Question about Toshiba Televison & Video
Cooling problem White lines appear across the top. Using floor fans to keep TV cool and white lines disappear
  • 59 Answers
More than likely its the field output ic or caps around that stage
using hairdryer and freezer spray you can narrow down the faulty component
best of luck.
Posted on Sep 07, 2009
My tv has several white horizontal lines running across the top of the tv screen the tv brand is an Insignia SDTV and its an older tv what can be done to remove these lines?
This is a retrace blanking problem. Probably, the Vg2 voltage is too high, so the cut-off point from the picture tube is not correct. Try to lower this voltage. On most common flyback trafo's it is the lower adjusting screw (plastic kind of button) which is used to set the Vg2 voltage. Turn it a bit CCW until the white lines disappear.
Jun 14, 2014 | Televison & Video
White line across screen
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sony 46 KDL46EX523 LCD TV
Small white dots have started to appear on our screen, first, on, then a couple days later 2 more, and today we have 6 small white dots on our screen. What is happening to cause this condition?
Your problem is that the DMD device is failing. You're in luck, though. Mitubishi has recently released a replacement DMD device in order to keep repair costs down for the consumer. Take your TV to an authorized Mitsubishi servicer for repairs.
Sep 25, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
When I first turn tv on there are several white horizontal lines across the top part of tv. They disappear after tv is on a while.
please check if the power outlet have the proper power output, low current have that effects to the flat panel TV
May 21, 2011 | Televison & Video
WHITE SMOKE OUT OF EHAUST
White smoke is caused by engine coolant / antifreeze being processed in the combustion chamber(s) of the engine
Keep in mind that, on a cold day you may see what appears to be white smoke from the exhaust that will disappear after the vehicles engine has warmed up to it's normal operating temp.. This is a normal reaction called condensation... condensation is the result of a small amount of water/dew being drawn into the exhaust usually collecting in the muffler and/or the catalytic converter.
Hope helps.
Mar 20, 2011 | 2002 Nissan Sentra
White lines across top
Your symptom sounds like a faulty capacitor in the vertical deflection circuit.
What you are seeing is called vertical fold-over.
If you want to fix this yourself and are handy with a soldering iron, it is not that difficult. Just look for a 1uf capacitor near the vertical IC. The vertical IC will be a black IC with straight legs mounted to a heat sink, generally in the center of the circuit board.
Note: Be careful when working on a television as the CRT and other capacitors can hold a charge that can be very dangerous.
I would recommend that you contact a local service center and see if you can get a quote for the repair. I would normally charge between $120.00-130.00 for this type of repair. The cost may vary depending on where you are located.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Sep 07, 2009 | Toshiba TP50H60 50" Rear Projection...
XB360 Screen colour changes and then disappears
Could possible be your television.
Or maybe your Xbox is overheating.
Try placing your Xbox in a cool spot, direct a fan at it, etc.
Or try getting a new TV or Xbox.
Jun 29, 2008 | Microsoft Xbox 360 Console
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
