Question about RTO Chair Rail Molding Router Bit
How to install chair rail when your wall edges are round
  • 10,865 Answers
You will have to either buy or make a piece that will square off the corner for you. if you have two 12" long pieces of say 1x6 and you use them to create a right angle and mount that to the wall where you want the chair rail to go you will see what I mean. For a more decorative look check out the moldings at any home depot.
Posted on Sep 07, 2009
I need to know how to charge the batterie om my sisters merits wheelchair,i do not know how to plug it up,,or if the charger is located on the frame someplace or if its freestanding.plain and simple i do...
sking the off board charger is a 5 inch by 3 inch rectangular box with a power plug on one end and a round silver 3 prong plug on the other. The charger plugs into the charger port located under the front of the joystick. Plug the charger plug into the joystick and then into the wall socket. When it is fully charged the light on the chrager will turn from yellow to green. Unplug the power from the wall socket first then unplug from the joystick In ither words always have the charger unplugged when you plug the charger up to the chair Now if the chair has an onboard charger there should be a power cord that just plugs into the chair usually somewhere in the rear of the chair all you have to do is plug it into a wall socket and charge away Hope this helps you
Mar 10, 2011 | Electric Mobility Merits Electric...
Hello i have a mildly used FR350 round head framing nailer. the problem is that it will shoot two or three nails then jam up? thanks todd
This gun is very reliable unless tip is broken or miss-shaped and or wrong nails are being used. Depending on model # could be clip head or full round. For best results do not use generic nails because they are not the exact angle required. Place a strip of nails on outside of rails with nail-heads aligned with edge of rails. The first nail should align with path of the driver (place a straight edge alighed with path of driver). Most generic nails do not align correctly. Good luck
Feb 28, 2011 | Porter Cable Air Tools & Compressors
What is the 3 prong outlet on the side of my chair for? Is it a charger?
If you have an on-board charger for your power chair this outlet is for your charger cord. One end of the AC cord plugs into the wall outlet and the other end plugs into the trapezoid shape outlet on the side of the chair. This is the same shaped AC cord used to power computers and other devices. You can buy one a most hardware stores and places like Radio Shack. If you are using an off board charger which plugs into the front of the joystick (round plug)to charge the chair, then you don't need to use the on-board one and you don't need another AC cord. Hope this helps.
Dec 04, 2010 | Jet 3 Ultra Power Chair
I think this is the chair I have, but I can't find the black plastic seat rail guides (back) that the seat glides on when opening and closing the chair.
These are called top rail guides and are made of white or black high density plastic. They are available from The Aftermarket Group or New Solutions. They should be a standard size in my experience. To install simply remove the crossbar bolt (X-bar) and put in two new guides. Reinstall X bar bolt and spray with silicone spray to help with easy folding. PAM kitchen cooking spray works too.
Sep 13, 2010 | Drive Medical Health & Beauty
Hi we just bought a maax breeze neo corner shower how do i install the two back walls do you use glue or what?
There will be a nailing flange on the walls of your shower. Typically, drywall screws are used on this flange on the top portion and along outside edges spaced 6-8" apart. Use a high quality tub/shower caulk down the seams.
Nov 19, 2009 | Maax Breeze: Two Piece Round Shower Module...
Dryer Hookup
Simply move the dryer back against the wall.
Take a straight edge and place it at the 12 o'clock position on top of the dryer vent. Touch the wall with the straight edge. Mark the wall. Cut a 4" round hole below the wall mark.
Adjust dryer levelings legs if necessary.
May 05, 2009 | Dryers
Have all items in professor laytons decoraters house
the easiest way to tell you is give you lukes stuff
round rug blue bed bear bookshelf books tv green chair desk lamp violin globe and world map every thing else goes to prof layton
Apr 01, 2009 | Nintendo DS Console
How do I use an 8" T bevel?
put it against the wall so it touches both walls. Then lock it in place with the nut. Next if you have a power miter saw lay it on the table and move the blade so it lines up with the angle thay you have then it will give you the angle for the cut.
Good Luck
Dec 28, 2008 | Swanson 8 Inch Sliding T Bevel
We don't know how to fix an integrated towel rail to the basin
Hi stickybrfc,
I'm Harvey the Master Plumber.
Your statement is: You have purchased a corner basin with integrated towel rail but there are no instructions to fit the rail onto the basin. various fittings & screws but no instructions.
I'm going to assime this is a wall hung sink.
The amount of parts will depend on whether it has a round front, straight front or square front. Installation is basically the same. The rod holders have a U shaped connection for the bottom of the apron (the screw goes in the back). Install the first one then a rod then the next one till you're done. You may need a helper to hold things in place till it's secure. Snug up the screws but DON"T OVERTIGHTEN. I find it helpfull to put a little piece of hard wood or rubber between the back of the apron and the screw.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 10, 2008 | Home
RTO Chair Rail Molding Router Bit Logo
105 people viewed this question
Top RTO Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a RTO Tool and Hardware - Other Expert? Answer questions, earn points and help others
