Question about Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive
I am trying to transfer my old computer files to this hard drive which I will then transfer to my new computer. It says there is not enough room.
    Problem Solver:
  • 12 Answers
Make 2 or 3 small transfers as opposed to one big one. The less information that you try to move at once, the less chance of total corruption of all of your files.
Posted on Sep 07, 2009
Need to transfer files from old computer to new Hitachi 3 terrabyte drive
The need to transfer files from one hard drive to another is common when restoring from backup, to make more room on a drive by archiving files or to copy or move files to a portable hard drive. Whether the destination drive is an installed second or third hard drive or is a portable hard drive, the procedure to transfer files from one hard drive to another remains the same.
Plug the destination hard drive into the computer if the drive is portable, and confirm that the computer has recognized the hard drive with a pop-up acknowledgment message. Click the "Start" button then click "Computer" or "My Computer," and then double-click on the icon of the hard drive that contains the files to be copied. When a window appears displaying the contents of the hard drive, navigate to the location of the files to be transferred. Click on each file to be transferred while holding down the "CTL" key to select all files to be copied. Right-click on one of the files that has been selected and click "Copy" in the menu that appears if you wish to leave a copy of the files on the hard drive, or click "Cut" in the menu that appears if you wish to move the files instead. Double-click on the icon of the destination hard drive in the "Computer" or "My Computer" window to display the contents of the hard drive in a new window. Navigate to the location on the hard drive where the files are to be saved. Double-click on the destination directory to open the directory and then right-click on blank space inside the directory window and click "Paste" on the menu that appears. A window will appear and display the status of the file transfer and disappear when the file transfer is completed. Hope this helps.
Jan 07, 2013 | Computers & Internet
How to transfer files from old to new computer
You have a number of options. You can buy a usb cable male to male and transfer. Connect a usb stick large enough to connect and copy them there. Alternativley you can remove the harddrive from the old computer and put it inside the new one as a secondary drive or move them hard drive to hard drive. Hope this helps.
Oct 20, 2012 | Dell Inspiron 620 MT Desktop Computer...
How to download my file from my old computer
The simplest way to transfer files from your old to your new computer is by using USB flash drives. Just save your files from the old computer onto the flash drive then plug this USB drive in to the new computer and save the files there. If you have large files, you can also use an external hard drive to copy and transfer files.
Mar 22, 2011 | Computers & Internet
Can't transfer my email files from old computer to new computer
Good Day!
To transfer files from an old computer you can use USB or flash drives, copy the files from your Old Computer to Flash drive, after copying---attach the flash drive to your new computer then copy the files and save it. This is the easiest way to transfer files.
Other way of transferring;
-You can also transfer files by Burning your files into a CD/DVD and copy it to your new computer.
-Get your hard disk from the old computer and attached it to your new computer
-Or connect/network your two computers.
I recommend USB or Flash drives, the simplest and easy way.
Hope I was able to help.
Jul 16, 2010 | Microsoft Windows XP Professional for PC
I'm trying to sync my files from my old computer
no you can what you have to use is files and setting transfer wizard in windows xp you can start the Files and Settings Transfer Wizard by clicking Start on the computer running Windows XP, pointing to All Programs, Accessories, System Tools, and then clickingFiles and Settings Transfer Wizard. (If both computers are running XP, you can start with either one.)
just select "i want create wizard disk in following drive " and select you external disk drive tha will do the trick...
Apr 11, 2010 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
I have a 16GB Cruzer Flash Drive. When I try to transfer a file that is just under 8GB to the Flash stick, it tells me there isn't enough room....
Check the propeties of the Flash drive. It it most probably formatted using the FAT32 file system, which does not allow files larger than 2GB.
There is a way to format a flash drive using NTFS file system, but you will lose some capacity of the drive, and transfer speed will be a bit slower, gaining in return a possibility to transfer larger files.
Go to the following webpage for instructions:
http://www.online-tech-tips.com/computer-tips/format-usb-ntfs/
Dec 03, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Transfer all files from my old desktop to new laptop
you can do that by following the steps below;
Instructions
  1. Step 1 Connect your laptop to your desktop through a home network connection. If you have a home network, you can hook up your laptop to it via an Ethernet cable or a wireless network card. Then, you can set a folder on your desktop computer to be shared across the network. To set a folder as shared in Windows, simply right click on it, select "Sharing and security," select the "Share" tab and check the box labeled "Share this folder on the network." You will then be able to access this folder from your laptop and transfer files to your.hard drive.
  2. Step 2 Purchase a USB jump drive. These handy devices are the size of a key but can store five gigabytes of files or even more, depending on the type of USB jump drive you buy. Insert the USB jump drive into your USB port and your operating system should find it as new hardware. If a window doesn't automatically come up, you can find in your drives under "My Computer." Then, you can click and drag files into it, remove the drive and take it to your desktop computer and access the files there.
  3. Step 3 Put your files onto another external storage device, such a CD, floppy disk or external hard drive. Files are transferable between any computers as long as you can store them on something external, then use that external device to move them to the other computer.
  4. Step 4 Email files to yourself. If you only have a few files that you would like to transfer and don't have any of the equipment used in Steps 1 through 3, send yourself an email with the files attached, access your email from the other computer and download the files to your hard drive.
Sep 10, 2009 | Dell Computers & Internet
Toshiba Gigabeat S 30GB Transferring error
You do not have enough room on your computer hard drive. In Windows XP, try a Disk Cleanup. This can happen when you've got a system more than a year or two old, and want to copy the whole 30GB or so.
Dec 20, 2008 | Toshiba gigabeat MES60VK Digital Media...
Saying I can't copy 9gb file due to lack of free space, 433bg still showing free
that might be due to the drive being formatted as Fat32 which has a file size limitation of 4 Gig..open up my computer, and look at the properties of that drive..right click..and that might help you
Oct 15, 2008 | Western Digital 500GB My Book World...
Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive Logo
83 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
