Question about Maytag Dryers
Gas dryer won't fire off. all safties are closed and the ceramic glow coil does light up.
  • Controlfrk
    Controlfrk May 11, 2010
    In order to be helped with this problem you will need model number.
  • 26 Answers
This is likely the result of a bad radiant sensor (mounted on the burner cone).
Posted on Sep 08, 2009
My Kenmore gas dryer wouldn't heat up, took back of it off,not enough lint to cause problem. exhaust duct was clear, ignighter glows, I even get fire (with face removed and drum out). I kicks off 10...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 19, 2011 | Dryers
Kenmore gas dryer 80series model 110.c72852101
if you hear the valve clicking but no gas the valve is bad.when the burner lights theres a probe that senses that it is lit and sends a microvoltage back to the controller to tell its lit.check to make sure all ground wires are grounded to a clean metal surface.
Oct 03, 2007 | Kenmore 74602 Gas Dryer
Hi, I have a Kenmore gas dryer model 417. I can't
Sounds like the coils on the gas valve are bad.
May 26, 2011 | Kenmore Dryers
Dryer won't heat up
When is the last time you cleaned out the dryer venting? May be a blockage that is causing the no heat problem. Check directly behind the dryer and also outside at the vent cap. If it's a gas dryer, it will not have a heating coil. The gas burner lights with an igniter. Does the igniter glow orange when dryer is first turned on? If not, it may be broken. Look for broken ceramic piece below where it attaches and replace. Do not touch the ceramic piece on the new igniter, as it is very fragile.
May 15, 2010 | Frigidaire AGQ7000E Gas Dryer
My gas drier turns the heat on for a minute or so and turs off.
Sounds like the glow bar is comming on but no flame. Make sure the gas is turned on.
If still not working the problem might be one of the safty coils on the top of the gas valve may have an open circuit or the glow bar sensor may have an open circuit.
Depending on your skill level
unplug the dryer and shut off the gas. Using a multi meter check the resistance of the safty coils on the gas valve. There is a coil replacement kit you can purchase to replace the gas coils. Check the resistance across the glow bar sensor. It is located on the gas funel. It is a little black box with two wires comming from it. It should be a closed circuit untill it senses the light of the glow bar then the circuit will open allowing the gas valve to open. If open, replace.
Dec 27, 2009 | LG DLG5932W Gas Dryer
Dryer will not heat
On the maytag gas dryer there can be a couple of problems.
1) there is a safty switch on the modor start switch that has to close befor the gas can come on.
2) There are safty coiles on top of the gas valve. Sometimes one of these may be burnt out. You have to check the resistance of each coil.
3) There is a light sencor on top of the burner funnel( a little black box with two wires comming out of it.) This can malfunction some times.
Not always an easy solution. Lots to check.
Dec 22, 2009 | Maytag Neptune MDG5500AW Gas Dryer
The dryers does not light
I will be happy to assit you with this issue
I have a web side that will help you.
http://www.youtube.com/watch?v=f1rebeCMVsk&feature=fvw
was this helpful?
your rating is very important so I can help others.
thank you
Oct 18, 2009 | Kenmore Dryers
GLOW PLUG WORKS BUT ONLY STAYS LIT FOR 30 SECONDS
HI, there are a set of coils on the gas valve assembly that have gone bad. these coils are responsible for the opening and closing of the gas valves. your coil assembly is damaged, in return, causing this interruption.
simply replacing the coils will fix this issue.
May 28, 2009 | Amana Dryers
Whirlpool LP dryer will not light. model LGR7646EQ2.
the ceramic ignitor probably is broke. turnoff power and gas, then remove burner assembly ther are two screws holding it in. also loosen gas connecter .pull burner out an visibly check igniter you most likely will see the ceramic coil broken remove it and bring it and model # to a part house then reassemble burner
Jan 26, 2009 | Dryers
Kenmore Dryer only lights gas sporaticly
replace the igniter. The ignitor is the most comon problem with gas appliances checking continuity does not tell you if it is bad or not it has to draw a certain amount of amps to open the gas safty valve and the is no safe way to check this on most gas dryers
Jan 19, 2009 | Kenmore Dryers
Dryers Logo
56 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
