Question about Welding Tools
I have a Hobart Champion 8500 stick welder. I am having trouble with getting it to weld on automatic idle as it will not idle up; but on 110 circuit it does idle up. I was wondering could it be the idle transformer? Can you help me?
    President:
  • 497 Answers
The idle transformer would be the first thing i would check. youre on the right track. Replacement should take care of youre problem.
Posted on Sep 07, 2009
Hobart welder generator
Sorry we do not have those diagrams.
Oct 31, 2017 | Electrical Supplies
Thermadyne predator has one cylinder not firing
Check or replace ignition wire, spark plug spark plug coil. Run a cylinder compression check. Should have same compression on both cylinders. If not, burnt valve, or flat cam lobe.
Sep 18, 2012 | Hobart Welders 500545 Champion Elite 11000...
I have a hobart champion 16 and it will barely arc it will not make a weld it went from welding fine to doing this.
Could be something as simple as worn brushes, dirty slip rings, or a bad bridge rectifier. If you know how to check them, these are all something you could fix. If it's anything beyond those, you're best bet would be take it to a repair facility. I repaired welders for 18+ years. (just an FYI)
Jan 04, 2011 | Hobart Welders 500545 Champion Elite 11000...
I have a Hobart Champion 10,000 welder generator. It runs but I am getting no juice out of it. Won't weld or put out power to run anything.
measure ouput on ALL available sockets - anything?
Take cover off electric motor-generator, visually inspect windings.
Measure continuity of all stator windings (2 or 3 points usually)
Measure continuity of stator thru brushset.
If all measures ok - has to be AVR module.
There is no mistery in generator - just stator to induce and rotor to obtain voltage.
Jan 01, 2010 | Hobart Champion 10,000 All-in-One...
Welding breaker keeps popping on my Hobart Champion 10,000.
look for short inside unit,start at breaker and work your way back.
May 24, 2009 | Hobart Welders Champion 500433A Factory...
Champion 8500 doesn't have full voltage underload
Sounds like you need a tune up. Check or replace spark plugs, air filter, fuel filter, carberator, and idle linkages.
Apr 22, 2009 | Hobart Welding Tools
Won't idle down between welding
have you went to your local welding store? Praxair or airgas can call Hobart for the part you request,or they will call their Hobart salesman for you.
Mar 08, 2009 | Hobart Welders Champion 500433A Factory...
Welding Tools Logo
46 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
