Question about Blackburn Cycling
Blackburn pump, switch from schrader to presta? can't figure out how.
  • 26 Answers
You will find conversion instructions in the following PDF:
http://www.blackburndesign.com/manuals/blackburn_pump_manual.pdf
Posted on Sep 08, 2009
Fill air in tires
Depends on the tube valve type (Presta or Schrader). Some tire pumps are for Presta, some for Schrader, and some for either.
Schrader valves look the same as your car tire, while Presta valves are skinnier, and need to be unscrewed, at the top, to fill.
You only need an adapter if your pump and tube are opposite.
Mar 30, 2014 | Trek 7.3 FX
My innertube leaks air and i am no familiar with the air intake device on it
There are two kinds of valve on bicycle tubes, Presta and Schrader. You are probably more familiar with Schrader because this is the type used on cars and most bikes. And I am guessing that you have Presta on this bike (Presta is skinnier than Schrader, and it has a little nut that you unscrew, where Schrader has a spring inside it. Google images for "Presta Schrader" and you will see both kinds, and you will also see a little screw-on adaptor that you can use on a Presta to make it fit your pump or air-hose like a Schrader. You can buy these adapters on-line or at any bike store. Good luck!
Oct 03, 2012 | Fuji Bicycles Cross Comp
How do you inflate this tube with the presta valve?
The following link is a good explanation of inflating a presta valved tube if you have a pump with a presta valve head.
If you have an older pump that does not have a presta valve head, you can purchase a schrader valve adapter from your local bike shop that screws onto the presta valve and will allow you to utilize a pump with a schrader head.
A good explanation can be found here: http://bicycletutor.com/presta-valve/
Feb 18, 2011 | Cycling
How do you fill the tires on this bike. The valve stems are not typical bike tire stems. I am (obviously) a novice biker and have not owned a bike in several years. The pump I bought is a Schwinn pump...
There are two types of valve stems, schrader ( like the valve stems on your car ) and presta. See images on this page http://www.sheldonbrown.com/brandt/presta-schrader.html Since you are asking I assume you have presta valves. You can get an adapter to convert the presta valves for use with a schrader pump. Unscrew the small knurled nut on top of the presta valve to open it, press down and release the small top to ensure the valve is free to move. Snug up the top when it is full.
Dec 23, 2010 | Schwinn Midmoor 700c Men's Hybrid Bicycle
How do I switch Schrader to Presta using my Schwinn Aluminum Frame Pump
If your pump only has one hole for the valve either one should fit in. If it has two than the Presta fits in the smaller one. Hope that helps.
Oct 04, 2010 | Cycling
How do I pump a presta valve with the Blackburn Mountain Air Bike Pump 4 Bicycle
They should be designed to fit both styles of valve, but you need to reverse the seal.
you should be able to unscrew the end, remove the sealing rubber and a plastic fitting that pushes on the valve, replace them the opposite way around ,and they will fit the presta.
Aug 22, 2010 | Blackburn Mountain Air Mountain Bike Pump...
My Blackburn air tower 3 pump won"t work.When attached to the Presta side air leaks out the schrader side and when attached to the schrader side air leaks out the presta side. What can I do?
I had the same problem, Blackburn knows about the defect. All you have to do is call their 800 number and if everything goes as it did for me, just tell them your name/address and they say they'll send a replacement head. We'll see if it gets here in the next 7-12 business days.
btw, the new replacement head isn't the same dual one that you and I have, it is a new one with only one insert that can apparently fit both dunlop (car tire) and presta (skinny bike tire).
Aug 07, 2010 | Blackburn Cycling
Can't get this pump to work on either schrader or presta valves! Help!
Its probably the fact that there are two separate holes for presta anad schrader, if so put your finger over the one you want to use and give small pump to vent it then attach, if not then you have to screw off the cover and invert the inner rubber core for presta or schrader, can you give me more details or pic...
Mar 26, 2010 | Cycling
How do I use a Blackburn Mountain air pump?
Dear Doug, to lock a hand pump onto the valve stem: 1.depending on valve type-loosen the valve lock for presta, twist off valve cap for schrader. 2.unlock the pumping handle from the pump so that you can actually "pump" the pump... 3. put the pump head on the valve of the tire, then pull up on the thumb tightening lever. This should squeeze toghether the internal rubber gasket of the pump, and lock on to your valve. 4. Begin pumping. 5. when desired pressure has been reached, push down on the thumb lever to unlock the pump. Remove it. Good Luck Fellow bicyclist!
Jan 18, 2009 | Blackburn Mountain Air Mountain Bike Pump...
Cycling Logo
1,374 people viewed this question
Top Blackburn Cycling Experts
Donald Ayers-Marsh
Paris Johnson
Paris Johnson
Level 1 Expert
Are you a Blackburn Cycling Expert? Answer questions, earn points and help others
