heat igniter comes on but only for short time. sometime burner lites but only for a few seconds
heatman101][\
Jul 01, 2011 | Maytag Neptune MDG9700A Gas Dryer
Intermittent no heat/extended dry time
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 20, 2011 | Maytag Dryers
Gas dryer burner intermittently lights. Foul gas
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 17, 2010 | Estate TGDS680EQ Dryer
Intermittant Heat on Gas Dryer
Check the venting tube. It maybe clogged full of lint somewhere inside of it. If so the moister contro sensor will shut off the burner within due time such as yours
May 01, 2010 | Maytag SDG4606A Gas Dryer
Dryers Logo
93 people viewed this question
Top Dryers Experts
