Question about Labtec LCS 1040 Computer Speakers
Wiring internal board of labtec computer speakers
Having trouble figureing out how to re-wire internal board of Labtec LCS-1070 computer speakers.
The speakers still powered on, but lost sound, so I took it apart and the wire leading from the internal board and the on/off volume knob came apart (separated from another wire). The other wire it was hand taped together to was the wire that gets plugged into the computer. It led to the source (the computer output sending the sound to the speakers).
Now I can't figure out how the wires should be attached back together.
Stipped down, the wire from the board or the volume on/off knob contains a green, yellow and main shield wire. These were attached to a source wire which gets plugged into the computer and it contains a red, white and shielded wire.
How do I properly reconnect the power knob wire (the green, yellow and shielded wire) to the wire that leads to the source (the red, white and shielded wire)? I know these two go together somehow because I took them apart myself and they were not connected to anything else. Just to each other.
  • 247 Answers
The shielded wires are for ground, so they get connected together. Plug the wire into the PC and run some music. Then touch each wire to the others. You only have a couple of combinations to try...red-to-green and white-to-yellow, or red-to-yellow and white-to-green, . You can do this while the PC is one and music playing until you get sound thru the speakers. There virtually no current running thru the wires and you can't hurt the PC by doing this.
If the speakers use an external power supply, have it plugged in and working when trying these connection options.
Posted on Sep 07, 2009
Testimonial: "Totally what I needed. Thank you very much for your help! It's my first day on a website like this and I'm a believer already.. "
    New Friend:
I connected like this didnot working wiring internal board of labtec computer speakers - 882aed92-be83-4b40-a0c0-6f92b94dde51.jpg
Posted on Oct 14, 2014
Opening Labtec speakers type LCS-1030
To open these you need to pull the front grille off. There are four screws, one in each corner. You'll need to do a bit of prying to get it open as the case is sealed around the edges, but it isn't too terribly difficult. Just take your time.
Mar 03, 2012 | Labtec LCS 1030 Computer Speakers
Labtec lcs 150 disassemble
Three screws (each speaker). One visible in the rear at the top, two more hiding in the battery compartment. Good luck. Broken wires can be re-soldered. Speakers may be replaceable (though in this disposable age your sources are drying quickly). Otherwise, off to Amazon for new speakers.
Jan 09, 2012 | Labtec LCS 150 Computer Speakers
I can't find a driver to install my labtec LCS 2424 speakers
Most speakers do not need any sort of software. All you have to do is to plug it in
Jul 21, 2010 | Labtec LCS 2424 Computer Speakers
No wires for labtec lcs-3210
1500mA @ 15VDC. I've got a set of these speakers and I just looked at the adapter.
Jun 21, 2009 | Labtec LCS 3210 Computer Speakers
Labtec LCS 1024
I don't have a wiring diagram for you but can tell you this as standards apply.
Red is always the positive (+) terminal and black the negative, ground, (-) terminal. FYI-though people use the term ground it is not correct.
Another thing you should know is red and black are relative. Inother words, when red to red and black to black it will cause an outward motion of the speaker. If you happen to reverse them, red to black, it just causes an inward motion of the speaker. Sometimes this is refered to as the "phasing" of the speaker.
Speakers are usually marked at their connection points with a red dot or a (+) for the positve and a black dot or (-) for the "negative" side.
So there's nothing to worry about if this happens anyway except:
if you were to go red-black on one speaker, and red-red on the other. This will cause the speakers to be in series which normally wouldn't hurt things, but make sure it's not done just in case you amp section cannot tolerate this condition.
Hope this helps.
Jeff
Mar 19, 2008 | Labtec LCS 1024 Computer Speakers
Schematics
Dclf1
Good day!
First things first:
1) you only can find those schematics on
http://www.labtec.com/index.cfm/service/splash/AMR/EN,CRID=3
but have to call or email support.
hope they can send the info.
Open Sky
Feb 09, 2008 | Labtec LCS 1024 Computer Speakers
Labtec LCS 1040 Computer Speakers Logo
805 people viewed this question
Top Labtec Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Michael Galve
Michael Galve
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Labtec Audio Player and Recorder Expert? Answer questions, earn points and help others
