Question about Maytag MDB5100A Dishwasher
#MDB5100AWB-water not draining. Screens were plugged bad. Taking all apart to clean/rinse.how do you take the bottom of assembly off? Thanks for any help.
  • 46 Answers
U need to remove the machine there are two screws at the tap of machine then u can chek everthing bottom of assembly (your pump seems to be the problem good luck
Posted on Sep 07, 2009
  • 10,865 Answers
Hello. to remove the lower panel you will need a phillips head screwdriver and a flashlight. get right down there and you will see that it is attached with screws. remove them and the front panel will come right off.
Regarding your water not draining issue. Begin by disconnecting the rubber drain hose, and the small pump at the low end of that hose. Examine for debris and remove it. Next inspect the trap under the kitchen sink and the garbage disposal if that is included. Chances are you will find a blockage.
My dishwasher Leaves food particles on the dishes and one the dishwasher. It appears to clean the dishes. What can I do about this?
Have you tried checking the filter in the bottom of the dishwasher, if this is blocked it will keep churning the waste matter around on each wash cycle and just drain the water away
Feb 17, 2012 | Dishwashers
I have a 3-gallon gilmour sprayer--has worked well-only several month old-able to get good compression but can not get anyspray-even after taking apart and rinsing your help is appreciated thanks ...
This situation sounds like a plugged hose. Keep taking apart and you will find something plugging a small orifice, somewhere... Always flush with clean water after each use, many garden sprays crystalize over time......
Apr 24, 2011 | Gilmour & Spray Doc& Poly Tank Sprayer...
I have a Frigidaire front-loading washing machine, model# FTF2140ES3 (serial# XC63816300). It works fine through the rinse cycle, but does not drain or spin. If I turn it to the rinse/spin only cycle, it...
Hi
Thanks for using FixYa. Please check the water pump. Either the water pump bearing is bad or there are some tiny pieces of debris stuck in the water pump. It is located below the door latch assembly. Remove the front panel and check the drain pump which is attached with hoses. Remove its clamps and clean the drain pump. You can also remove the drain pump by unbolting it from the washer base. If still the issue persists, then check the motor speed control board which is located inside the bottom of the washer. Please do accept the solution if the issue is resolved or
post a comment for further assistance.
Thanks
Rylee
Jun 08, 2010 | Washing Machines
Dishwasher didn't drain completely after final rinse.
Check the drain hose stub connection at the disposal for plugging. Lots of material flying around in there which could block the stub pipe. You might consider inserting a short section of drain pipe that has a built-in stub into the regular sink drain and plug the disposal stub. Also check the screen at the bottom of the lower spray arm assembly for plugging. Clean the screen in a mixture of hot water/detergent/white vinegar for an hour or so. That will remove hard water deposits from the screen as well as any food debris. The draining process is a timed event, so it depends on fairly rapid removal of the water. Hope some of this helps!
Mar 19, 2010 | Frigidaire 24 in. PLD2850 Built-in...
We have a Whirlpool Gold Quiet Partner GU980SCGZ0 model. When rinse cycle is over the water only trickles out when draining. We checked the drain and it is not plugged. Water remains sitting in bottom of...
I took the check valve assembly off the bottom of the pump assembly and there was a big chunk of string balled up in the line which created a plug against the screen when trying to drain.Works great now!
Feb 15, 2010 | Whirlpool Dishwashers
Maytag MDB5100AWB Dishwasher not draining
More than likely the filter is clogged,remove the spray arm(there is a threaded cap in the center of the arm twist it to the left,then remove the # 15 or 20 torx(star shaped) screws out of the filter cover(around the edges)The filter is round and runs around the outer edge of the pump housing it lifts right out,clean it and reverse the process.It's the most common issue with not draining on this model.
Sep 26, 2009 | Maytag MDB5100A Dishwasher
Dishwasher doesn't drain
The drain motor might be worn so it still pumps out fairly well but will let wtare back in once it stops pumping. It may also have something stuck in it so it ot is worth removing and cleaning through with a good degreasing cleaner.
Sep 10, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Water not draining
For starters does it drain at all?If the drain line is connected to the sink drain and you have a garbage disposal,the drain hose could be plugged up.
Aug 06, 2008 | Dishwashers
Miele Coffee maker cva 615 coffee will not come out
The screens that the coffee grinds are squeezed in between are clogged. You need to remove the brew unit, remove the bottom screen, (should be one phillips screw in the center) and scrub the screens clean. You need to clean all of the really fine holes out so that the water can pass through. To prevent this in the future, use the rinse cycle on the machine frequently and also take the brew unit out and rinse it under hot water everytime you dump your waste unit.
May 05, 2008 | Miele CVA615 Espresso Machine
Maytag MDB5100A Dishwasher Logo
255 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
