Question about Moultrie MFH-DGS-100V2 Digital Camera
Put new rechargable battery in it and the camera shut off saying battery low. IT takes less than a day.
    President:
  • 2,761 Answers
There's always the possibility that your new batteries are defective, or that your charger is not working properly, but the problem you describe is frequently due to corrosion on the battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion buildups may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment, clean the contacts at both ends of the batteries, and reinstall them in the camera. Assuming that the batteries are fresh/fully charged, this takes care of about 90% of the startup problems. I hope it works for you.
Posted on Sep 07, 2009
My camera is less than a year old.I have put in new batteries.Sometimes it will turn on,sometimes not.
I bought a kodak c182 for my daughters wedding. it work wonderfully, but now I have a problem with the batteries. I can put in new batteries take 1 picture, then it says low battery and shut off. I have place seveal new batteries in and get the same results. Could it possibly be a promblem with the memory card.
Mar 15, 2011 | Kodak Easyshare C182 12MP Digital Camera
JUST PURCHASED NEW CAMERA, PUT NEW BATTERIES IN AND AFTER TAKING JUST A FEW PICS, BATTERY LOW INDICATOR CAME ON AND SAYS IT NEEDS NEW BATTERIES. PUT NEW ONES IN AND AGAIN, BATTERY LOW INDICATOR CAME ON. ...
yes, The Flash mode consumes LOT of power, thats why it needs lot of batteries, use " rechargable batteries", or use camera without FLASH, and use GOOD QUALITY battaries
Jan 22, 2011 | Canon PowerShot SX100 IS Digital Camera
Sanyo VPC-E90 Turns off then back off
If it's really almost new, why don't you take advantage of the warranty?
Apr 17, 2010 | Sanyo VPC-S880 Digital Camera
Olympus FE170 digital camera shows battery compartment empty with batteries in place I have the same problem. When I place fully recharged batteries in the Olympus FE 170, the camera won't power on at...
on rechargeable batteries, check the mAh on the side, you would need to be about 2300 or more. also the shelf life on some rechargeables may be less than desireable... try lithium digital
Dec 16, 2008 | Olympus FE-170 Digital Camera
Camera shuts off after a few seconds
i had that problem with another camera i toggled with the lens it went in and works like a charm. Dont be to gentile it will go in
Oct 08, 2008 | Samsung S630 Digital Camera
Camera hp m425
try quality batteries like Duracell or Energiser... and also make sure u give ample interval of 2-3min before each snap...
Sep 16, 2008 | HP Photosmart M425 Digital Camera
The camera we purchased won't take more than 4 0r5 pictures before it says low battery and won't take more pictures. recentlu when we put in new batteries it says low battery.
You did not say what kind of batteries you are using. If they are AA rechargeables they need to be recharged if they havenot neen used for a while. Say if you took 4 or 5 pictures, the batteries died, you charged them but did on use the camera again for several weeks. When you do they will be dead again, that in the nature of rechargables, they lose charge just sitting there. Solution find the Sanyo Enteloop or Rayovac Hybrid brands, these next generation rechargables have a shelf life similar to NiCads.
Jul 23, 2008 | Samsung Cameras
Camera
I am having the same problem with mine. Sorry to say I haven't found a solution yet, but am seraching!
Mar 31, 2008 | Sony Cyber-Shot DSC-W1 Digital Camera
Canon
You need to power it with rechargable batteries. with the MAH being no less than 2000. I bought a charger which came with 2batteries for less than a tenner
Dec 23, 2007 | Cameras
Fuji A345 finepix
As batteries are recharged- they develop a 'memory' That is to say starting with a new fully charged battery- the 'low' light may come in when the voltage drops below a certain value. The battery is not however fully discharged. It could have say 25% residual in it. When recharging- the charger is charging the 75% only, and on the next recharge- that mush less again until the battery is only offering a small percentage of its capacity. The answer is to put the low battery in a simple device - a torch - until it is completely down Then recharge - you will then get the full capacity of the battery. Meanwhile do contact the Tech support of the manufacturer just in case there is a known problem with a given model.
May 16, 2007 | Fuji FinePix A345 Digital Camera
Moultrie MFH-DGS-100V2 Digital Camera Logo
130 people viewed this question
Top Moultrie Cameras Experts
AZBen
AZBen
Steve
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
