Question about Acer Aspire 5100 Notebook
Acer aspire 5610 touchpad stopped working
I've tried everything to fix it but i couldn't.I've tried to format and change from XP to Windows Vista, updated the touchpad driver from synaptics, nothing work, if somebody can help to solve this problem i will be very greatfull. thanks.
Eduardo
vista program not working
  • 5 more comments
  • Anonymous Feb 25, 2008
    worked for me! thanks much
    usb mouse and keyboard locked up
  • Anonymous May 22, 2008
    Same problem, happened after I installed Ubuntu
  • rokbttm Feb 21, 2009
    left click button quit working. Can it be replaced?
  • Anonymous May 03, 2009
    The function key solution worked for me too, wish I had got to you sooner as I've re-installed everything and wasted a lot of time, wish the Acer website was as useful.
  • Anonymous May 18, 2009
    The Fn-F7 worked for me too but the botton in the center of the touchpad that up and down de page continues without working
There is a button to the left of the ON button above the keyboard that turns the touchpad on and off. The light next to that button should be off for the touchpad to work.
Posted on Feb 11, 2010
My Acer Aspire 5100 laptop has the same problem.
I really appreciate the above guest's answer. Actually, I found that I had accidentally pressed FN+ F7. the action disabled the touchpad mouse. Yah!!!!
Posted on Jun 22, 2008
  • 4 Answers
I have the Acer Aspire 5610Z and I had the same problem. I tried everything and nothing worked. I remembered I have the extended warranty so I called them. I felt so stupid after I found out what the problem was. I will share it with you and hope it is a simple solution for you as well.
I am using Windows Vista but that has nothing to do with it. There is a function key on the bottom left side of the key pad that is marked Fn in blue. Hold this tab down and at the same time tap on the F7 tab. This turns the touchpad on or off. There is no message that comes up so you just have to test out the touchpad each time to see if it is on or off. I am sure I knew this at one time but I forgot it so I made a document in word to remind me when I have a senior moment again.
I hope this helps someone else.
Posted on Dec 16, 2008
    Problem Solver:
  • 11 Answers
You should check the status of the touchpad. Go to the control panel, System, Hardware, Device Manager and look for the touch pad(on my computer it is labeled as Human Interface Devices). Right click and Properties. Make sure the device is working properly. A similar thing happened to my Sony Vaio. Even without the drivers that it needed, it still showed as working properly. Other than that, I would think it will most likely not be functioning and needs to be replaced.
Posted on Dec 09, 2007
Remove the battery. Ive done this and it worked. My keyboard also froze up system was slow keyboard worked about 50%. removed battery back to normal 100%
Posted on Jan 29, 2008
The Fn+F7 works for me too...WoW, Thanx So Much
Posted on Jul 26, 2008
The Function F7 didnt help me, I'd long since tried that. reinstalled drivers and everything. But removing the battery and putting it back in DID solve the problem! amazing! Thanks!!!!
Posted on Aug 16, 2010
    Problem Solver:
  • 27 Answers
Hi Friends,
Acer Aspire 5100 PC Notebook main problem is Connection Problem, Software Problem etc.
For these problem you can visit a link by just Click Here .
For any other problem with this Notebook you can Click Here
Posted on Jul 20, 2010
Hey has everyone found what the driver name is for the touch pad aspire 5610z iff you look onto ya device manager it shows on there if you click onto mouse that there isnt no driver there so try finding the driver and installing it by searching for new hardware once you got the driver downloaded.
Posted on May 02, 2010
Thanks, the Fn +F7 key really helped me out. Thought I was losing my mind in the middle of my term, lol, thanks!
Posted on Sep 09, 2008
Fn+f7 worked for me too but only by doung it after a clean restart thankyou, you saved my sanity
Posted on Aug 30, 2008
Thanks dude Fn+F7 work for me 2. thanks thanks thanks thanks
Posted on Aug 26, 2008
So I have a problem with my touchpad in acer aspire 5610, my left buttons not working
Posted on Aug 06, 2008
Bad *** man !!!! great solution
Posted on Jul 13, 2008
None of this worked for my 5100!!
Posted on Jun 18, 2008
The remove-battery thing was a saver! thanx!
Posted on May 26, 2008
Wow, I had the same problem on my 3680. The Fn F7 worked for me too. I wonder how many people do that! Thanks soo much.
Posted on May 23, 2008
Fn key F7 worked for me - thanks for your advice I was beginning to dispair!
Posted on Mar 12, 2008
Had this happen to me and finally figured out that I had accidentally pushed the FN key and the f7 when I held FN and hit f7 it worked again, that is i guess some key to turn it off for what ever reason.
Posted on Jan 24, 2008
2 Suggested Answers
SOURCE: acer aspire 5610 touchpad stopped working
On my acer it is the fn and f7 button pushed together.. that turns the touchpad on and off
Posted on Dec 20, 2007
Labtop camera stop woking
Did the machine come with originally vista os installed or it was xp. Try to re install the driver. Still if it doesnt work, i would suggest that it is wise to send it for a depot repair. Good Luck.
May 05, 2010 | Acer Aspire 5610 Notebook
I need to format windows of my laptop acer aspire 5610. I need software build in hardware driver of laptop acer aspire 5610.
Go to the Acer WEB site to download the Windows drivers you need, make sure it is Windows XP or Vista version of the drivers for your particular MODEL laptop.
Use this link :-
http://global.acer.com/support/download.htm
Apr 01, 2009 | Acer Aspire 5610-4648 Notebook
Pioneer DVR-K17RS ATA ACER CODE=39
Code 39 for cd/dvd drives is a common problem, you need to edit the registry to fix this error. See these instructions on how to fix code 39.
Mar 28, 2009 | Acer Aspire 5610-4648 Notebook
Touchpad not working after re-install windows XP SP2.
You can't load Windows XP over Vista. Microsoft has it in the BIOS that it cannot be overlaid with an older system. The only way to use XP is to attempt to dual-boot but that will take you some research. Load vista back...don't blame me Microsoft screwed us..
Pls rate solution.
Feb 28, 2009 | Acer Aspire 5610-4648 Notebook
Acer aspire 3680 PQSERVICE
if you have installed vista and change it to xp, you should first delete or reformat your current OS (Operating System) which I believe is the ur vista.
formatting OS:
-insert your xp disk then press F8
-click format or delete files ( i don't know the exact message that will appear on the screen)
-then install windows XP (just follow the instruction that you will see on the screen)
hope this would help you solve your problem..
thanks.. :)
Aug 22, 2008 | Acer Aspire 5610-4648 Notebook
How to format acer aspire 5610
My PC is running too slow so i want to format my pc (which is acer Aspire T310) so that it comes back to normal. I want to know everything about it because i havent tried it before. Some questions are:
1.How to format?
2.How to reinstall the windows?
3. How to get MS powerpoint,word etc?
Jul 27, 2008 | Computers & Internet
Keyboard + toucpad freezes
Might seem ovious but you may want to try Acer support and look for a new Driver.. Also check under Control Panel...Mouse options... and also check device profiles to make sure windows isn't loading a "docked profile which may disable touchpad and laptop keybaord use.
Feb 21, 2008 | Acer Aspire 5670 Notebook
Nov 20, 2007 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5100 Notebook Logo
18,961 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
