Question about Brother MFC-8860DN Printer
Printer says "No Paper" when there is paper in the tray
After looking at this for awhile, I am fairly certain that the problem lies in the mechanism which lifts up the paper in the paper tray. The gear system on the paper tray appears to function ok, so I believe it is the corresponding gear on the printer frame that is not functioning correctly. This gear is easy to move by hand and does not give resistance as if it were connected to a motor.
Has anyone seen this issue before? And if so, is there a way to fix it?
By manually lifting up the paper in the tray by placing a ball of paper under the lift gear I can make the printer feed correctly, but this is not a real solution... And yes, I have checked the rear stop clearance as well.
  • 215 Answers
SOURCE: Paper tray not lifting the paper up for the initial paper feeder
most common problem on these is the rear paper stop pressing too hard against the rear of paper causing paper not to lift. make sure you have about an 1/8" gap.
good luck,
razors
Posted on Jan 09, 2009
yooperbud
  • 8637 Answers
SOURCE: Brother mfc 420cn must lift cover then close to print
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came withthe printer. When the software program asks you to connect theprinter to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
  • 215 Answers
SOURCE: MFC886DN will not pick up the paper in the lower tray.
first, most common problem is the rear stopper in the cassette is pressed too tightly against rear of paper. leave 1/8" gap between stopper and rear of paper. if that doesn't help, pull cassette out and locate gear on left side of cassette bay and make sure it is not dislodged.
good luck,
razors
Posted on Apr 15, 2009
Evildice
  • 217 Answers
SOURCE: MFC has a clicking sound when lifting paper then
try to clear paper feed rolers...remove paper tray, look for rubber, clean it whit wet cloth or alcohol or just repleace rollers whit new ones
Posted on Dec 14, 2010
  • 134 Answers
SOURCE: MFC-210C, keeps saying " NO Cartridge" lift
This unit has issues with the ink detect sensors. Have you tried a brand new cartridge? Other wise you may need a technician to solve the issue directly.
Posted on Jun 26, 2011
Printer says paper jam, But there is no paper jam.
I will ask where does the sheet of paper lie inside the printer when it jams or is there no sheet of paper to be seen. Next question does the printer actualy pick up a sheet of paper. if not may be worn\ missing grey rollers, which can be seen by removing paper tray and looking in and up. There are 3 main sensors usually one at the paper pickup from tray, next one half way through( under a plate which is under the toner cartridge) and the last one is on the fuser at the rear, although the last one normally gives the alarm message " jam in fuser area" check these sensors out for sticking or not free.
Dec 22, 2014 | Lexmark Office Equipment & Supplies
What is code error e03
Printers & Copiers
Code error E03
Nov 14, 2014 | Office Equipment & Supplies
Paper tray in my image class MF8350 won't close
There's probably a piece of paper wadded up in the feed mechanism. Carefully remove the paper tray and look in the feed rollers. Also be sure all the "guides" are in their proper orientation.
May 19, 2014 | Canon Imageclass Mf-8350cdn Color Laser...
My paper feeds out the back and I want it to print out the front. How can I set this up?
If the paper output tray is pulled out at the bak then paper will exit through the back (face up). If you push this tray down then paper will exit out the top and lie face down on top of the printer. The tray that pulls out of the front of the printer is a input tray only and cannot be used to output any pages.
Jul 28, 2011 | OKI Electric Industry B4600 Laser Printer
PAPER FEEDS OUT OF THE BACK INSTEAD OF THE FRONT
If the paper output tray is pulled out at the back then paper will exit through the back (face up). If you push this tray down then paper will exit out the top and lie face down on top of the printer. The tray that pulls out of the front of the printer is a input tray only and cannot be used to output any pages.
Jul 26, 2011 | OKI Electric Industry B4600 Laser Printer
Samsung ML-2250 the printer is no longer able to feed paper from paper tray. Just spins and doesn't print.
Hi, the only suggestion I could give you is to look where the paper leaves the tray to make sure there are no pieces from a paper jam. Some people even tried using a vacuum cleaner to try cleaning it out.
Other suggestion is to make sure you have the proper paper size selected.
Start, control panel, printers, your printer, printer preferences.
The mechanism that lifts the paper in the In tray up to the paper wheels may either be jammed or broken.
I guess that will help.
Thanks for using fixya...
Oct 28, 2010 | Samsung ML2250 Laser Printer
Red "Paper" light stays on; printer will not print.
Paper light flashing could mean several things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. You can also check in between the drum and toner by removing the toner from the drum. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 11, 2010 | Brother HL-2040 Laser Printer
THE PRINTER IS INDICATING A PAPER JAM, THERE IS NO SIGN OF PAPER, THE DRAWERS ARE ALL CLOSED TIGHT
Paper light flashing could mean a few things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. Open the back cover and look for a Jam as well.
Apr 05, 2010 | Brother HL-2040 Laser Printer
Printer not picking up paper from paper tray
1). take all the paper out of the paper tray.
2). look at the printer pickup roller while you enable the printer to print a test page.
3). if the roller is not turning, and hear click sound, then you need to take the printer to be service. The gear that runs the pickup roller is broken.
4). if the pickup roller truns, but you still hear the click sound, then most likely the secondary roller gear is broken. You still need to bring it to be repair.
call the repair shop and find out how much it cost and how long, It is cheaper to get a new printer than to have it fixed.
Jun 03, 2009 | HP Photosmart C6100 All-In-One Printer
Paper pick-up for by-pass tray won't work
OPEN BACK AND LOOK FOR A SMALL PIECE OF PAPER FROM PRINT JOBS PAST THAT MAY HAVE JAMMED ...FOLLOW THE PAPER PRINT TRAIL, CHANCES ARE YOU WILL FIND SOMTHING BLOCKING THE PATHWAY!
Dec 07, 2008 | Ricoh Aficio SP C410DN Laser Printer
Brother MFC-8860DN Printer Logo
116 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
