Question about Kenmore 62702 Microwave Oven
Kenmore microwave does not heat anymore.
My Kenmore microwave does not heat anymore. The light turns on, the turn table rotates but the item does not get heated. It does make a different noise when it rotates. There is an extra buzz in the usual sound the microwave makes.
My model number is: 363.62709200. Can someone please suggest what may be wrong? If this is a part I can change, can I buy the replacement part somewhere?
Thanks,
Sri
  • Kenmore Master
  • 9,086 Answers
Assuming your inside light, turntable, and internal cooling fan all come on when you try to microwave, with the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron.
The diode is a fairly cheap fix, and the mag will cost more.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Kenmore microwave does not heat anymore. - d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
http://www.gallawa.com/microtech/cap_test.html
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven Sears parts site.
But Sears parts can usually be obtained for far less here by entering either the part number.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 12, 2009
Why
The table motor belt may have detached which stops table from rotating and the magnetron control shuts off the heating if table does not move. Need model number etc for the microwave. It is not recommended to open the units unless you are qualified technician or understand the operation of the microwave oven. The voltages and waves can harm human body.
Sep 02, 2014 | Kenmore Microwave Ovens
Why microwave does not heat anymore
Well, we are looking at a bad magnetron, cracked high voltage diode, or a shorted high volage capacitor. I would suggest replacing the microwave oven because the expence involved to have it serviced.
Mar 29, 2012 | GE Microwave Ovens
My Kenmore Built-in microwave doesn't heat and the turn table doesn't turn. Model 911-47812200
It is good that the microwave does not work all together. It might be an interlock button or even a relay connection burn on the main mother circuit board.
Need a qualified technician. The service manual will be like $20-50.
e
Nov 22, 2011 | Microwave Ovens
GE Microwave model hvm1750sm1ss powers up fine, table rotates, lights on, but does not heat up item
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 12, 2011 | Microwave Ovens
Hi there, unit worked fine this morning heating coffee, now has a different tone, and not heating. Timer works, interior light comes on, turn table rotating. Unit is a KEMC308KSS01
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Dec 21, 2010 | KitchenAid Microwave Convection Oven
I have a Kenmore Microwave Oven.The turn table stopped rotating and the unit does not heat. It sounds like it is working but it does not heat. Does the turntable have something to do with this?
What you probably hear is the fan. If it's not heating the problem is almost certainly the magnetron. The magnetron is the main component in every microwave and can be very expensive tp replace. You'll be better off buying a new microwave. The prices on new ones have dropped dramatically, I saw a 700 watt unit selling for $50.00.
Nov 20, 2010 | Kenmore Microwave Ovens
On switching Microwave oven turn table rotates and light in the chamber also lights. Heating of of food do not take place. What is possible reason?
Basic Microwave Oven TroubleshootingTips
heatman101=--=
Aug 29, 2010 | LG LMVM1935 Convection/Microwave Oven
Kenmore microwave model 721.80033700 won't heat
heatman101
Jul 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore 62702 Microwave Oven Logo
375 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
